โ ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
Fast up SKETCHUP:
Hello, can anyone tell how to configure my Sketchup Vray to work on GPU rather than on CPU, because i run a strong GPU 980ti Nvidia and i want to get enough from it.
just open your render option panel, browse for the vray rt tab check "enabled" and then switch the rendering mode from cpu to cuda.. then start vray rt..
Thank for the help
. I see GPU cuda and GPU opencl whats the difference witch one is faster ? -
you are on nvidia, i suppose cuda is the way to go..
