    [Plugin]Ithil Render Tools
    26 Posts 13 Posters 17.5k Views 13 Watching
    • spiderminhS Offline
      spiderminh
      converter materials V-ray <==> Corona ??
      GREAT πŸ˜„
        dieptp
        It's so awesome!!!
        I have a bit trouble with apply metal matterial and with matterial attribute paste.
        • Metal matterial it's not friendly =.= I feel so hard to change any value
        • Matterial attribute paste also paste diffuse, too
          Hope guy with fix those bugs (any the other) soon. I truly love clipping plane rendering
          1000 stars for you. Sorry for my bad English
        • chavinskeeC Offline
          chavinskee
          great plugin! would it be possible to edit the material wizard to make use of brdf mats as default in editing already placed materials?
          http://chavinskee.blogspot.com/
          • ithilI Offline
            ithil
            Chavinskee, You are free to change the files in the folder.
            C:\Users\USER_NAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\ithil_render\vrmat
            Read the help file.
              chavinskee
              i can't seem to find the help file. is it because i installed it in sketchup 2016? but the plugin is working properly. anyway, when i edited the material preset plastic 1 using brdf properties, the current applied material's colors in the model did not retain its property but instead used the color of the edited preset material. any help would be greatly appreciated.
              • ithilI Offline
                ithil
                File User manual.zip
                In the first post of this topic
                  rmsnmz
                  I installed the plugin to my SU 2016 but the toolbar is missing all icon images. Anyone experienced this issue?
                  • ithilI Offline
                    ithil
                    Such errors happen when you install a wrong path.
                    If you use ExtensionStore select the path for the installation this plugin:
                    The plugin version does not support path such:
                    c:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Plugins
                      shakigami
                      hi Ithil, whats is the meaning of number 2200 in your example for camera clipping?
                        shakigami
                        hi Ithil, what is the meaning of the number 2200 in your example of camera clipping?
                          shakigami
                            shakigami
                            • ithilI Offline
                              ithil
                              Hey.
                              This is the distance from the camera to the sectional plane in metric millimeters units.
                                Tales Macedo
                                Does not have update to work on SketchUp 2017 and Vray 3.4 Beta?
                                • ithilI Offline
                                  ithil
                                  I'm planning a new version. But I'm waiting for the final release.
                                  I have a working test version. But a lot needs to be fixed for compatibility.
                                    barrubba
                                    how can i export skp 2019 and vray 4 to 3dsmax 2019! its urgent!!
