VCB and Shortcut Keys
@driven said:
Hi Joe,
your script partially works on mac withto_fadded @ line 4.Interesting John. On my Windows PC I modified the script as follows:
<span class="syntaxdefault">def onUserText</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">text</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> view</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> puts</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Text is a #{text.class} class."</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> begin<br /> value </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> text</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l<br /> puts</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Value is a #{value.class} class."</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> rescue<br /> </span><span class="syntaxcomment"># Error parsing the text<br /></span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">beep<br /> puts </span><span class="syntaxstring">"Cannot convert #{text} to a Length"<br /></span><span class="syntaxdefault"> value </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil<br /> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text </span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> SB_VCB_VALUE<br /> end<br /> return if </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">value<br /> if </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">state </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 1 and </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">stick_pt2</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">valid</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault"> build_story_stick</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> value</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> new_stick<br /> end<br /> end</span>and get the following puts to the console. No complaints of coercing String to Length.
Text is a String class.
Value is a Length class.But your code is clearly more correct and you may have saved me a Mac bug. Very interesting that it works on the PC but not the Mac.
Whoops! Let me correct myself. SketchUp has a String def called to_l so the you don't need the to_f. Are you sure it doesn't work without the to_f?
with your original code, I get
Cannot convert 1w to a Length
if I change only this linevalue = text.to_f.to_l #just to do somethingI get 1w in the message box...
with your last code I get an empty message box, with or without the
.to_fjohn
Ya gotta love it! The following works just fine on the Mac, even though h is the shortcut for the pan tool, but fails on Windows by switching to pan.
<span class="syntaxdefault"></span><span class="syntaxkeyword">class </span><span class="syntaxdefault">MyTool<br /> def onUserText</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">rawtext</span><span class="syntaxkeyword">, </span><span class="syntaxdefault">view</span><span class="syntaxkeyword">)<br /> </span><span class="syntaxdefault">begin<br /> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"VCB held #{rawtext}"</span><span class="syntaxkeyword">) </span><span class="syntaxcomment"># show the raw input<br /> </span><span class="syntaxkeyword">if(</span><span class="syntaxdefault">rawtext</span><span class="syntaxkeyword">[-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">chr </span><span class="syntaxkeyword">=~ /[</span><span class="syntaxdefault">wh</span><span class="syntaxkeyword">]/) </span><span class="syntaxcomment">#trap and strip key characters if present<br /> </span><span class="syntaxdefault">key </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">rawtext</span><span class="syntaxkeyword">[-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">chr<br /> text </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">rawtext</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">chop</span><span class="syntaxkeyword">!<br /> else<br /> </span><span class="syntaxdefault">text </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">rawtext<br /> end<br /> value </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">text</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l </span><span class="syntaxcomment">#see if text is convertible to a length<br /> </span><span class="syntaxdefault">rescue<br /> </span><span class="syntaxcomment"># can't process the VCB input. This could be because the trailing character<br /> # isn't one of the key characters or because the text isn't a number<br /> </span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">beep<br /> puts </span><span class="syntaxstring">"Cannot convert #{rawtext} to Length with optional key"<br /> </span><span class="syntaxdefault">value </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">nil<br /> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">set_status_text </span><span class="syntaxstring">""</span><span class="syntaxkeyword">, </span><span class="syntaxdefault">SB_VCB_VALUE<br /> end<br /> </span><span class="syntaxkeyword">return if !</span><span class="syntaxdefault">value<br /> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Got value = #{value}, key = #{key}"</span><span class="syntaxkeyword">)<br /> </span><span class="syntaxdefault">end<br />end<br />Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool</span><span class="syntaxkeyword">( </span><span class="syntaxdefault">MyTool</span><span class="syntaxkeyword">.new ) </span><span class="syntaxdefault"></span>Steve
Why not take your normal 'numbers' text as your lengths, and then use key-down checks for toggling what it means ?
Like Cmd/Ctrl, Shift etc *** - so on one press of that key it expects one type of value [shown in status-bar] on the next press it's something else = i.e. it's a 'toggle'.***You can use TAB key action as a toggle BUT it must be key-up as the MAC doesn't recognize tab-down - only tab-up !
Hi TIG,
That is exactly what I will end up doing in my tool. So as far as I am concerned I have a solution to the problem I raised, thanks to the folks like you who responded to my original question.
However, I think the bigger issue here is that there are scripts in this thread that work on the Mac and not the PC, and scripts that work on the PC and not the Mac. Apparently the Mac is not aware of the String class to_l method and the PC doesn't handle the h shortcut key correctly. Although I would argue that the PC is handling the h shortcut key the way I would like it to and the PC and Mac are handling shortcut keys when they shouldn't be if the VCB is active for user input.
I for one just wish that release 2013 spent more time on bug fixes, platform inconsistencies and Ruby API maintenance than it did on icon changes which are driving me nuts and causing me a lot of work.
But again, thank you and the others who helped me on this issue.
.to_fjohn
What should "1w" represent?
additional observation:
If onKeyDown or onKeyUp returns true then onCancel is not triggered. It is blocked by onKeyDown/onKeyUp as well.
