    Australian Victorian balustrade?
    9 Posts 5 Posters 715 Views 5 Watching
      DesignBrenden
      I want to add decorative feature to my Australian Victorian house in SketchUp:
      (Outlined in Red) Where can I find this?
        Depending of what do you want ?
        For a file 3D of for an image...
        You can use image as texture...on a box
        You can use some free Vectorizer on line like http://www.autotracer.org/
        and obtain some funny result πŸ˜„
        But you must have a more detailed image!
        render free SimLab Composer Light! (1920 *1080 max)
        Or you can modelize the model itself πŸ˜„
        Alas for you seems not existing at 3Dwarehouse
          DesignBrenden
          Here is a more detailed image:
          I want to add it like you see. Place it on a verandah.
            So a cool exercice for you! πŸ˜‰
            Maybe this can help you! (it's free)
            DrawMetal
              pcmoor
              Outline the lace structure, push out 25mm, then add photo texture of the lace
              • gillesG Offline
                gilles
                As you are a beginner I suggest you to draw it, with the use of components you won't have to draw that much, else you can create a library and re-use.
                You can find some pics there:
                http://centralfoundry.com.au/lacework-corners-and-freize/#prettyPhoto
                Victorian Frieze.skp
                  Model by Gilles
                  Render : free SimLab Composer Light! (1920 *1080 max)
                    DesignBrenden
                    Thanks heaps guys! πŸ˜„
                    • HornOxxH Offline
                      HornOxx
                      Besides modeling the geometry itself you could use suitable PNG textures as well
                      (picture material from the web or self-made).
                      For my example I have used image material which Gilles has recommended by his link above
                      001.skp
                      never trust a skinny cook
