    Issue Inferencing along the Green Axis...
    21 Posts 7 Posters 4.1k Views 7 Watching
      slbaumgartner
      In the images @Wo3Dan showed, the intersection of the Green axis vanishing point with the horizon seems to be visible. But if you ponder a moment, you must realize that this point is infinitely far away and can never actually be seen! The ratio of pixel to distance (foreshortening) thus becomes infinite as you move up the view away from the origin! I think this makes it impossible for the inference engine to determine where you are intending the cursor to be in the model, and it gives up.
      • Wo3DanW
        Wo3Dan
        Hi Steve, Have you tried the model I attached?
        I only made these observations, ...... marking them all with *****. This does however not explain why SketchUp can't find the axis. (and I don't understand your explanation as to why)
        You are right that the vanishing point can't bee seen due to infinit distance. But looking at the 'blind' area on screen this seems to be quite large compared to the entire viewport.
        I wonder if the program couldn't be made to narrow down the blind area to something significantly smaller.
        The model origin's location on screen has no influence.
          db11
          Interesting observations regarding the centre screen inferencing 'blind spot'. This may explain why inferencing is, on occasion, so incredibly frustrating — when most of the time it works like magic. Seems the work-around for now is to draw
          outside of that centre circle.
          • utilerU
            utiler
            I opened your file Wo3Dan and tried it out but didn't see any issues...
            Just Curious...
              slbaumgartner
              Yes, Gerrit, I tried your model. As saved, inferencing on the green axis indeed fails. But if I orbit so that the axis isn't so straight back in the view, green axis inferencing works fine. Having the green axis oriented too close to the "into the screen direction" in perspective seems to induce the problem, and I was suggesting that maybe this direction causes the inference engine to struggle trying to infer how far back in the "into the screen direction" the cursor is marking in empty space. I should emphasize that my explanation was only a theory - without access to the SketchUp code I'm just guessing based on symptoms.
              • Wo3DanW
                Wo3Dan
                So did I, to see if my uploaded file was any better, .... fixed something that I wasn't aware of.
                But it is still the same, the indicated area inside the yellow "circle" doesn't trigger inference to any of the three axes. Is there no center blind spot at all for you? is this a screen / graphics card / driver depending issue?
                • utilerU
                  utiler
                  Ok, done it again.
                  This time it didn't work on the RED or BLUE axis.... Note I was within a component moving other components around. I also tried to orbit around to various locations to trick it a bit but I just couldn't find those two axises...
                  The only way is to add guidelines which then works.
                  Interencing issues.wmv
                  WorksWhenAddingGuidelines.wmv
                  Just Curious...
                  • utilerU
                    utiler
                    More of the same.... really starting to annoy me now!!
                    InferencingAgain.wmv
                    Just Curious...
                    • utilerU
                      utiler
                      And just tried a new model with nothing in it....
                      Can't find the red axis.
                      InferencingInACleamModel.wmv
                      Just Curious...
                      • Wo3DanW
                        Wo3Dan
                        Just tested a model similar to the one in your file, feb 13.
                        With the camera position you presented I could find R, G and B axes in FOV less than 10 deg upto 120 degrees. No problem here.
                        The blind spot that seems to only appear on my laptop decreases with a larger FOV.
                        Weird.
                        • 2 / 2
