    [resolved] Place this cube under mouse!
    6 Posts 2 Posters 946 Views 2 Watching
      Why this cube is not dynamic position under the mouse ? (V 2017)
      Exported as V6 : it has the normal dynamic position under the mouse when reloaded!
      cube.zip
        What is happening is caused by the cube skp having been geolocated.
        When it's inserted as a component, it then snaps to the origin.
        Edit the cube skp file and remove its geolocation.
        Save it and retry inserting it again.
        This time it should be at the mouse cursor location until you place it with a click.
        Ce qui se passe est causée par le cube SKP avoir été géolocalisé.
        Quand il est inséré en tant que composant, il se mette à l'origine alors.
        Modifiez le fichier SKP cube, et supprimer le géolocalisation.
        Enregistrez-le et essayez de nouveau l'insérer à nouveau.
        Cette fois-ci, il devrait être à l'emplacement du curseur de la souris jusqu'à ce que vous le placez en un clic.
          Many thanks!
          PS Where is the option for that ? 😳
            I don't want explode the object because it's for a Dynamic Component !
            So how do you make an "Un-geolocalisation" ?
            I have seen the Menu File / Localisation but it show only Add possible not Erase!
              In Model Info...
              It should look like this - NO geolocation set up.
                In fact my error was to "Import" the file and not "Open"!
                (cube of the first post who was not a component)
                So it was automatically transformed in a componnent! (doh of the day for me)
                In fact seems you are not obliged to Edit the Component!
                Just Erase the Geolocalisation and save file seems sufficient...
                or maybe not if many different localisations are possible in a same file?
                Thanks for have found the trick! 😎
