    [Plugin]Ithil Render Tools
    26 Posts 13 Posters 18.8k Views 13 Watching
    • chavinskeeC
      chavinskee
      great plugin! would it be possible to edit the material wizard to make use of brdf mats as default in editing already placed materials?
      http://chavinskee.blogspot.com/
      • ithilI
        ithil
        Chavinskee, You are free to change the files in the folder.
        C:\Users\USER_NAME\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\ithil_render\vrmat
        Read the help file.
        • chavinskeeC
          chavinskee
          i can't seem to find the help file. is it because i installed it in sketchup 2016? but the plugin is working properly. anyway, when i edited the material preset plastic 1 using brdf properties, the current applied material's colors in the model did not retain its property but instead used the color of the edited preset material. any help would be greatly appreciated.
          • ithilI
            ithil
            File User manual.zip
            In the first post of this topic
              rmsnmz
              I installed the plugin to my SU 2016 but the toolbar is missing all icon images. Anyone experienced this issue?
              • ithilI
                ithil
                Such errors happen when you install a wrong path.
                If you use ExtensionStore select the path for the installation this plugin:
                The plugin version does not support path such:
                c:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Plugins
                  shakigami
                  hi Ithil, whats is the meaning of number 2200 in your example for camera clipping?
                    shakigami
                    hi Ithil, what is the meaning of the number 2200 in your example of camera clipping?
                      shakigami
                        shakigami
                        • ithilI
                          ithil
                          Hey.
                          This is the distance from the camera to the sectional plane in metric millimeters units.
                          • T
                            Tales Macedo
                            Does not have update to work on SketchUp 2017 and Vray 3.4 Beta?
                            • ithilI
                              ithil
                              I'm planning a new version. But I'm waiting for the final release.
                              I have a working test version. But a lot needs to be fixed for compatibility.
                              • B
                                barrubba
                                how can i export skp 2019 and vray 4 to 3dsmax 2019! its urgent!!
                                • 2 / 2
