    MSPhysics 1.0.3 (16 October 2017)
    927 Posts 171 Posters 1.1m Views 172 Watching
    • luckyvacL Offline
      luckyvac
      Hello Anton,
      Thank you for your reply. I will need more knowledge to carry out my project.
      I am guitarist and I teach guitar accompanying songs.
      This project aims to realize a tutorial to learn how to play the accompanying guitar and to show that one can realize accompaniments guitar with 5 or 6 rhythmic figures.
      http://www.luckyanimationspectacle.com/index.asp?pageid=33
      I used MSPhysics to simulate the movement of the arm and hand of a guitarist holding a pick.
        He accompanies guitar with a song following the rhythm 1-2-345et.
      Fig.01 As an attachment. pierrot robo guitar
      I used 2 servomotors:
      • one for the forearm which operates the up and down of the forearm.
      • a second for the descent of the hand.
        I made a stop-motion video by adjusting the two actuators point by point according to the following diagram:
        Fig.02 As an attachment 1-2-345et
      I would like to replace the slider by time functions, point by point (FIG. 2) or FFT.
      The displacement coordinates of the servomotors are shown in the table in figure 02.
      You will find the simulation with the <FOREARM> (avant bras ) and <HAND> (main ) slider in my drive and an example video. I chose the refrain of Bob Dylan's "blowin in the wind".
      Here is the link :
      https://drive.google.com/open?id=0B00m7nJr8D_qTnRXX3AyeWVyZmc
      The video tutorial shows the synchronized movement with a rhythmic tablature made with Guitar Pro MIDI (*.gpx, *.mid ). There is no human, just my voice 😉.
      I thank you for your attention and information you can communicate to me to help me realize my project.
      Best regards
      jean-luc alias luckyvac... lucky guitaR
        TheSniper
        Anton Awesome Plugin Thanks for the hard work!
        I add And not to complain but hopefully to help.
        Platform: Sketchup 2017 on Mac 64 bit
        Known issues: 1 setting dont get saved in multiple areas for instance in the Joint and Piston Settings: Max and Min wont save always defaults back to -393.7007874, as well as the controller line resets back to default values. Controller name wont transfer over either. In the Servo panel: cannot save custom servo names, Plus Servo Max and MIn wont save either. Just some examples. Hope it helps. -S
          SynSuka3D
          Hello
          Problem of direction axes
          Xbox Controller
          Joystick 🙂 righty) is X-XAXIS position on right stick.???
          Joystick 🙂 rightx) is axes button LT.????
          No axes Y-XAXIS right stick.???
          please.
          • luckyvacL Offline
            luckyvac
            Great thanks Anton, I wait peacefully while working on other rhythm guitar. 😄
            • luckyvacL Offline
              luckyvac
              Hello, I would like to know how to increase the damping of the servo motor. Thank you 😄
                Anton_S
                Hi, Luckyvac,
                Which of the joints are you referring to, a servo or a motor?
                To increase the damping of a motor joint, simply select the desired motor joint, open MSPhysics UI, and increase the Damp parameter.
                To increase the damping of a servo joint, that is decrease its angular rate, select the desired servo joint, open MSPhysics UI, and decrease the Angular Rate parameter.
                Hope this helps,
                Anton
                  Anton_S
                  @luckyvac My appologies for not responding any sooner. I am a bit busy. In short, it's possible to have the servo angle correspond to the table values at time t. The table with angles and times must be converted to a Ruby Hash and then the rest is easy. I will examine your model in depth soon and we'll see what can be done to get the guitar stringing.
                  @TheSniper Apparently there were a few reports about the dialog options not working properly on Mac OS X and that's not good. I will check it out soon.
                  @SynSuka3D The joystick function accepts four symbols and each of them correspond to an axis on one of the joysticks:
                  joystick(:leftx) returns X position on left stick.
                  joystick(:lefty) returns Y position on left stick.
                  joystick(:rightx) returns X position on right stick.
                  joystick(:righty) returns Y position on right stick.
                  The position ranges from -1.0 to 1.0.
                  Here is the documentation link to the function: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/MSPhysics/CommonContext#joystick-instance_method
                  I suggest you explore the MSPhysics scripting documentation for specs and other functions that might be useful, such as joybutton(button).
                  • luckyvacL Offline
                    luckyvac
                    Hi Anton,
                    Thank you for your advice it works ... but ... I send you the left hand of the guitarist named "Pierrot".
                    I feel that the system comes into resonance when I connect several servo motors to each other.
                    What do you think ? How to decrease the resonance ?
                    Merci 😉
                    have a nice week end. 👍
                    Lucky guitaR
                    main gauche MOV 03.skp
                      Anton_S
                      @SynSuka3D Interesting, I will fix this.
                        SynSuka3D
                        https://youtu.be/b0YBVqUhMdU xbox controller faill script ?
                          SynSuka3D
                          Add joystick(:rightz) and joystick(:leftz) for joy(RT) and joy(LT) please.
                          for xbox controler.
                            Anton_S
                            for xbox controler.
                            Roger that!
                              Anton_S
                              Hi, SynSuka3D,
                              I fixed it and added rightz/leftx commands.
                              You can download the WIP version here: https://drive.google.com/open?id=0B3qg8f4WrNdHUmE5OXNiWjQ0Vzg
                              You can try out the joystick controller test model attached below.
                              Best regards,
                              Anton
                              Joystick.skp
                              • F Offline
                                faust07
                                Should make my question more precise:
                                The reason for the loose behaviour of the joints is the update rate in MSPhysics UI - Simulation - Update Rate = 1 (seems the best for my large model).
                                If I change this from 1 to 3, the servos remain more stable in the pivot but the spring no longer brings the steady up and down movement.
                                Have now tried to modify all settings at the Spring Joint, but do not get the desired result.
                                What can I do?
                                Thank you in advance, Anton!
                                Update Rate 1
                                Update Rate 3
                                Servo-Spring-Test
                                • luckyvacL Offline
                                  luckyvac
                                  Hi Anton and the community,
                                  I think I have found the solution to control the damping of the servo motor. I worked on the geometry of "green" parts to decrease the sensitivity to the vibratory modes. As we can do in reality.
                                  It's impressive !
                                  Best regards. 😄
                                  luckyvac
                                  • F Offline
                                    faust07
                                    Unfortunately, changing the Update Rate from 1 to 3 is not useful when camera, joints, emitter, etc. are based on scripts that use the OnUpdate function. Programmed objects become 3 times faster. The appearance of emitted objects no longer fits to the image rate. The weight of the emitted objects or the lifetime seems to change.
                                    For the joints based on pivot points, an option independent of the Update Rate in the user interface seems to be useful for fixing at the pivot point. If this is possible...
                                      SynSuka3D
                                      @Anton_S goood xbox controller Merci!
                                        SynSuka3D
                                        @Anton_S
                                        @body.set_omega([Internal body axis , 0, axes in global space]) ???
                                        ex:
                                        *onStart{
                                        @body = simulation.find_body_by_name('body')
                                        onUpdate{
                                        r_body = @body.get_matrix
                                        ax = Geom::Vector3d.new([key('up'), 0, 0]).transform(r_body)
                                        @body.set_omega([ax.x, 0, key('right')])
                                          TheSniper
                                          Anton,
                                          Got the update, (Thank you) I have not gone thru all the settings as of yet. But so far it appears to working as expected. Ill let you know as soon as I can get thru all the settings THANKS! -S
                                            Anton_S
                                            SynSuka3d, like I said, you should reference the scripting documentation to see what each function does: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/MSPhysics/Body#set_omega-instance_method
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 46
                                            • 47
                                            • 28 / 47
