    Custom Dynamic Component Functions = Ruby links
    30 Posts 9 Posters 15.6k Views 9 Watching
    • jeff hammondJ
      @jim said:
      Once the DC is configured, these steps could be automated into a single step (via a menu or tool button.) I am making the assumption of consistent Component names being used i.e Components named "Cutters" are always subtacted from Components named "Stringer_Uncut"
      hey Jim.
      since the time of this thread, I have automated the finishing parts of the DC using AppleScript. I found a pretty decent way to create macros for sketchup.. the macros are osx 'services' which (can) reside in a specific app's menus (or they can be available system wide)
      which reminds me. maybe I should type up a thread showing how to accomplish this.
      • Dan RathbunD
        Dan Rathbun
        Jeff.. please DO.
        Then if we can find a PC complement (likely OLE,) these "services" could be wrapped as Ruby objects or classes. A platform conditional if block would define the Ruby interface, using AppleScript on the Mac, and OLE on PC. In this way we could have a cross-platform Ruby interface for plugins.
        I'm not here much anymore.
        • jeff hammondJ
          @dan rathbun said:
          Jeff.. please DO.
          hmm. I'm not too sure it would work with what you're suggesting. (at least the way I've been going about it)
          I'm doing GUI scripting so it's basically just keystrokes and menu items.. you can accomplish quite a bit this way (I actually have one script that uses a little but of ruby in there via the console 😄 )
          the thing that's good about it is it's not very complicated so a lot of people should be able to make their own macros this way (and a bonus is that you don't have to install any additional software)..
            Jim
            The Windows equivalent can be accomplished via Windows Scripting.
            Here's a VBScript example:
            Sub Wait
            	Wscript.Sleep(1500)
            End Sub
            set WshShell = WScript.CreateObject("WScript.Shell")
            'WshShell.AppActivate "- SketchUp"
            Command = """C;\Program Files (x86)\Google\Google SketchUp 8\SketchUp.exe"""
            'MsgBox Command
            WshShell.Run(Command)
            Wait
            WshShell.SendKeys "%u" ' My SU Shortcut to open Ruby Console
            Wait
            WshShell.AppActivate "Ruby Console"
            Wait
            WshShell.SendKeys "require_all 'c;/plugins'{ENTER}"
            • jeff hammondJ
              > Command = "C;\Program Files (x86)\Google\Google SketchUp 8\SketchUp.exe"
              > MsgBox Command
              > WshShell.Run Command
              > WScript.Sleep 1000
              > WScript.Sleep 1000
              > WScript.Sleep 1000
              > WshShell.SendKeys "require_all 'c;/plugins'"
              > WScript.Sleep 1000
              > WshShell.SendKeys "{ENTER}"
              is something like that easy to run from within sketchup? (that's sort of the beauty of osx services.. they become a menu item so activating the script is the same for anything else in sketchup.)
              regardless, you guys could probably write a macro recorder in ruby that in turn produces these services :enlighten:
              nothing to do with recording cursor movement etc.. AppleScript can't handle it.. (eg- edit component, select all, explode, generate faces, exit component)
              those steps are what ruby watches, then places the commands in a .scpt format and moves them to the services folder.
              [edit-- sorry for not cleaning up the quotes in my replies.. im on a phone and deleting big chunks of text is no fun 😄 ]
              • Dan RathbunD
                Dan Rathbun
                Yep.. what Jim said.. however, his example can also be written in Ruby (on PC using the Win32ole.so extension, which many users have already installed to their "Plugins" directory, or they have it in their full Ruby library directory, if they have installed the full Ruby edition, and pushed it's lib path into the $LOAD_PATH array.)
                So to use the "SendKeys" example (which seems to be a common function name in many of the programming languages available, from low-level C, to the higher level languages such as VB, C# etc.)
                Goal: To provide a cross-platform Ruby method, named SendKeys() that sends keystrokes to the Sketchup application.
                1) Choose a community namespace. As an example, lets say (for argument's sake,) this will go within the SKX project namespace, and beneath that we'll wrap it within a GUI submodule.
                module SKX; end # make sure outer namespace is defined
                module SKX;;GUI
                  if RUBY_PLATFORM =~ /(darwin)/i # on Mac
                    def self.SendKeys(keystring)
                      # the Mac code using AppleScript
                  else # on Windows
                      # the WIN code using Windows Scripting Host
                end # module SKX;;GUI
                This is the one file approach, which may not be the best, because it makes everyone update their file(s) even when a revision is made for a certain platform. I show it to make an important point about Ruby, in that it is a dynamic language that can be defined during runtime. (In this example, we would define the same method, two different ways, depending upon which platform it will run on.)
                The separate file approach may be better. Where a user chooses an install package for the proper platform, so that their "Plugins/SKX/GUI" directory, only contains the Ruby object definitions for their platform.
                To use this proposed feature, scripters would simply require the proper module definition file:
                require("SKX/GUI/keyboard.rb") SKX::GUI::SendKeys("require_all 'c:/plugins'"+SKX::GUI::KBD::ENTER)
                P.S.: Locally within a custom module or class, a scripter can create 'nickname' shortcut references that point at long nested qualified objects, like:
                gui = SKX::GUI @kbd = SKX::GUI::KBD
                or even:
                ENTER = SKX::GUI::KBD::ENTER
                So don't be afraid of well organized, multi-nested module namespaces.
                Also.. if say, the KBD submodule was just a mixin module of constants, scripters could, if they wished, mix it into their module(s) or class(es) by inclusion:
                module Author;;FancyPlugin
                  include(SKX;;GUI;;KBD)
                  # now all constants in KBD module, are mixed in.
                • jeff hammondJ
                  the wording in AppleScript is keystroke.
                  keystroke "v" (for the v key)
                  keystroke "V" (is for shift + v)
                  keystroke "V" using command down (for shift-cmmd-v or paste in place)
                  likewise, you can also do menu items:
                  click menu item "Outer Shell" of menu "Tools"
                  • Dan RathbunD
                    Dan Rathbun
                    Yea.. and what is the point your making ??
                    • jeff hammondJ
                      just saying that ruby could write the macro script. (but I'm pretty sure I'm not thinking about doing this the right way 😉 )
                      like if a user turns on the macro recorder (.rb plugin) then does a series of commands they want to automate then click 'stop ecording'(or whatever).. ruby will then write the commands used in a scpt file in the format of my previous post.. then puts it in the services folder so the user now has a sketchup macro without leaving sketchup or manually typing up an AppleScript.
                      edit. oh, I was also just saying it's 'keystroke' in applescript as opposed to 'sendkeys'
                      • bmikeB
                        bmike
                        Jeff,
                        Very much hope you do a thread on how to use services in Mac. I've moved back to Mac after a too long trip through various PCs and am very curious about Services, AppleScript, and Automator. Anything you put together for Services in SketchUp would be appreciated.
                        • jeff hammondJ
                          @bmike said:
                          Jeff,
                          I'm going to do a thread today on it.
                          I think I'll keep it super basic at first then the thread can evolve from there into the other possibilities.
                          • bmikeB
                            bmike
                            @bmike said:
                            Jeff,
                            Great!
                            I'll keep an eye out for it!
                            • jeff hammondJ
                              ok. I made a little macro example in this thread:
                              http://forums.sketchucation.com/viewtopic.php?f=15&t=44503
                              • halroachH
                                halroach
                                @tig said:
                                Please read this http://cfcl.com/twiki/bin/view/Projects/SketchUp/DA_Adding_Functions
                                which covers how to add your own 'custom functions' to a DC. ...
                                The link seems not to work anymore (It actually looks like an endless loop of DNS forwarding!?)
                                Anywhere else where the info may be found?
                                FlexTools - Super Quick Windows, Doors, Slats...
                                • halroachH
                                  halroach
                                  Seems like the site is back up and running! The link about "Adding Functions" seems to have changed to this:
                                  http://cfcl.com/twiki/bin/view/Projects/SketchUp/Cookbook/DA_Adding_Functions
                                  • 2 / 2
