    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 250.0k Views 51 Watching
    • fredo6F Offline
      NEW RELEASE 4.3a - 19 Oct 14
      Important update for support of directories and username with non-ascii characters
      See first post of this thread for downloading the script.
      • fredo6F Offline
        NEW RELEASE 4.4a - 06 Nov 14
        Update to take benefit of new features in SU 2015, allowing to select directory via a dialog box
        • fredo6F Offline
          NEW RELEASE 4.5a - 30 dec 14
          Minor update for support of user-name with non-conventional characters (such as apostrophe)
          • F Offline
            flyashy
            Hello,
            I had a suggestion.
            Is it possible to integrate AdditionalPluginsFolders script with the sketchucation plugins manager so that the ruby scripts in the additional folders can be updated via the manager just like it finds the ones in the default plugin folder?
            That would make life much much better. πŸ˜„
            Thanks.
            Flyashy
              The newest version of the SketchUcation PluginStore tool [v2.6.2 on limited beta-test release] has that already built in.
              When you save with AutoInstall it spots your Additional Plugins folder[s] and asks if you want to install into there [it has done so for a long while].
              Now when Updating Plugins it looks to see where each Plugin that is being updated is currently installed and it installs the Plugin into the appropriate folder - the Updater's closing dialog shows the installation location[s].
                CaptainCrowbar
                I found a bug in the current version of AdditionalPluginFolders: On line 281 you call LibFredo6.log "True load: #{basename}" without checking whether LibFredo6 is installed. If it isn't you get an error when SketchUp starts up (if a file of the relevant type is being loaded). This line needs to be enclosed in an if defined?(LibFredo6.log) check.
                • fredo6F Offline
                  Well spotted. I will fix and republish.
                    MieczyslawASompolski
                    I have a problem at loading LibFredo6 with its tools in SU 15. Details in enclosed *.pdf
                    Erors on loading LibFredo6.pdf
                      Looks like you have NOT updated the version of the Lib, or perhaps some of the Extensions that use it.
                      Can I suggest that you download the latest versions of all of Fredo's RBZs from the PluginStore and install them.
                      Or alternatively use the SketchUcation PluginStore tool to AutoInstall them.
                      Then restart SketchUp to complete the changes.
                      See if the error remains...
                      • F Offline
                        flyashy
                        Hello,
                        I seem to have reached an impossible situation.
                        Recently installed 2017 and added additional plugins folder plugin.
                        After I gave a path to my old directory of 2016 plugins, SU17 loaded a few plugins and then crashed.
                        I guess it didn't like some plugin in there.
                        So I uninstalled Additional Plugins folder plugin and tried to reinstall it, it still refers to the path I had given.
                        I have in fact deleted the plugin files but it still refers to the same path and crashes SU17 on startup.
                        So I can't even give a new path to start afresh.
                        While reinstalling the plugin it doesn't wit for me to prescribe a path but starts to load from the old path and crashes SU17.
                        Where would it save the path if the files have been deleted; and how can I reset the plugin?
                        • fredo6F Offline
                          To delete the alternate directory, you can type a command in the Ruby Console*, but again, this assumes you open Sketchup first.
                          So I am afraid you have to disable AdditionalPluginFolders, then start a clean version of Sketchup and then sort out the reason of your crash.
                          * Sketchup.write_default "LibFredo6", "Alternate_dir", ""
                          • F Offline
                            flyashy
                            erm,
                            this is what I get:
                            true
                            I also tried searching the registry for the key so I can manually delete it but can't find it.
                            PS.
                            I meant to say that I didn't find the entry with the path.
                            I found lots of other entries, 2 for each version of SU.
                            • fredo6F Offline
                              @flyashy
                              read_default and write_default manipulate the Sketchup registry, which itself probably use the Windows Registry (and Plist on Mac).
                              So the HKEY of the Windows registry might be different.
                              In addition, the Sketchup registry is assigned to each version of Sketchup.
                              • F Offline
                                flyashy
                                Solved it without having to edit the registry.
                                Checked the log & figured that SU crashed while loading an outdated plugin called 'recalllasttool'.
                                Got rid of it & everything works.
                                Cheers!!
                                  lilywater
                                  thanks a lot! hope it would be useful.
                                  • E Offline
                                    ervau
                                    Hello!
                                    Additional Folders is one of my favorite Plugins and so necessary to keep my User-Profile clean and small (without all the Plugins they're normally stored in...).
                                    So I've updated to the newest version 5.0a --- and get errors:
                                    Fehler beim Laden der Datei C:/Progz/SketchUp/Plugins/LibTraductor.rb
                                    Error: C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:314:in require' C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:314:in load_single_file'
                                    C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:255:in block (2 levels) in load_additional_folders' C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:255:in each'
                                    C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:255:in block in load_additional_folders' C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:253:in each'
                                    C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:253:in load_additional_folders' C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:153:in startup'
                                    C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:617:in <module:AdditionalPluginFolders6>' C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:29:in <top (required)>'
                                    Fehler beim Laden der Datei Win32API.so
                                    Could not find included file 'Win32API.so'
                                    ("C:/Progz/SketchUp/Plugins/" is my additional folder.)
                                    Where's the fix?
                                    Thank you so much for a solution!
                                    Greetings from Bavaria -
                                    ervau
                                    • fredo6F Offline
                                      You should try to remove the old file LibTraductor.rb in the plugin folder.
                                      • E Offline
                                        ervau
                                        Hmmmm - just deleted the file LibTraductor.rb.
                                        Seems not getting better without it, why should it πŸ˜‰?
                                        Do I have to install a newer one (as you say "the old file")? - Where do I get it from (already googled and looked up in LibFredo6)?
                                        Thank you!
                                        Robert
                                        • fredo6F Offline
                                          You don't need LibTraductor.rb with the recent versions of my plugin or if you have LibFredo6 installed.
                                          You error message was related to a fault loading this file. So, if the file is no longer there, you should at least get another error....or no error.
                                          • E Offline
                                            ervau
                                            @fredo6 said:
                                            ... you should at least get another error...
                                            You're right: The error has changed (and shortend):
                                            Fehler beim Laden der Datei !AdditionalPluginFolders.rb
                                            Error: #<NoMethodError: undefined method +' for nil:NilClass> C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:137:in register_execute'
                                            C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:618:in <module:AdditionalPluginFolders6>' C:/Users/volz/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/!AdditionalPluginFolders.rb:29:in <top (required)>'
                                            Any idea what's missing?
                                            So many thanks for your support!
                                            ervau - Robert
                                            • 7 / 8
