    Missing lines in pdf
    9 Posts 4 Posters 514 Views 4 Watching
    • john2J Offline
      john2
      I am trying to export model as pdf with colour by layer option. I am getting missing lines in pdf. I tried turning on and off the hardware acceleration but failed to get the appropriate result.
      I tried again in 2017 version and was disappointed again.
      What must I do to get the lines in the pdf?
      This is the jpeg export of the result that I want.
      This is the jpeg of the pdf export
      VECTOR SHADOW PRACTICE.skp
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • bazB Offline
        baz
        FYI. Just checked your file with SU17. Same result.
          Deleted the faces in the shadow outlines and it worked for me.
            Charlie__V
            You have overlapping faces which is the cause of the missing lines. (Z-fighting)
            Also, you have geometry on layers other than zero, this will always cause problems in SU. (always has)
            Better to keep all geometry on layer zero and put groups/components on layers other than zero to control visibility or in this case color by layer.
            Dave Beat me to it....... πŸ‘
            .pdf with missing lines
            Overlapped faces & Geometry on other than Layer Zero .skp V7
            • bazB Offline
              baz
              Aha, learning, still learning...
              • john2J Offline
                john2
                I always thought that keeping everything on different layer is an organized way! I mean a rectangle group with its geometry on layer "green rectangle" and also the group within the same layer. I was living in a lie! Whoa! I will follow this golden rule that you've given me! Thanks a lot!
                • john2J Offline
                  john2
                  @dave r said:
                  [attachment=0:31wjp3iy]<!-- ia0 -->Screenshot - 2_10_2017 , 6_46_12 AM.png<!-- ia0 -->[/attachment:31wjp3iy]
                  That's a cool maneuver!
                  Please provide some links of pages that will enlighten me more about this basic common sense on geometry conflict. I've been using SketchUp for more than 8 years and still sometimes feel a newbie.
                  I'm aware of Z-fighting of faces.
                    I don't know of any links. It's just experience.
                    • john2J Offline
                      john2
                      Reminds me of an Indian proverb."Talking to a wise man is far better than reading thousand books."
