    In Model Materials
    16 Posts 3 Posters 1.4k Views 3 Watching
    • ntxdaveN
      ntxdave
      Thanks Dave
      I think you might have been thinking of TIG's MaterialConsolidator. I will give it a try.
      When I first searched the plugin store using the word 'material' it did not find it.
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        ITG's MaterialConsolidator is not longer available in the PluginStore. I installed ThomTom's Cleanup and that will do the trick.
        Now I have one last (I hope) silly question. I see things like Color_005 and [Color_005]1 which are duplicate colors. How can I merge them?
        I wish there was a way to tell which objects contained the color/material so I could go change them.
        • sdmitchS
          sdmitch
          After you have changed all "[Color_0051" to "[Color_005]" using Shift key as previously describe, Window>Model Info>Statistics>Purge Unused should remove it from the model materials]
          Make [Color_0051 the current material then, using my Select by Material, choose option "Hide if not"]
          http://sdmitch.blogspot.com/
          • ntxdaveN
            ntxdave
            OK guys, I am missing something about using the Shift key to change a color. Look at the animated gif below and tell me what I should be doing to make all three of these colors the same.
            Materials Panel with same color names
            Is there a tutorial somewhere that I can go read on how to do this properly? There are others as well.
            @SDMitch when I download your plugin there is no RBZ file, do I just place it in my plugins folder? I also notice there is another plugin like yours in the SketchUcation Plugin Store but by another author.
            • sdmitchS
              sdmitch
              First find a face in the model that has a color that you want to get rid of. To use my plugin, first make the color to be removed the current material. Next make the color you want to change it to the current material. Press and hold the Shift key down and paint anyone of the faces having the bad color.
              [attachment=0:34fa5izk]<!-- ia0 -->Materials Panel.gif<!-- ia0 -->[/attachment:34fa5izk]
              @SDMitch when I download your plugin there is no RBZ file, do I just place it in my plugins folder? Yes.
              I'm not surprised.
              • ntxdaveN
                ntxdave
                @sdmitch said:
                I'm not surprised.
                It has the same name as yours and yours is not in the store.
                Once I identify the face I want to change can't I just paint it with the correct color? Why do I have to through the Shift key process?
                BTW: I tried changing the name of one the colors to the one I wanted it to be and I get the message that the names must be unique.
                • sdmitchS
                  sdmitch
                  You would only need or use the Shift key if you wanted all faces with that 'color' to be changed. Otherwise only the one face will be changed.
                  A unique Color/Material name only make sense.
                  • ntxdaveN
                    ntxdave
                    OK - I finally found it and am using it but have a couple more really dumb questions/comments:
                    • I finally found it under Extensions>SDM Tools>Face Tool>Current Material (obviously changed since your video)
                    • When I used Hide if Not it did exactly what it was supposed to however, how do I get back to view my entire model. I could not see what you did in your video to get out of that mode. I have tried all kinds of keys and selections but nothing seems to work. Good thing I went off and created a test to learn how to use the tool.
                    • What are the other entries under the SDM Tools (Edge Tool, CorG Tool, Misc Tool)?
                    In 2017 I had a problem when I clicked on the Hide In Not selection. It just seemed to hang but then this was a much larger model so that may have been the reason. I will try with another test model to see if there is a problem.
                    I think this is going to help me change/clean up a rather complex model that I want to then use in Sketchfab.
                    • sdmitchS
                      sdmitch
                        Edit>Unhide>All should do it.
                        It was my attempt to make things more logical by making the plugins that use and/or create those type of entities.
                      • ntxdaveN
                        ntxdave
                        Yep - that sure works. Hope that is the last of my dumb questions (at least on this topic). β˜€
