    Solid tools on components
    17 Posts 4 Posters 3.2k Views 4 Watching
    • newnoobN Offline
      newnoob
      I also don't understand Peter. πŸ˜„
      I had a little workaround going which was to create a nested component containing component A and B by copying component A into B, then to transform the former content of component A while in A into a seperate component to end up with a nested component of A and B and then to perform the solid operation and afterwards explode the nested component. This way all instances of the components are affected by the solid operation. However it did only work so far for some of my components because of impractical axis of some of my components.
      Thanks Dave your post was very enlightening! The next thing I am going to do after this post (after I have had a look in my fridge) is to install your recommended Trim and Keep extension.
      • pbacotP Offline
        That's what I meant. I didn't add the detail of bringing in the cutting component and all.
          Good luck in the fridge.
          FWIW, Jim's Trim and Keep made quick work of the mortises, dadoes and grooves in this model. There's lots of them, too. I'd probably still be drawing this if I'd use the Trim tool from the Solid Tools set. No. I tell a lie. I would have done all those manually in much less time than I'd have spent using the Trim tool. I'm thankful for Jim.
          https://c7.staticflickr.com/8/7404/27075086230_727b94c372_z.jpg
          • pbacotP Offline
            Missed that model, Dave. Sweet! I like the drawer fronts. Makes the clear parts look fancier, no matter the grade or species. How do you use that pegboard thingy?
              Thank you Peter. On the original, the drawer fronts and the tongue and groove panels on the back and sides were painted with blue milk paint which was then oiled to give it a rich deep color.
              That "pegboard thing" is called a dead man or a lazy jack. There would be a large peg inserted into a hole to support a wide board or a door on edge clamped in the front vise for planing. It slides on its shoe in the groove.
              • newnoobN Offline
                newnoob
                Thanks Dave, Trim and Keepp is working flawless. I was succesfull in trimming all the strut instances against all the hub instances of my geodesic dome model.
                  Good deal.
                    Jim
                    I am glad you were successful too. FYI Trim and Meep purposefully does not remove the components left around after performing the operation. They are all still available in the Component Browser. Run a Purge Unused operation to clean them up.
                      That's a good point and I should have mentioned it.
                      Meep
                      Made me choke on my coffee. πŸ˜„
                      • newnoobN Offline
                        newnoob
                        I suppose you are the Jim who wrote "Trim and Keep", many thanks for that!
                          Jim
                          @dave r said:
                          Meep
                          You started it...
                            Jim
                            Aye. You're welcome. Thank Dave - he's the one who conceived it - I just wrote it.
                              @jim said:
                              @dave r said:
                              Meep
                              You started it...
                              πŸ˜† πŸ˜† πŸ˜†
                              I didn't notice that. πŸ˜„
                              I suppose I'd better change it though. Who's going to search for Trim and Meep?
