    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    SketchUV Shortcuts
    11 Posts 5 Posters 866 Views 5 Watching
      leminilab
      Hi, I'd like to create shortcuts for the very often used 'Save UVs' and 'Load UVs' in SketchUV. But the commands cannot be found in the Preference/Shortcuts Panel.
      Is it impossible? Really? Forever? ๐Ÿ˜ฎ
      Seriously, it's really not vital, but I would certainly enjoy it! ๐Ÿ˜„
      • "Live every day as if it were your last and then some day you'll be right."
      • "ThomThom rules!!!"
      • srxS Offline
        srx
        Try activating the commands before setting shortcuts.
        www.saurus.rs
          rv1974
          there's no way do that.
          Unfortunately, for some reason Whaat doesn't enable access to shortcuts for many important commands. 'Build profile' or 'build profile along the path' in PB2 for example.
            leminilab
            No way... I was hoping some ruby genius would have replied something like 'yea, no problem!'...
            ๐Ÿ˜„
              If you need to map shortcuts to context menu items you need to make a selection that will make them appear in order for them to appear in Preferences > Shortcuts.
                Pherim
                But SketchUV has its own context menu and the commands only appear there.
                  leminilab
                  Well it seems impossible then...
                  Does sanyone know of another plugin which would do the same thing but would be usable with a keyboard shortcut? โ“
                    Can you screenshot the menu?
                      Pherim
                      Here you go:
                      Only appears with the SketchUV tool selected.
                        Ah, I see. Yea, they probably cannot be assigned shortcuts. Maybe Dale can add alternative menus?
                          leminilab
                          Nah, he replied this to me:
                          "Regarding keyboard shortcuts, unless they are listed as an option in the SketchUp keyboard shortcuts (Preferences), then it can't be done. Sorry!"
                          ๐Ÿ˜ž
