    Round Corners do Not Drape
    4 Posts 2 Posters 6.9k Views 2 Watching
    • Bob JamesB Offline
      Bob James
      Simple plan with two rectangles: one with all four corners rounded and one with only two corners rounded.
      All straight lines are draped correctly, but the rounded corners do not.
      • TIGT Online
        How small is this geometry.
        SketchUp's in-built 1/1000" tolerance can prevent tiny edges from forming, so sometimes it incorrectly deduces that two very close points are coincident and then it doesn't make the edge !
        Try Scaling everything up x100, retrying the process and see if that helps.
        Scale back down afterwards...
          Bob James
          Redone with sufficiently large dimensions.
          • TIGT Online
            I can replicate it.
            With a radius ~1" the segments should be long enough to exist, do it fails.
            So the in-built 1/1000" issue should not kick in as the segments are considerably longer than that.
            Making it say ~2", then it does not present the issue at all...
