    Final Documentation for BakeHouse Distillery
    27 Posts 14 Posters 2.8k Views 14 Watching
    • cottyC Offline
      cotty
      A real Richard!
      Great (again)!
      my SketchUp gallery
      • andybotA Offline
        andybot
        Beautiful work, great job!
        • pbacotP Offline
          Masterpiece of presentation and documentation! Congratulations!
          • tademaT Offline
            tadema
            Hello Richard, nothing I can say that has not already been said above. Clients often fail to realise the amount of work goes into these type of presentations. Beautiful πŸ‘ πŸ‘ πŸ‘
            John
            • RichardR Offline
              Richard
              @hornoxx said:
              Actually I'm speechless but, as you see, obviously not πŸ˜„ πŸ˜‰ πŸ˜„
              Long before I think about presented contents, As allways, I'll stick to your outstanding good graphic language. Reduced to white-gray-black, combined with a clear color coding using mainly orange as a matching contrast color for your there pointed(?) references. This "language" you hold through all the plans and everything, from start to end, is from one single font πŸ‘ πŸ‘
              Since this entire facility is probably too far away from the road to be seen from there, it is a good idea carefully to appreciate the driveway(?) with itΒ΄s own special design.
              Especially I love the "simplicity" to produce plasticity by the use of shadows (are the shadows made by layer syles PS?). In the plan "Landscape Principles" this effect is nice to look at, since this works very playfully, without any strictness.
              Thank you SO MUCH for the praise mate!!!!!! πŸ‘
              To answer your question:
              @hornoxx said:
              Especially I love the "simplicity" to produce plasticity by the use of shadows (are the shadows made by layer styles PS?).
              To keep the whole page sharp and text legible I've used Indesign to get the shadow effects for the trees. Everything on the page was compiled in Layout and exported as a layer enabled PDF.
              The trees are on 3 separate layers within that PDF. Within Indesign the PDF is dragged onto a page, all tree layers turned off so all background elements only are displayed, this is then copied > pasted in place and just level one trees enabled and shadow cast added > pasted in place again and just level two trees enabled and shadow cast added > and again for level three trees. The whole document then exported out as a PDF.
              The result is much cleaner and lighter (file size) wise as kept as vectors.
              Again, big thanks mate!
              BUILTBRAND.COM.AU
              • RichardR Offline
                Richard
                @jo-ke said:
                HornOxx ist totally right.
                Outstanding as always. Beautyfull presentation
                Thanks mate, I'm hoping the Council assessing the application for it clear and legible!
                BUILTBRAND.COM.AU
                • RichardR Offline
                  Richard
                  @kaas said:
                  Great assignment, great design, great presentation... Great job!
                  Thank you my man! Seriously fun design job, certainly a lot of time spent fully considering all aspects to get what I hope will be a successful venture. And keep me stocked with Gin!!!
                  BUILTBRAND.COM.AU
                  • RichardR Offline
                    Richard
                    @cotty said:
                    A real Richard!
                    Great (again)!
                    Cheers mate! I'm now hoping for an approval so I can jump onto some marketing work to promote the final product!
                    BUILTBRAND.COM.AU
                    • RichardR Offline
                      Richard
                      Thanks mate! Its been a big job, just writing the report took weeks of research and writing itself!
                      BUILTBRAND.COM.AU
                      • RichardR Offline
                        Richard
                        Thank you as always kind sir!!!!! πŸ‘
                        BUILTBRAND.COM.AU
                        • RichardR Offline
                          Richard
                          John
                          Luckily in this case mate the client has been so involved with the whole design and documentation he is rather struck by the work that has gone into it!
                          And luckily for all of US here, the tools at our disposal are well up to the task of producing great stuff!!!
                          BUILTBRAND.COM.AU
                          • cheddaC Offline
                            chedda
                            A comprehensive submission, very easy to read and understand.
                            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                            • RichardR Offline
                              Richard
                              Thank you ma man!!!!
                              BUILTBRAND.COM.AU
                              • marked001M Offline
                                marked001
                                These are awesome, richard. I am in love with that first landscape plan.
                                http://www.revision21vis.com
                                instagram: revi21on
                                • RichardR Offline
                                  Richard
                                  Cheers mate! I particularly like the method to convey the site's slope. Its just the contours chopped up and joined to create an object. Then given all the same fill and then transparency dropped by 5% for each object.
                                  BUILTBRAND.COM.AU
                                    Very fine as always! 😎
                                    Have you try the Affinity serial programs who seems have a very agressive price against Adobe ones?
                                    • RichardR Offline
                                      Richard
                                      Thanks weirdo French mate! I haven't checked out affinity! I will!!! πŸ‘ Though as always, we have to equate time to learn something new against the hours we save in already knowing something!
                                      Hop life is treating you well old mate! x Rich!
                                      BUILTBRAND.COM.AU
                                      • Bryan KB Offline
                                        What they said.
                                        Fantastic work.
                                          Glenn at home
                                          Simply outstanding presentation and design. Thanks for sharing.
                                          • DanielD Offline
                                            Daniel
                                            Beautifully done job all around, Richard.
                                            My avatar is an anachronism.
