Custom Dynamic Component Functions = Ruby links
Yep.. what Jim said.. however, his example can also be written in Ruby (on PC using the Win32ole.so extension, which many users have already installed to their "Plugins" directory, or they have it in their full Ruby library directory, if they have installed the full Ruby edition, and pushed it's lib path into the
$LOAD_PATHarray.)So to use the "SendKeys" example (which seems to be a common function name in many of the programming languages available, from low-level C, to the higher level languages such as VB, C# etc.)
Goal: To provide a cross-platform Ruby method, named
SendKeys()that sends keystrokes to the Sketchup application.1) Choose a community namespace. As an example, lets say (for argument's sake,) this will go within the
SKXproject namespace, and beneath that we'll wrap it within aGUIsubmodule.module SKX; end # make sure outer namespace is defined module SKX;;GUI if RUBY_PLATFORM =~ /(darwin)/i # on Mac def self.SendKeys(keystring) # the Mac code using AppleScript end else # on Windows def self.SendKeys(keystring) # the WIN code using Windows Scripting Host end end end # module SKX;;GUIThis is the one file approach, which may not be the best, because it makes everyone update their file(s) even when a revision is made for a certain platform. I show it to make an important point about Ruby, in that it is a dynamic language that can be defined during runtime. (In this example, we would define the same method, two different ways, depending upon which platform it will run on.)
The separate file approach may be better. Where a user chooses an install package for the proper platform, so that their "Plugins/SKX/GUI" directory, only contains the Ruby object definitions for their platform.
To use this proposed feature, scripters would simply require the proper module definition file:
require("SKX/GUI/keyboard.rb") SKX::GUI::SendKeys("require_all 'c:/plugins'"+SKX::GUI::KBD::ENTER)P.S.: Locally within a custom module or class, a scripter can create 'nickname' shortcut references that point at long nested qualified objects, like:
gui = SKX::GUI @kbd = SKX::GUI::KBD
or even:
ENTER = SKX::GUI::KBD::ENTER
So don't be afraid of well organized, multi-nested module namespaces.
Also.. if say, the KBD submodule was just a mixin module of constants, scripters could, if they wished, mix it into their module(s) or class(es) by inclusion:module Author;;FancyPlugin require("SKX/GUI/keyboard.rb") include(SKX;;GUI;;KBD) # now all constants in KBD module, are mixed in. end
the wording in AppleScript is keystroke.
keystroke "v" (for the v key)
keystroke "V" (is for shift + v)
keystroke "V" using command down (for shift-cmmd-v or paste in place)likewise, you can also do menu items:
click menu item "Outer Shell" of menu "Tools"
Yea.. and what is the point your making ??
just saying that ruby could write the macro script. (but I'm pretty sure I'm not thinking about doing this the right way
)like if a user turns on the macro recorder (.rb plugin) then does a series of commands they want to automate then click 'stop ecording'(or whatever).. ruby will then write the commands used in a scpt file in the format of my previous post.. then puts it in the services folder so the user now has a sketchup macro without leaving sketchup or manually typing up an AppleScript.
edit. oh, I was also just saying it's 'keystroke' in applescript as opposed to 'sendkeys'
Jeff,
Very much hope you do a thread on how to use services in Mac. I've moved back to Mac after a too long trip through various PCs and am very curious about Services, AppleScript, and Automator. Anything you put together for Services in SketchUp would be appreciated.
@bmike said:
Jeff,
I'm going to do a thread today on it.
I think I'll keep it super basic at first then the thread can evolve from there into the other possibilities. -
@bmike said:
Jeff,
I think I'll keep it super basic at first then the thread can evolve from there into the other possibilities.Great!
I'll keep an eye out for it! -
ok. I made a little macro example in this thread:
http://forums.sketchucation.com/viewtopic.php?f=15&t=44503
@tig said:
Please read this http://cfcl.com/twiki/bin/view/Projects/SketchUp/DA_Adding_Functions
which covers how to add your own 'custom functions' to a DC. ...The link seems not to work anymore (It actually looks like an endless loop of DNS forwarding!?)
Anywhere else where the info may be found? -
Seems like the site is back up and running! The link about "Adding Functions" seems to have changed to this:
http://cfcl.com/twiki/bin/view/Projects/SketchUp/Cookbook/DA_Adding_Functions
