Adding layers to extension
10 Posts 6 Posters 1.1k Views 6 Watching
    medeek
    I've been considering adding the option to specify layers within my plugin (ie. framing, sheathing, blocking etc...)
    I'm still trying to understand SketchUp's concept of layers though. Should each line be drawn on the custom layer or is it enough to create the group or component on the custom layer and the underlying geometry remains on layer0?
    Nathaniel P. Wilkerson PE
    Medeek Engineering Inc
    design.medeek.com
      Always assign the 'raw' geometry - faces and edges - to Layer0 [that's what they get if you do nothing !].
      Then assign other layers to their containers - groups or component-instances...
      A simple way to get a reference to a layer is:
      my_layer = Sketchup.active_model.layers.add("my_layer_name")
      If a layer of that name does not exist, then it's created, and also a reference to it is returned.
      Alternatively, if a layer of that name already exists, then it returns a reference to it.
        medeek
        Is it better to change the active layer to the custom layer and then create the group or component or first create the group/component and then assign it to the custom layer?
        design.medeek.com
          Never change the current layer in code.
          It's unnecessary - and will lead to issues if you forget to reset it afterwards.
          It's much easier to make the geometry already inside a new container.entities context [it'll all be assigned Layer0 [nil] as it's created]
          Then just assign that container.layer=my_layer as desired...
          Much easier and foolproof...
            Garry K
            If you choose to change the active layer - make sure you set it back the way you found it.
            model = Sketchup.active_model
            layers = model.layers
            original_layer = model.active_layer
            begin
            your_layer = layers.add("your_layer_name")
            model.active_layer = your_layer
            do whatever you need to
            ensure
            model.active_layer = original_layer
              medeek
              Thank-you for all of the advice, this will save me from making a bunch of beginner mistakes with regards to layers.
              I've had a number of requests for layers so I'm beginning to explore it a little more seriously.
              I will make the custom layers user definable (name and rename the layers). Are there any more gotchas I should be aware of with layers?
              The default layer names will be something like:
              ROOF_TRUSS
              ROOF_FRAMING
              ROOF_SHEATHING
              ROOF_TRIM
              FLOOR_TRUSS
              FLOOR_FRAMING
              FLOOR_SHEATHING
              design.medeek.com
                driven
                I'd suggest not yelling your Layer names...
                e.g.
                Roof_Truss
                Roof_Framing
                Roof_Sheathing
                Roof_Trim
                Floor_Truss
                Floor_Framing
                Floor_Sheathing
                to me it's polite and looks more professional...
                  Paul Russam
                  As an very active user of layers could you please precede your layers with your/your plugin name this way they will remain unique, calling them common names like 'Roof' or 'Truss' is just asking them to be mixed in with existing layers.
                  If you did the same with any component and material names your plugin(s) creates it would be very helpful too.
                  Paul Russam
                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                    Garry K
                    You could add a sketchup menu option something like "Medeek Truss - Edit Config"
                    Then throw up a simple Sketchup API inputbox where you set each of your granular layers
                    The prompts could be:
                    Roof Truss:
                    Roof Framing:
                    Roof Sheathing:
                    etc.
                    If the input box is empty then use Layer0
                    You can also provide logical defaults like "Roof Framing"
                    Users like Paul can add "Medeek Roof Framing"
                    Users who like underscores "Roof_Framing"
                    Users who want upper case "ROOF_FRAMING"
                    User who speak a different language can call it what ever they want
                    Also if a user wants Roof Framing and Roof Sheathing to appear on the same layer - then all they need to do is use the same layer name for both!!
                    With a bit of effor - you can almost satisfy everyone.
                      Dan Rathbun
                      Yes, SketchUp layers are not really layers at all. They do not "own" geometric collections of entities (like they do in most CAD applications.) In SketchUp, layers are display behavior property sheets, that can be shared with multiple entities.
                      So in SketchUp, each object descended from Sketchup::Drawingelement has a layer property that can be assigned to point at one of these property sheets (that were misnamed "layers" by the developers.)
                      So, in reality you assign a SketchUp object to "use" a layer, not put an object upon a layer.
                      @paul russam said:
                      ... could you please precede your layers with your/your plugin name this way they will remain unique, ... If you did the same with any component and material names your plugin(s) creates it would be very helpful too.
                      This also applies to Attribute Dictionary names. They should be prefixed with the name of your author name and extension name in some way, so there will not be any clashing of dictionary names. (For example, we all cannot have dictionaries named "Properties".) Something like "Medeek_TrussMaker_TrussProperties" or whatever.
                      I'm not here much anymore.
