    How to change dimension in Profile Builder 1?
    13 Posts 3 Posters 1.6k Views 3 Watching
      You can't modify profil measures with the free version! πŸ€“
      So explode your result and make some Scales...
        Post your SKP file "save as" (version V6) )
          JSA_SJ
          Thank you so much Pilou!!Would you help me to try please?
          I exploded it and did the scale then but it still wouldn't make the proper look.
          My Arch.skp
            JSA_SJ
            I JointPushed it after exploding it, looks nicer?
              JSA_SJ
              Or I may need to buy PB2 as it may be very helpful
              • pbacotP Offline
                You can draw a profile- Take the original profile, modify it and draw. -or has this been removed from version 1? You can't modify things after drawing in PB1.
                • pbacotP Offline
                  It looks like you are doing this with followme and that should work OK for this. Why not redraw the profile and run again? I'd use more segments in the arc (unless this needs to be "low poly" -in which case the profile itself is needlessly faceted / detailed)
                    I have not the free but...
                    You can't "Stamp" the Profil, then explode, then Group , then Scale ?
                    Sure in Pro version you can make like that but...
                      JSA_SJ
                      Thank you both so much!!! Finally made it through, my circular arch! Couldn't be any happier.
                      With Profile Builder 1 Free edition, I don't have 'stamp' though I use 'Build' to create the 'Crown' profile, had a few adjustments - scale, rotate, copy the face, then FollowMe on selected path. πŸ˜› πŸ˜›
                        Cool! β˜€
                        Maybe you can change: Menu Style / Edges / Disable Extremities
                        for not have these black dusty lines! πŸ˜‰
                        And use this very easy free Render : SimLab Composer Light (maxi 1920 * 1080)
                          JSA_SJ
                          Thanks again for your answer!It looks so much nicer when all the black lines hidden.
                          Much appreciated!!
