    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Fixed a small bug in the valley truss set, hence the revision 1.7.8b. Hopefully tonight I can attack the timber truss module, I think I have most of the pseudo code put together.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • G
        Garry K
        My stair maker plugin creates straight and curved stairs. Also Spirals.
        I am intending on adding quarter and half landings and some other features.
        I have built more than 200 of these geometric stairs including elliptical, specialty winders etc.
        We also specialized in framed up curved stairs without the cost of stringers.
        Some of my stairs projects include providing the bending forms and flattened stringers.
        • medeekM
          medeek
          Spent some time this morning traversing through the common truss code updating some of the truss types so that I can enable energy/raised heels for all common trusses as well as enable custom layers, materials and connector plates.
          As I've developed the plugin and added new features I used the fink truss as the cutting edge, so everything having to do with this truss type is pretty much up-to-date, however some of the other truss types are seriously lagging so a little house cleaning is in order.
          It may be a few days before I can release this latest version since there is a lot of tedious work ahead.
          design.medeek.com
          • pbacotP
            Great work. I wish I had your dedication!
            • medeekM
              medeek
              I will download your stair plugin and give it a go.
              That whole spiral staircase thing looks like a real challenge to code, don't even want to go there.
              design.medeek.com
              • medeekM
                medeek
                Raised/Energy heels add another level of complexity to the equation. Below you can see that various heights of a raised heel on a simple King Post truss requires different configurations and hence separate plating routines:
                http://design.medeek.com/resources/images/truss_su177_800.jpg
                This also affects the gable trusses as well, below is a fink truss with its gable counterpart:
                http://design.medeek.com/resources/images/truss_su178_800.jpg
                View models here:
                https://3dwarehouse.sketchup.com/model.html?id=91d8d78a-8e6c-4dab-9839-4d689c84c297
                https://3dwarehouse.sketchup.com/model.html?id=89739563-049f-4277-bfca-75663724967e
                I'm still house cleaning. I've now got the King Post, Fink and Howe truss fully cleaned up with connector plates enabled for all possible configurations (raised heel, non-raised heel, structural, non-structural). I've only got 9 more common truss types to work through, see list below:
                Queen Post
                Fan
                Mod Queen
                Double Fink
                Double Howe
                Mod Fan
                Triple Fink
                Triple Howe
                Quad Fink
                design.medeek.com
                • medeekM
                  medeek
                  Raised Heel Howe Truss:
                  http://design.medeek.com/resources/images/truss_su179_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.7.9 - 01.15.2017
                    -Enabled metal plate connectors, materials and custom layers for king post, howe and queen post trusses.
                    • Added energy/raised heels for queen post truss (3 variants: wedge, slider and vertical w/ strut).
                    • Added energy/raised heels for howe truss (3 variants: wedge, slider and vertical w/ strut).
                    • Metal plate connectors now enabled for king post, queen post, fink and howe raised heel/energy trusses.
                    design.medeek.com
                    • medeekM
                      medeek
                      I'm still investigating "real world" applications of the plugin to determine where the weakness and deficiencies are. Here is an example combining a dutch gable rafter roof with some raised heel trusses. Now that the raised heel feature is fully active for many of the common trusses it is actually quite easy to measure and then match the heel height of the rafters.
                      https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=cc8bdb7c-d8a4-46a7-b9ff-88ac60c6ec07
                      View model here:
                      3D Warehouse
                      (3dwarehouse.sketchup.com)
                      I am interested in how others are actually using the plugin and where it is falling down for you, please feel free to send me models or post on the forum with your "real world" design issues with regards to the plugin. This will help drive future development and prioritize the more important items on the todo list.
                      design.medeek.com
                      • medeekM
                        medeek
                        Raised heel double fink truss with connector plates:
                        http://design.medeek.com/resources/images/truss_su180_800.jpg
                        I added this one today and will roll it into verson 1.7.9b.
                        design.medeek.com
                        • medeekM
                          medeek
                          In the advanced options for common roof trusses I currently have the sheathing option. I am wondering if it might be useful to also enable a gypsum wallboard option for the ceiling, with a global setting that sets the exterior wall thickness (inset) and the gysum thickness:
                          https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=1f8640f7-a620-4542-ad23-3ccdd6ff40b8
                          View model here:
                          3D Warehouse
                          Please chime in if this is something that would have some utility or not.
                          design.medeek.com
                          • jujuJ
                            juju
                            View model here:
                            3D Warehouse
                            That would be useful! Below are some parameters I would appreciate to help speed up the process:
                            • board thickness (manual entry, but remembers the last used value)
                            • offset from walls (manual entry, but remembers the last used value)
                            • Z-offset, to bottom of ceiling, below tie-beam (manual entry, but remembers the last used value)
                            • batten sizing (manual entry, but remembers the last used value)
                            • batten spacing (manual entry, but remembers the last used value)
                            I like the way you pull out all the stops! I gather the above will also comply to your regimen of being able to preselect the layer assignments?
                            Something else (more-or-less in line with your train of thought with the above) that would be great to have, if it could be added as well,0 is the ability to automatically generate an extruded plane (extrusion height manual entry, but remembers the value last used) as the roof material. Generally I model these as a box on top of the purlins/roofing battens as a representation of the roofing material, would be great if there were some automation involved here. 😉
                            • jujuJ
                              juju
                              @medeek said:
                              If its not too much I will probably also specify two additional layers:
                              ceiling_gypsum
                              ceiling_batten
                              Ceilings aren't always made of gypsum board, I think we would need to consider an alternative name there? However, as long as the user is aware, this shouldn't pose a problem even if the naming stays as you proposed.
                              @medeek said:
                              What is the typical size for ceiling battens in your locale?
                              typically 38x38mm and 38x50mm is used, depending on truss spacings
                              @medeek said:
                              Also with a roof plane/extrusion, I see the necessity with having this addition when one uses battens but what about when there is already a sheathing layer on the roof and no battens?
                              I would still consider having the option there. Where I'm from, the typical roof construction does not use sheathing, I think I've used it once ever, with RheinZink as final roof material finish... Maybe some of the other people here can give us some feedback here?
                              • medeekM
                                medeek
                                On a similar note I would also like to create a new section in the global settings for "Sheathing". Here one can select whether sheathing will be an enabled advanced option by default or not and also other default parameters like sheathing thickness (wall and roof separately). My default sheathing material is OSB but in the global settings I will add a toggle between OSB and Plywood.
                                So far I have not dealt with wall sheathing on the gable ends, leaving it to the user to add their own but I would like to make that an option.
                                Also with the roof sheathing I would like make a global setting option of coloring the exterior/top face with a pre-determined roofing material if no other roofing extrusion is present, I've got to think about this some more.
                                My thinking is that the global settings should allow one to setup or customize the plugin so that all of your typical settings are "fine tuned" for you thereby minimizing the effort required when presented with all of the input menus during the roof creation process.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Another item I have been putting off is the heel blocking. I'm planning on offering two variants (vertical and angled), with the option to draw in the ventilation holes (typically 2" in diameter in my region, with 3 holes per 24" o/c spacing) if desired:
                                  http://design.medeek.com/resources/images/truss_su181_800.jpg
                                  Obviously this is not a hot item since no one has bugged me about it but I have not forgotten it, just put it aside up until now.
                                  With raised heels this may become a bit more complicated requiring more options, (ie. a V-cut instead of the typical bird holes). More input from builders would be useful in this regard.
                                  With the angled heel blocking an overhang must be present for this to work so the code will revert to a vertical heel block when not enough overhang is present.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    @Juju
                                    I like what you have proposed here. What I will do is add a new section in the global settings called "Ceilings" that enables one to enable a gypsum wall board layer and/or battens. The thickness and sizes can also be set here as well (which become the default values) but the pop-up menu for ceiling - advanced options will allow for manual entry of each item and will also override the default values with the last values selected.
                                    ceiling_gypsum or ceiling_sheathing?
                                    ceiling_batten
                                    What is the typical size for ceiling battens in your locale? and the o/c spacing?
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      I didn't particularly like the shade of the plywood material that is standard with SketchUp, so I went looking for a better texture. I think I've found one that I like but would be happy to entertain others if someone has a certain plywood material texture that they like.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I've got the plywood material working quite well in the plugin, and the ability to toggle between it and OSB in the global settings. I have a few more other features and edits and then maybe I will role a revision tomorrow or Sunday.
                                        http://design.medeek.com/resources/images/truss_su183_800.jpg
                                        I actually like the plywood look much better than the OSB.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          OSB or Plywood will now be an option for the floor sheathing:
                                          http://design.medeek.com/resources/images/truss_su184_800.jpg
                                          The new sheathing tab in the global settings:
                                          http://design.medeek.com/resources/images/truss_su185_800.jpg
                                          As time goes on I will probably add in more options for wall cladding and interior wall cladding (ie. gypsum) as well as the ceiling logic I discussed in a previous post.
                                          I'm now working on the gable end wall sheathing option and the roof cladding option.
                                          There are also two new options in the "General" tab which allow one to toggle the default setting for gable end trusses and advanced options (roof, floor etc...).
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.8.0- 01.22.2017
                                            • Enabled roof cladding for common trusses.
                                            • Added nine "IKO Cambridge" architectural shingle colors into the roof cladding material library.
                                            • Added "plywood" material for roof and floor sheathing.
                                            • Added a "Sheathing" tab into the global settings.
                                            • Added entries in the "General" tab of the global settings to toggle default settings for gable end trusses and advanced options.
                                            http://design.medeek.com/resources/images/truss_su186_800.jpg
                                            View model here:
                                            3D Warehouse
                                            Initially I was just going to texture the exterior face of the sheathing for the roof cladding but then I realized that there may be cases where there is roof cladding but not sheathing or vice versa. In the end I went with a separate layer, material and extrusion for the roof cladding, this allows one to get more granular with the structure and in my mind closer to reality.
                                            design.medeek.com
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 76
                                            • 77
                                            • 31 / 77
