How to align all vertices to a plane (eg. Green-Blue) ?
 Hy, I am trying to find a way (eg. plugin that could ease the task) to align all selected vertices to one of the three planes formed by the axes. I have Vertex Tools and indeed it does "planar", but the plane is calculated I believe as the average (or most probable) plane based on selected vertices.
 The plane resulted was very close to Green-Blue plane, but not quite, which causes too many problems due too small misalignments.Please, in case you know a tool that could align a set of selected edges/vertices to a defined plane, would be great.
 Thanks.
 There is one by Tak2Hata that has some shuriken icons, that throws vertices to a plane. You define the plan and shoot. There is also another one that drops vertically to a plane. I think it's Tig's. If the vertices are supposed to be straight lines, then edgetools2 will help you.
 Vertex Tool Scale on the Gizmo align to RED,GREEN or BLUE when you scale to zero.
 Why haven't I found the time to play with SubD and VT yet?
 Your too awesome to find time.
