    UNKNOWN FONT
    28 Posts 3 Posters 1.6k Views 3 Watching
      djh
      Dave R., yes, I removed the dimension lines from the SU file, saved, updated the LO file and made the export ... with no problem.
        djh
        Dave R, after extensive effort with CDR, it seems there is a problem with the export from LO to PDF. Can one reinstall or repair the installation of LO?
        Someone who works with CDR, wrote to me,"Your file is corrupt. Try this file instead." He seemed to have fixed the "corrupt file".
        Test 016(Ariel).pdf
          You can try to reinstall SketchUp and LayOut. Right click on the installer and choose Run as administrator. Then, when presented with the option, choose Repair.
          I wonder why Adobe reader and Acrobat display the font without problem. If the PDF file is corrupt, they should have problems reading it, too.
            djh
            Dave R, thanks for your patience and suggestion. I repaired the installation but ... it still doesn't import into CDR X6.
              As I indicated in my last post, I find it difficult to believe that LayOut is creating a corrupt PDF considering that Adobe Read and Acrobat have no problem with it. I think despite what the guy at CDR told you, the problem is on the Corel end. I don't have a fix for you, though. Sorry about that.
                djh
                But, even Illustrator (according to the version) couldn't import the file properly.
                  Try a different font and see if you get the same results.
                    djh
                    Same results.
                      Weird.
                      Do you get the same results with a brand new LO file?
                        djh
                        Yes.
                        Test 026.pdf
                          driven
                          does this version of your pdf open in Corel?
                          Test_026.pdf.pdf
                            djh
                            [attachment=0:1ztrr0d6]<!-- ia0 -->Test_026.pdf.pdf<!-- ia0 -->[/attachment:1ztrr0d6]
                            Yes, it opened in CD.
                              driven
                              All I did was opened and saved on my mac...
                              the only real difference is OS X 'shows' the 'lowest' pdf version number 'needed' to open but your file shows the pdf version as being v1.7...
                              Corel must prefer the v1.4 tag as the contents is identical...
                                djh
                                Is there any way to change how LO exports pdf?
                                  djh
                                  Dear John, can one save it as v1.4 tag in Acrobat? I don't have a Mac.
                                    driven
                                    sorry, I don't have Acrobat installed...
                                    the guy who 'fixed' your file earlier in this thread saved it using Acrobat Distiller 11.0 (Windows) as v1.5...
                                    there are on-line and downloadable pdf convertors...
                                      djh
                                      John, thank you.
                                      Now, I'll try to figure out how to fix my file using Acrobat Distiller 11.0 (Windows) as v1.5...
                                      • 2 / 2
