    [Plugin]Ithil Render Tools
    26 Posts 13 Posters 18.5k Views 13 Watching
    • ithilI
      ithil
      Yes. This version is only for v-ray.
      • G
        gcdavismarine
        Wow! Itil, this is an incredible collection of tools. Thanks so much! I can't believe how much time this could save. Will be very handy while waiting for Vray3. Cheers! πŸ‘
        • G
          gcdavismarine
          Have thought about writing a 'light lister' script for Vray SKU? (I'm currently manually resetting subdivs on 20+ lights in a scene...fun, fun!)
          • ithilI
            ithil
            Yes. It's possible. I will add in the next update.
            Before, You can use "Global subbdivs mult" in DMC sampler, and use light inside the components.
            • C
              cowboyathome
              Any future plans of this working with other renderers? Twilight Render? LuxRender?
              • ithilI
                ithil
                First I am going to make a version compatible with V-ray 3.4 and Corona render version.
                I want to make the converter materials V-ray <==> Corona.
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  This is awesome!
                  • T
                    TraxXx
                    1000 thanks ! So many functions that are missing in Vray are added with that plugin ! And also congrats for adding the camera clipping plane, that's going to make realistic sections renders way easier !!!
                    • spiderminhS
                      spiderminh
                      converter materials V-ray <==> Corona ??
                      GREAT πŸ˜„
                        dieptp
                        It's so awesome!!!
                        I have a bit trouble with apply metal matterial and with matterial attribute paste.
                        • Metal matterial it's not friendly =.= I feel so hard to change any value
                        • Matterial attribute paste also paste diffuse, too
                          Hope guy with fix those bugs (any the other) soon. I truly love clipping plane rendering
                          1000 stars for you. Sorry for my bad English
                        • chavinskeeC
                          chavinskee
                          great plugin! would it be possible to edit the material wizard to make use of brdf mats as default in editing already placed materials?
                          http://chavinskee.blogspot.com/
                          • ithilI
                            ithil
                            Chavinskee, You are free to change the files in the folder.
                            C:\Users\USER_NAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\ithil_render\vrmat
                            Read the help file.
                            • chavinskeeC
                              chavinskee
                              i can't seem to find the help file. is it because i installed it in sketchup 2016? but the plugin is working properly. anyway, when i edited the material preset plastic 1 using brdf properties, the current applied material's colors in the model did not retain its property but instead used the color of the edited preset material. any help would be greatly appreciated.
                              • ithilI
                                ithil
                                File User manual.zip
                                In the first post of this topic
                                  rmsnmz
                                  I installed the plugin to my SU 2016 but the toolbar is missing all icon images. Anyone experienced this issue?
                                  • ithilI
                                    ithil
                                    Such errors happen when you install a wrong path.
                                    If you use ExtensionStore select the path for the installation this plugin:
                                    The plugin version does not support path such:
                                    c:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Plugins
                                      shakigami
                                      hi Ithil, whats is the meaning of number 2200 in your example for camera clipping?
                                        shakigami
                                        hi Ithil, what is the meaning of the number 2200 in your example of camera clipping?
                                          shakigami
                                            shakigami
