    Layout and Mac El Capitan
    layout
    13 Posts 3 Posters 4.0k Views 3 Watching
      architect
      Still using Layout 3.0.16845 and am now using Mac El Capitan 10.11.6. Won't let me select objects with click and drag. I assume since I'm still on Sketchup 8 Pro it's time to dig myself out of the paleolithic era. Are the latest versions of Sketchup Pro/Layout now compatible with El Capitan?
        It's possible it's an issue with the graphics drivers but you are using a version of SketchUp and LayOut that aren't explicitly compatible with El Cap. The current version of SketchUp and LayOut is 2017 and it is compatible. See: https://help.sketchup.com/en/article/36208
          architect
          Dave, the upgrade site says "SketchUp also requires a 3D class video graphics card made by NVIDIA or AMD. Intel-based graphics cards are not recommended at this time."
          I have an "ATI Radeon HD 5770"
          Am I looking at purchasing a new graphics card first? What about the 32-bit-color Cinema HD Display?
          Chipset Model: ATI Radeon HD 5770
          Type: GPU
          Bus: PCIe
          Slot: Slot-1
          PCIe Lane Width: x16
          VRAM (Total): 1024 MB
          Vendor: ATI (0x1002)
          Device ID: 0x68b8
          Revision ID: 0x0000
          ROM Revision: 113-C0160C-155
          EFI Driver Version: 01.00.436
          Displays:
          Cinema HD Display:
          Display Type: LCD
          Resolution: 1920 x 1200
          Pixel Depth: 32-Bit Color (ARGB8888)
          Main Display: Yes
          Mirror: Off
          Online: Yes
          Rotation: Supported
            ATI Radeon cards are well known for their less than adequate support for OpenGL which SketchUp relies on. I don't know if you can update the drivers for that card independently from the OS. Apple pushes graphics drivers with OS updates and they automatically get updated.
            As far as HD displays, SketchUp 2017 has had updates to make it work better with them although they say they have more to do in that line. The big thing right now is that some extension authors have yet to update their toolbar icons to work and play well with the HD displays.
              architect
              Mac website says the ATI card I have will use openGL 4.1 and openCL 1.2 are those new enough?
                architect
                Further checking from my system profiler shows an OpenGL version 12.1.0
                Untitled.pdf
                  mwm5053
                  I don't know where you got that off your computer, ver 12.1 doesn't make sense. I think the highest is 4.1. Maybe you should check this out from Apple.
                  Mac computers that use OpenCL and OpenGL graphics - Apple Support
                  Applications in macOS can use OpenCL and OpenGL to take full advantage of the modern graphics processor (GPU) in your Mac. Learn about the OpenGL and OpenCL versions that your Mac supports.
                  Apple Support (support.apple.com)
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                    architect
                    I saw that, that's where the info in my first post from the 10th came from. Then from the apple logo on the desktop screen I went to "About this mac" then "system report" button in "overview" tab. See attached, it's referring to frameworks under software. Regardless, will I be OK to upgrade to the latest version of SU Pro with what I have (ATI Radeon HD 5770)?
                    macinfo.pdf
                      mwm5053
                      I'm not sure what Apple is referring to there. You can find an app in the App store called OpenGL Viewer like in my screenshot below. That being said I would think you would have no problem with SU 2017 on your Mac at least you would have tech support since SU no longer supports SU 8. I was using Sierra on my Mac and SU 2017 but had problems with my SU 2015 Pro so I installed Yosemite. Download the Trial ver. of SU 2017 and LO and see if it works you should have no problems though.
                      2011 iMac
                      V2 Twilight
                        mwm5053
                        Also if you do a screenshot on your Mac and view it in Preview you can export as a jpeg instead of a PDF that way people can see what your referring to. Sketchucation won't let you post PNG as you found out.
                        2011 iMac
                        V2 Twilight
                          architect
                          Thanks, will remember about the jpeg and didn't even think about trying the trial version. Duh
                            It won't?
                            This is a png file.
                              mwm5053
                              Thanks Dave I stand corrected
                              2011 iMac
                              V2 Twilight
