    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 926.4k Views 172 Watching
    • robintR Offline
      robint
      Hi PP
      some good stuff there, doesnt make the sound?
      take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact
      Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar
      Have tried to use magnetism in UI but doesnt seem to have any effect? 😲
      What am I doing wrong?
      Robin
      mortar 3.skp
      As one door closes another one slams in your face
        PituPhysics
        I made more models to be more opportunities.
        1.) Frozen: mortar 4.1.skp
        2.) Hide: mortar 4.2.skp
        3.) Simulation pause: mortar 4.3.skp
        And magnet test:magnet.skp
        • robintR Offline
          robint
          Hi PP
          tried your magnet and I am baffled as to why its so very slow, <2fps. tried everything to speed it up. Sketchy physic was much faster? I made ther executive balls desktop toy by putting all the balls as pendulums in a frame and colliding. It was fast and realistic?
          Robin
          • robintR Offline
            robint
            Even stranger, I managed to get my balls to clang together at 30 fps, but unable to simulate repulsion even with negative magnet values? I notice that perhaps magnet is a wrong term as it behave more like gravity between two masses (hence no repulsion effect)
            Universal gravitation equation
            F = GMm/R2
            where
            F is the force of attraction between two objects in newtons (N)
            G is the Universal Gravitational Constant = 6.674*10−11 N-m2/kg2
            M and m are the masses of the two objects in kilograms (kg)
            R is the separation in meters (m) between the objects, as measured from their centers of mass
            notice how the ball is attracted to the target even though the target has no magnetic force
            for example
            Robin
            my magnetic balls 1.skp
            • robintR Offline
              robint
              Hi PP
              Got as far as 4.3 and it certainly is the cats whiskers, like the disappering effect in 4.2, all we need is a little pop up explosion (still no sound on mine?)
              I dont understand what is affecting the fps so drastically? It goes from 30fps down to 4 or less
              Robin
              • robintR Offline
                robint
                Playing with real shells. Wonder how I can get the nose pointing along the path? hmmm ❓ notice the fps is 27, yet on some of the models its very slow 2fps
                mortar 5.1.skp
                  PituPhysics
                  For me 63 fps.
                  mortar 5.2.skp
                  • robintR Offline
                    robint
                    Wow PP that has blown me away, havent looked into detail yet, tomorrow am
                    Now could this be mounted on a tank? Forward, left, right track
                    Then we could have two or more, multi players
                    Tank battle, forests, obstacles, terrain, mines, smoke etc
                    Pls assume all rights, I'll be your beta tester and write the manual
                    Robin
                    Ps I wrote a game like this in BASIC years ago, for four players, it was extemely addictive, hidng under tree cover trying to guess where you opponents were. Each tank had a home base corner and had to return for new ammo and fuel. we spent hours on it
                    I turned this into a kids game sliding around on mats on a polished wood floor blindfold, getting coded instruction from their base commanders. They fired foam tennis balls at each other and only had three reserve tanks. Couldn't get them out of the classroom, oh and they had to give their instructions in a foreign language, French German, Italian and swedish - a summer uni job - but the kids loved it
                    Robin
                    • robintR Offline
                      robint
                      Hi PP
                      changed the angle so its a cannon 0 - 80deg azimuth control
                      just gets better 😄
                      mortar 5.3.skp
                      • I Offline
                        INVR
                        I have a little issue where sometimes when I run the sim (simple hinges) it starts scanning and objects seem to disappear. I can control the camera and see them or half of the object. But it gets worse and worst until I have to reset it. Is there any steps I can take to fix this?
                          Anton_S
                          INVR, camera clipping is very like caused by some objects falling down too far away from camera. To fix this, find the objects that fall down non stop and draw a floor below them or set them to ignore if they are not necessary for the simulation. These objects could be hidden groups or hidden layers. So uif you unhinde everything, and run simulation, you should be able to notice which objects do that.
                          • F Offline
                            faust07
                            Testing "export replay to images" in SketchUp 2017.
                            The result is incomplete images with always the same empty white parts..
                            The same happens when using the following line in a MSPhysics script:
                            Sketchup.active_model.active_view.write_image("e;/MSPh_Temp/frame_%06d.png" % frame,1600,900,true,1.0)
                            How should it be right for SUp 2017?
                            • F Offline
                              faust07
                              Hi, Anton. Here I have yet an other question:
                              It would be great if, for example, there would be a mode for the servos to hold the joint exactly at the center of rotation and completely prevent the centrifugal forces and the pulling out of the components involved.
                              In the enclosed example, I have not found any way to keep the outer sections of the wings exactly at the center of rotation of the servos. There always develops a gap between the parts.
                              Have screwed at all settings and nothing was useful.
                              It seems to be a kind of inertia of the outer wing segments, which can not be stopped by reducing weight, gravitation, friction, etc.
                              • luckyvacL Offline
                                luckyvac
                                Hi Anton, is it possible to control the movement of a servo motor with a function of time. An Excel file ? In the command section can replace the slider by a function of time ( ontick ? ). ... thank you very match.
                                  Anton_S
                                  Yes, luckyvac, it is possible to control servo angle through a function of time. There are lots of ways it can be done. One way is to simply write a function into the controller section of the the servo. Say, you want to control the angle of the servo, in degrees, with a function f(t) = t*3 + 150.
                                  Converting it to ruby and MSPhysics, the code would like like this: world.time * 3 + 150. If you paste this snippet into the controller section of a servo, it will have the servo angle be the value of this function at simulation time, t.
                                  • luckyvacL Offline
                                    luckyvac
                                    Hello Anton,
                                    Thank you for your reply. I will need more knowledge to carry out my project.
                                    I am guitarist and I teach guitar accompanying songs.
                                    This project aims to realize a tutorial to learn how to play the accompanying guitar and to show that one can realize accompaniments guitar with 5 or 6 rhythmic figures.
                                    http://www.luckyanimationspectacle.com/index.asp?pageid=33
                                    I used MSPhysics to simulate the movement of the arm and hand of a guitarist holding a pick.
                                      He accompanies guitar with a song following the rhythm 1-2-345et.
                                    Fig.01 As an attachment. pierrot robo guitar
                                    I used 2 servomotors:
                                    • one for the forearm which operates the up and down of the forearm.
                                    • a second for the descent of the hand.
                                      I made a stop-motion video by adjusting the two actuators point by point according to the following diagram:
                                      Fig.02 As an attachment 1-2-345et
                                    I would like to replace the slider by time functions, point by point (FIG. 2) or FFT.
                                    The displacement coordinates of the servomotors are shown in the table in figure 02.
                                    You will find the simulation with the <FOREARM> (avant bras ) and <HAND> (main ) slider in my drive and an example video. I chose the refrain of Bob Dylan's "blowin in the wind".
                                    Here is the link :
                                    https://drive.google.com/open?id=0B00m7nJr8D_qTnRXX3AyeWVyZmc
                                    The video tutorial shows the synchronized movement with a rhythmic tablature made with Guitar Pro MIDI (*.gpx, *.mid ). There is no human, just my voice 😉.
                                    I thank you for your attention and information you can communicate to me to help me realize my project.
                                    Best regards
                                    jean-luc alias luckyvac... lucky guitaR
                                      TheSniper
                                      Anton Awesome Plugin Thanks for the hard work!
                                      I add And not to complain but hopefully to help.
                                      Platform: Sketchup 2017 on Mac 64 bit
                                      Known issues: 1 setting dont get saved in multiple areas for instance in the Joint and Piston Settings: Max and Min wont save always defaults back to -393.7007874, as well as the controller line resets back to default values. Controller name wont transfer over either. In the Servo panel: cannot save custom servo names, Plus Servo Max and MIn wont save either. Just some examples. Hope it helps. -S
                                        SynSuka3D
                                        Hello
                                        Problem of direction axes
                                        Xbox Controller
                                        Joystick 🙂 righty) is X-XAXIS position on right stick.???
                                        Joystick 🙂 rightx) is axes button LT.????
                                        No axes Y-XAXIS right stick.???
                                        please.
                                        • luckyvacL Offline
                                          luckyvac
                                          Great thanks Anton, I wait peacefully while working on other rhythm guitar. 😄
                                          • luckyvacL Offline
                                            luckyvac
                                            Hello, I would like to know how to increase the damping of the servo motor. Thank you 😄
                                            • 46
                                            • 47
                                            • 3 / 47
