    Create lego-like solid pieces for assembly
    9 Posts 4 Posters 25.6k Views 4 Watching
    • Guillo_OrtizG Offline
      Guillo_Ortiz
      Hi!
      I'm attempting to make a split model for 3d printing and I'd like it to have joints to get a firm grip when assembled (like a lego).
      This is what I have:
      https://cdn-enterprise.discourse.org/sketchup/uploads/default/optimized/3X/3/e/3e2fd95e5402a7029f5b3a8a3667e1e0dbaf1c32_1_690x386.jpg
      Does anyone know of a plugin or a way to get this done?
      • Rich O BrienR Online
        Do you have an idea of the joint type you'll use?
        • sdmitchS Offline
          sdmitch
          @guillo_ortiz said:
          Hi!
          Here is a start. You will need to change the values to suit your situation.
          unless file_loaded?((__FILE__))
          	UI.add_context_menu_handler do |menu|
          		sel = Sketchup.active_model.selection
          		if sel.first.is_a?(Sketchup;;Face)
          			menu.add_separator
          			menu.add_item('Dimple') {
          				face = sel.first; ctr = face.bounds.center; nrm = face.normal
          				cir = Sketchup.active_model.active_entities.add_circle(ctr,nrm,0.125,12)
          				pts = cir.map{|e|e.vertices}.flatten.uniq.map{|v|v.position}
          				fac = Sketchup.active_model.active_entities.add_face(pts)
          				fac.pushpull -0.25 if fac
          			menu.add_item('Pimple') {
          				fac.pushpull  0.25 if fac
          	file_loaded((__FILE__))
          http://sdmitch.blogspot.com/
            Guillo_Ortiz
            Not really, any type will do.
              Guillo_Ortiz
              @sdmitch said:
              @guillo_ortiz said:
              Hi!
              > 			menu.add_separator
              > 		end
              > 	end
              > end
              Thanks for the plugin! It's very close to the effect I'm looking for. BTW, how can I change the units to cm? I tried writing "cm" and " cm" after the number, but got an error.
              • sdmitchS Offline
                sdmitch
                The syntax is ".cm", so 1.inch = 2.54.cm
                  Guillo_Ortiz
                  Thanks, sdmitch. In the end I used your method.
                  Thanks a lot!
                  https://cdn-enterprise.discourse.org/sketchup/uploads/default/original/3X/1/b/1b801c8aee26ab73cbb824f411bc983a90e8e7ca.jpg
                  • JQLJ Offline
                    JQL
                    That won't have a very firm grip as it will twist upon the joint's axis. You should have at least 2 pins per joint... It also seems very prone to detach from each other. Maybe you now should model from what Mitch gave you.
                    www.casca.pt
                    Visit us on facebook!
                      Guillo_Ortiz
                      Thanks, I will. I'm also going to use super glue to reinforce it.
