    Mass convert SU files to different version?
    16 Posts 9 Posters 7.5k Views 9 Watching
    • E
      ericschimel
      I've been looking around and I'm trying to find a way to mass convert SketchUp 2017 files down to SketchUp 8 files. I've found this great plugin by Jim Foltz:
      404 Not Found
      (sketchucation.com)
      Unfortunately, it does it one file at a time. Ideally what I'd like to do is point SketchUp 2017 at a directory full of hundreds of SketchUp models and have it open each one and do a "Save as SketchUp 8" and overwrite the file, close, and open the next one.
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
      • sdmitchS
        sdmitch
        404 Not Found
        (sketchucation.com)
        I have attached a plugin that I wrote a year ago for someone that made a similar request.
        Usage: Plugins>SDM Tools>Misc Tool>Bulk Copy by Version
        • Select the Copy Version* Select the 'From Folder'* Select the 'To Folder'
        Bulk Copy by Version.rb
        http://sdmitch.blogspot.com/
        D 1 Reply Last reply
        • E
          ericschimel
          I'm trying it and I can't get it to work for some reason (I'm on a Mac if that's helpful)
          When I fire it up it asks me for the version, and then a file dialog pops up. I forces me to browse for and select an individual SketchUp model, I can't multiselect or just pick a folder. Once I do pick a file it pops up another file dialog, assumably for me to tell it where to place the converted files. I select a location and run it and nothing happens...
          Perhaps I'm doing something wrong?
          -Eric
          Custom Models
          • sdmitchS
            sdmitch
            Since this a 'Bulk' copy, it is assumed that every model in the 'From' folder is to be copied to the specified version so it is not possible to select individual models. You only need to select any one of the models in the folder and click 'Open'. Then select the 'To' folder and click 'Save'.
            • E
              ericschimel
              Ok, it doesn't work on Mac but it does work on my PC.
              Is there any way to remove the "V8" appended to the end of the filename?
              -Eric
              Custom Models
              • E
                ericschimel
                That is actually exactly what I'd want. I'll try out that code, THANK YOU!
                -Eric
                Custom Models
                • sdmitchS
                  sdmitch
                  Yes of course but, if the 'From' and 'To' folders are the same, you will have to accept the overwriting of each individual file.
                  Change
                  mod.save_copy("#{tdir}/#{m}_v#{versions[ver]}", ver);
                  to
                  mod.save_copy("#{tdir}/#{m}", ver);
                    Jim
                    I have source code for a command-line converter available here[1]. The documentation is not up to date - although there's no time this morning to clean it up. It should compile just by typing "make" in the root folder (where the Makefile is.)
                    It builds for me under Windows using MinGW-64, I can't test Macs. You would need to modify the Makefile to point to your copy of the SketchUp SDK. You will also need a c++ dev command-line dev environment setup which might be a huge hurdle by itself. There is a link in the readme to an easy to install Windows g++ compiler suite.
                    Batch processing can be done by specifying a sub-folder in the output file:
                    mkdir temp_folder
                    loop for each skp_file in folder:
                    s2s 2013 skp_file temp_folder/skp_file
                    end loop
                    [1] https://github.com/jimfoltz/jf-sketchup-c-api-sandbox/tree/master/skp2skp
                    • sketch3d.deS
                      sketch3d.de
                      @ericschimel said:
                      ...to mass convert SketchUp 2017 files down to SketchUp 8 files.
                      just wondering for what this is required.
                      • gillesG
                        gilles
                        I confirm it does not work on Mac:
                        Ruby console output:
                        Sketchup.open_file(/Users/gilles/Downloads/@/Roller bracket.skp)
                        mod.save_copy(/Users/gilles/Downloads/@/Roller bracket_v8, 8)
                        Error; #<ArgumentError; Model must be saved before copying.>
                        /Users/gilles/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Bulk Copy by Version.rb;70;in `save_copy'
                        /Users/gilles/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Bulk Copy by Version.rb;70;in `block in main'
                        /Users/gilles/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Bulk Copy by Version.rb;64;in `each'
                        /Users/gilles/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Bulk Copy by Version.rb;64;in `main'
                        /Users/gilles/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Bulk Copy by Version.rb;29;in `block in <top (required)>'
                        SketchUp;1;in `call'
                        • gillesG
                          gilles
                          Lot of peoples like me don't upgrade to the latest version for some (good) reason.
                          If you ask here some help and upload a model we can't read, we can't help you.
                          This may be one of the reasons why this is required for.
                          • sketch3d.deS
                            sketch3d.de
                            batch converting instead of doing a "Save as..." is probably not required for this purpose.
                              andreimd87
                              @sdmitch said:
                              404 Not Found
                              (sketchucation.com)
                              hi. could you please make it working with the latest 2021 version?
                              • G
                                goldenmem
                                Hello and thanks to the developer of this extension,
                                but I tried it on sketchup 2021 and it did not work ! when I click on the covert no window pop up to select the "from" folder and "To" folder and the "Version" ! it works on sketchup 2015 but on sketchup 2021 it did not work!
                                I wonder if the developer of this extension can check and update it to work with sketchup 2021
                                Thank you,
                                  dahnuguy @sdmitch
                                  @sdmitch
                                  This plugin would be very useful if I could get it to work . Using SU version 8. Followed video instruction in this thread . Tried different folders etc.
                                  Laptop is Win 10 64 bit.
                                  Sketchup.open_file(C:/Users/12/Downloads/Projects/SketchUp/_Models/001.skp)
                                  mod.save_copy(C:/Users/12/Downloads/Projects/SketchUp/_Models/_SU 8/001_v8, 😎
                                  Error: #<NoMethodError: undefined method save_copy' for #<Sketchup::Model:0x11a22be4>> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/4JDu_BulkCopybyVersion.rb:70:in main'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/4JDu_BulkCopybyVersion.rb:64:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/4JDu_BulkCopybyVersion.rb:64:in main'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/4JDu_BulkCopybyVersion.rb:29
                                  For reference, this is the plugin code. Maybe there is a newer version?
                                  Permission to use, copy, modify, and distribute this software for
                                  any purpose and without fee is hereby granted.
                                  THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING,
                                  WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                                  THIS PLUGIN IS ANOTHER FIGMENT OF MY IMAGENATION AND IS NOT BASED ON OR COMPLY WITH ANYTHING!
                                  IT WAS CREATED AND ONLY TESTED IN A WINDOWS ENVIRONMENT AND MAY NOT FUNCTION ON A MAC.
                                  Name: Bulk Copy by Version
                                  By: sdmitch
                                  Note:
                                  Date: Feb 2016
                                  require 'Sketchup'
                                  ------------------ MENU SETUP ----------------------
                                  unless $sdm_tools_menu
                                  $sdm_tools_menu = UI.menu("Plugins").add_submenu("SDM Tools")
                                  $sdm_Edge_tools = $sdm_tools_menu.add_submenu("Edge Tool")
                                  $sdm_Face_tools = $sdm_tools_menu.add_submenu("Face Tool")
                                  $sdm_CorG_tools = $sdm_tools_menu.add_submenu("CorG Tool")
                                  $sdm_Misc_tools = $sdm_tools_menu.add_submenu("Misc Tool")
                                  unless file_loaded?(FILE)
                                  $sdm_Misc_tools.add_item("Bulk Copy by Version") { SDM::Bulk_Copy_by_Version.main }
                                  file_loaded(FILE)
                                  module SDM
                                  module Bulk_Copy_by_Version
                                  	def self.main
                                  		mod = Sketchup.active_model
                                  		ent = mod.active_entities
                                  		sel = mod.selection
                                  		version = Sketchup.version.to_i.to_s
                                  		versions = ['0','0','All','3','4','5','6','7','8','2013','2014','2015','2016','2017','2018','2019','2020']
                                  		until versions[-1].index(version)
                                  			versions.pop
                                  		inp = UI.inputbox(["Save Version:"],["6"],[versions[2..-1].join("|")],"Save by Version")
                                  		if inp
                                  			ver = versions.index(inp[0])
                                  			path = File.dirname(mod.path)
                                  			path = Dir.pwd if !path || path==""
                                  			input_folder = Sketchup.read_default("BulkCopybyVersion","InputFolder",path)
                                  			from = UI.openpanel("From Folder:",input_folder,"*.skp")
                                  			if from
                                  				fdir = File.dirname(from).gsub("\\","/")
                                  				Sketchup.write_default("BulkCopybyVersion","InputFolder",fdir)
                                  				models = Dir[fdir+"/*.skp"].map{|m|File.basename(m,'.skp')}
                                  				output_folder = Sketchup.read_default("BulkCopybyVersion","OutputFolder",path)
                                  				to = UI.savepanel("To Folder:",output_folder,"temp.tmp")
                                  				if to
                                  					tdir = File.dirname(to).gsub("\\","/")
                                  					Sketchup.write_default("BulkCopybyVersion","OutputFolder",tdir)
                                  					Sketchup.file_new
                                  					for m in models
                                  						next if m=="." || m==".."
                                  						puts "Sketchup.open_file(#{fdir}/#{m}.skp)"
                                  						Sketchup.open_file("#{fdir}/#{m}.skp");
                                  						unless ver == 2
                                  							puts "mod.save_copy(#{tdir}/#{m}_v#{versions[ver]}, #{ver})"
                                  						else
                                  							for ver in 3...versions.length
                                  					Sketchup.file_new
                                  TIGT 1 Reply Last reply
                                    TIG Moderator @dahnuguy
                                    @dahnuguy
                                    The model.save_copy method is only available >=v2014
                                    So it fails in v8.
