    Final Documentation for BakeHouse Distillery
    27 Posts 14 Posters 3.4k Views 14 Watching
    • RichardR Offline
      Richard
      @hornoxx said:
      Actually I'm speechless but, as you see, obviously not πŸ˜„ πŸ˜‰ πŸ˜„
      Long before I think about presented contents, As allways, I'll stick to your outstanding good graphic language. Reduced to white-gray-black, combined with a clear color coding using mainly orange as a matching contrast color for your there pointed(?) references. This "language" you hold through all the plans and everything, from start to end, is from one single font πŸ‘ πŸ‘
      Since this entire facility is probably too far away from the road to be seen from there, it is a good idea carefully to appreciate the driveway(?) with itΒ΄s own special design.
      Especially I love the "simplicity" to produce plasticity by the use of shadows (are the shadows made by layer syles PS?). In the plan "Landscape Principles" this effect is nice to look at, since this works very playfully, without any strictness.
      Thank you SO MUCH for the praise mate!!!!!! πŸ‘
      To answer your question:
      @hornoxx said:
      Especially I love the "simplicity" to produce plasticity by the use of shadows (are the shadows made by layer styles PS?).
      To keep the whole page sharp and text legible I've used Indesign to get the shadow effects for the trees. Everything on the page was compiled in Layout and exported as a layer enabled PDF.
      The trees are on 3 separate layers within that PDF. Within Indesign the PDF is dragged onto a page, all tree layers turned off so all background elements only are displayed, this is then copied > pasted in place and just level one trees enabled and shadow cast added > pasted in place again and just level two trees enabled and shadow cast added > and again for level three trees. The whole document then exported out as a PDF.
      The result is much cleaner and lighter (file size) wise as kept as vectors.
      Again, big thanks mate!
      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
      • RichardR Offline
        Richard
        @jo-ke said:
        HornOxx ist totally right.
        Outstanding as always. Beautyfull presentation
        Thanks mate, I'm hoping the Council assessing the application for it clear and legible!
        • RichardR Offline
          Richard
          @kaas said:
          Great assignment, great design, great presentation... Great job!
          Thank you my man! Seriously fun design job, certainly a lot of time spent fully considering all aspects to get what I hope will be a successful venture. And keep me stocked with Gin!!!
          • RichardR Offline
            Richard
            @cotty said:
            A real Richard!
            Great (again)!
            Cheers mate! I'm now hoping for an approval so I can jump onto some marketing work to promote the final product!
            • RichardR Offline
              Richard
              @andybot said:
              Beautiful work, great job!
              Thanks mate! Its been a big job, just writing the report took weeks of research and writing itself!
              • RichardR Offline
                Richard
                @pbacot said:
                Masterpiece of presentation and documentation! Congratulations!
                Thank you as always kind sir!!!!! πŸ‘
                • RichardR Offline
                  Richard
                  @tadema said:
                  Hello Richard, nothing I can say that has not already been said above. Clients often fail to realise the amount of work goes into these type of presentations. Beautiful πŸ‘ πŸ‘ πŸ‘
                  John
                  Luckily in this case mate the client has been so involved with the whole design and documentation he is rather struck by the work that has gone into it!
                  And luckily for all of US here, the tools at our disposal are well up to the task of producing great stuff!!!
                  • cheddaC Offline
                    chedda
                    A comprehensive submission, very easy to read and understand.
                    Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                    • RichardR Offline
                      Richard
                      Thank you ma man!!!!
                      • marked001M Offline
                        marked001
                        These are awesome, richard. I am in love with that first landscape plan.
                        http://www.revision21vis.com
                        instagram: revi21on
                        • RichardR Offline
                          Richard
                          Cheers mate! I particularly like the method to convey the site's slope. Its just the contours chopped up and joined to create an object. Then given all the same fill and then transparency dropped by 5% for each object.
                            Very fine as always! 😎
                            Have you try the Affinity serial programs who seems have a very agressive price against Adobe ones?
                            • RichardR Offline
                              Richard
                              Thanks weirdo French mate! I haven't checked out affinity! I will!!! πŸ‘ Though as always, we have to equate time to learn something new against the hours we save in already knowing something!
                              Hop life is treating you well old mate! x Rich!
                              • Bryan KB Offline
                                What they said.
                                Fantastic work.
                                  Glenn at home
                                  Simply outstanding presentation and design. Thanks for sharing.
                                  • DanielD Offline
                                    Daniel
                                    Beautifully done job all around, Richard.
                                    My avatar is an anachronism.
                                    • RichardR Offline
                                      Richard
                                      What they said.
                                      Fantastic work.
                                      You're always one to tune in, thanks mate!
                                      • RichardR Offline
                                        Richard
                                        You're welcome mate, hope someone gets inspiration as I do from many others!
                                        • RichardR Offline
                                          Richard
                                          Thanks Daniel, an easy job to get engaged with, and want to do well!
