    3D Truss Models
    1.5k Posts 32 Posters 1.7m Views 31 Watching
    • medeekM Offline
      medeek
      @Juju
      I like what you have proposed here. What I will do is add a new section in the global settings called "Ceilings" that enables one to enable a gypsum wall board layer and/or battens. The thickness and sizes can also be set here as well (which become the default values) but the pop-up menu for ceiling - advanced options will allow for manual entry of each item and will also override the default values with the last values selected.
      If its not too much I will probably also specify two additional layers:
      ceiling_gypsum or ceiling_sheathing?
      ceiling_batten
      What is the typical size for ceiling battens in your locale? and the o/c spacing?
      Also with a roof plane/extrusion, I see the necessity with having this addition when one uses battens but what about when there is already a sheathing layer on the roof and no battens?
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I didn't particularly like the shade of the plywood material that is standard with SketchUp, so I went looking for a better texture. I think I've found one that I like but would be happy to entertain others if someone has a certain plywood material texture that they like.
        design.medeek.com
        • medeekM Offline
          medeek
          I've got the plywood material working quite well in the plugin, and the ability to toggle between it and OSB in the global settings. I have a few more other features and edits and then maybe I will role a revision tomorrow or Sunday.
          http://design.medeek.com/resources/images/truss_su183_800.jpg
          I actually like the plywood look much better than the OSB.
          design.medeek.com
          • medeekM Offline
            medeek
            OSB or Plywood will now be an option for the floor sheathing:
            http://design.medeek.com/resources/images/truss_su184_800.jpg
            The new sheathing tab in the global settings:
            http://design.medeek.com/resources/images/truss_su185_800.jpg
            As time goes on I will probably add in more options for wall cladding and interior wall cladding (ie. gypsum) as well as the ceiling logic I discussed in a previous post.
            I'm now working on the gable end wall sheathing option and the roof cladding option.
            There are also two new options in the "General" tab which allow one to toggle the default setting for gable end trusses and advanced options (roof, floor etc...).
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.8.0- 01.22.2017
              • Enabled roof cladding for common trusses.
              • Added nine "IKO Cambridge" architectural shingle colors into the roof cladding material library.
              • Added "plywood" material for roof and floor sheathing.
              • Added a "Sheathing" tab into the global settings.
              • Added entries in the "General" tab of the global settings to toggle default settings for gable end trusses and advanced options.
              http://design.medeek.com/resources/images/truss_su186_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              Initially I was just going to texture the exterior face of the sheathing for the roof cladding but then I realized that there may be cases where there is roof cladding but not sheathing or vice versa. In the end I went with a separate layer, material and extrusion for the roof cladding, this allows one to get more granular with the structure and in my mind closer to reality.
              design.medeek.com
              • medeekM Offline
                medeek
                Trying to find a good wood shake or shingle roof texture, this one is pretty good except for a bit of banding:
                http://design.medeek.com/resources/images/truss_su187_800.jpg
                Slipped in a wood shingle roof texture and a few metal ones in to Version 1.8.0.
                I set the exposure of the wood shingles at 5-1/2", however it does look a little small to me, maybe 7-1/4" would be better?
                design.medeek.com
                • medeekM Offline
                  medeek
                  When you first install the plugin the layers, materials and connector plates are disabled or turned off by default, maybe it would be better that they all be turned on. Either way all of these items can now be customized in the global settings.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I am wondering why SketchUp doesn't automatically ship with more high quality textures? This seems like a no-brainer.
                    design.medeek.com
                    • jujuJ Offline
                      juju
                      Yup, you know it. I recently experienced a situation where people are starting to create rendering engine textures using 4K and higher images, this was over at Indigo Renderer. Crazy stuff but probably in the not-so-distant future normal.
                      • medeekM Offline
                        medeek
                        And even if the quality is not so great a few more textures (built in) would be nice. I'm just surprised that there is not more built in textures for roof and siding materials. There should be at least 50-100 such textures (roof and siding specific) built in with SketchUp, or so I would think. This sort of thing could only help SketchUp's marketshare and adoption by serious architects and designers.
                        design.medeek.com
                        • jujuJ Offline
                          juju
                          Yes, more (and better) out-of-the-box textures will be great. However once "serious" professionals start using this for more than just conceptual study modeling, they generally get professional texture packs or collect / make their own.
                          • medeekM Offline
                            medeek
                            Thinking about sheathing and cladding advanced option for the valley truss set. Typically the valley truss set is placed on top of the main roof sheathing:
                            http://design.medeek.com/resources/images/truss_su188_800.jpg
                            View model here:
                            3D Warehouse
                            If I create the sheathing and cladding just right then it will be easy for the user to manually trim the secondary roof sheathing and cladding with my trim tool and then optionally union them up with the built in Union tool. I may need to make a video showing exactly how to perform this task.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              The valley truss set now has sheathing and cladding added as an option. You still have to manually trim the secondary roof's sheathing and cladding and then union it to the valley set's but with the trim tool this is very simple to do:
                              http://design.medeek.com/resources/images/truss_su189_800.jpg
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Call me crazy but I want to build something like this on my 10 acres so I can see all the way to the beach.
                                  https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=9b90c2ad-90af-452d-a3e7-2253ec8fa11c
                                  Given my wind speed (155mph ult.) and seismic zone (D2) I am probably looking at some serious holdowns at the first level (HDU 11). I would have to run the numbers but it would probably work. I would probably also sheath it with 5/8" plywood inside and out for some serious shearwall action, at least on the the first two floors. I would probably also frame the first two floor with DF No.2 2x8 studs or 2x6 studs at 12" o/c. I'm thinking spiral staircases between levels to save as much floor space as possible and to make it more interesting. Minimal windows on the first three levels and then the top level would have a lot of windows for the view. 11-7/8 TJI 210 for the floors with 3/4 sheathing T&G, 16" o/c.
                                  The structure is 16'x16' with grade to top plate height of 38'8".
                                  The roof is 6:12 pyramid hip with 2x8 rafters, I may go with a steeper pitch though.
                                  On a structure like this overturning is a serious threat, I would need to check the dead weight of the structure and see if the seismic or wind forces could potentially lift the foundation right out of the ground. The solution is to increase the dead weight of the structure especially at the base, by upsizing the footing and stemwall. You will notice my stemwall is 10" thick, 36" deep and a 24"x12" footing, even this may not be enough.
                                  Anyone design something goofy like this before. I don't know if my county building dept. would give it an approval though even if its engineered (stamped).
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Since I have now have roof cladding enabled I figured it only made sense to have some sort of wall cladding enabled for the gable end walls:
                                    http://design.medeek.com/resources/images/truss_su190_800.jpg
                                    The advanced options now allow one to specify wall cladding, the settings can be adjusted in the "sheathing" tab of the global settings. I currently only have 4 different colors of Hardiplank Siding but I will add more as requested and I can find textures that I like or create. It should also be noted that it isn't too hard to swap out the texture for the user's custom textures.
                                    I'm also thinking about adding an option for an air gap between the wall sheathing and the wall cladding in the case that someone wants to use brick as their cladding option. For standard veneer brick in the US the air gap is usually 1" if my recollection is correct.
                                    I will try to roll these latest additions into a new revision here shortly.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.8.1 - 01.29.2017
                                      • Enabled gable wall cladding for common trusses.
                                      • Added four "HARDIPLANK Cedarmill" siding colors into the wall cladding material library.
                                      • Enabled sheathing and cladding for valley truss sets.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Here is a simple structure created with the Truss and Foundation Plugins along with Housebuilder:
                                        I like Housebuilder but I really feel like I need to develop my own Wall Plugin since it will tie in better with my Truss Plugin and allow the user to create the different sheathing and cladding options on the same layers.
                                        Creation of the foundation and roof both took less than 30 seconds to create. The walls, windows and doors did require manual editing. I also realized that it would be useful to allow the option for wrapping the floor framing in wall sheathing and cladding so that this can be unioned with the appropriate sheathing and cladding on the walls above. I will add this into the Todo list.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          So far I have not really had the opportunity to use my own plugin on a real job, other than some minor conceptual structural models.
                                          Last night I had the opportunity to model a garage/office as part of a real world study for a building design.
                                          https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=a99a3be2-36a1-44a0-9f6c-ce635f18a0a0
                                          This further re-emphasized how much I need to put together my own Wall Plugin, something I might seriously wade into this weekend.
                                          View model here:
                                          3D Warehouse
                                          Its 25Mb because of the vehicles I inserted from the 3D Warehouse, it would be nice to have more lightweight test vehicles to use as space fillers and sizers, does anyone have any suggestions?
                                          design.medeek.com
                                          • facerF Offline
                                            facer
                                            Medeek,
                                            Plugin in is coming along!
                                            Is polygon slabs available?
                                            Thanks for your dedication to a unique plugin.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 76
                                            • 77
                                            • 31 / 77
