    Could use some help with a material
    5 Posts 2 Posters 356 Views 2 Watching
      mwm5053
      In the picture the driveway has a semicircle brick pattern to it. Right now I'm using a herringbone brick pattern but would like to make it more like the picture so what's the best way do that. A circular pattern for it or use a UV mapping plugin to show the semicircle pattern to it.
      Thanks Walt
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Just use ThruPaint to map the texture...
        Click to play
        Play around with the scaling to get what you want
          mwm5053
          I've been wanting to learn to use that plugin, now's a good time as any
          Thanks Rich
          2011 iMac
          V2 Twilight
            mwm5053
            Had some time today to try Rich's advice but not coming out with same results. The 2 bottom right and left faces aren't UV mapped correctly not sure why perhaps I missed a step.
            2011 iMac
            V2 Twilight
              mwm5053
              Well it's better, I think I may still have to play around with ThruPaint some more.
              2011 iMac
              V2 Twilight
