Can you substitute profile faces in existing follow me objec
Is there a way to substitute(replace) one profile(Face) for another with out having to re trace the path you are extruded along.(follow me tool)
I am trying to make several different door casing examples along a path and am trying to save myself some steps
Thanks -
if the path is away from the end result, it is easier to reselect...
I think i can use this technique to speed things up -
People often miss that you can do multiple followmes by enclosing the profiles in one face.
that's a nifty trick!
Tricky!
Some rests to erase but not a big deal!
Invest in Profile Builder. It's one of the best plugins I have come across. I cant live with out it!
I second that!
Profile builder can let you easily tweak these profile's shape width/length、placement、mirror、material in one step with one click,very slick!
