    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
      Hm.. yea, it's quite likely other extensions also will run into problems.
      As for Selection Toys. So it's installed and you see the menus? But the Settings dialog is blank?
      • coulteriC
        coulteri
        I can use only menu on right mouse button.
        UI settings window is blank.
        I will try to make my computer name TT friendly in the future πŸ˜„
          There is no toolbar in the list of toolbars? And nothing under Tools > Selection Toys?
          (If you keep the Ruby Console open when you try to open the UI settings window - is there any output then?)
          • coulteriC
            coulteri
            When I enable Selection Toys toolbar from view/toolbars there are toolbars you can see on the left side of the picture.
            Tool/selection toys / UI settings - calls blank window in the middle.
            Tools/selection toys/ cheat sheet - looks fine.
            Ruby console doesnΒ΄t contain anything.
              Interesting. Ok - let me try to have another look at this.
                I added an issue in the issue tracker: https://github.com/thomthom/SelectionTools/issues/1
                  Weeelll.... that's embarrassing. It turns out that the blank window is due to a bug. Where I previously tried to fix unicode issues. Not sure how I never noticed that before. But it doesn't even load on my machine. It's a quick fix though - hang on.
                    Ok - try using v2.3.11: http://sketchucation.com/pluginstore?pln=tt_selection_toys
                    • coulteriC
                      coulteri
                      I am out of my office until the end of this weekend. I will try it after my return and let you know πŸ˜„
                      Thank you very much!
                      • ludnidL
                        ludnid
                        Hi Thomthom. I've got the same problem with Coulteri. With the new version dialogue still remains the same.
                        If you don't ask, the answer will always be no.
                          Can you open the Ruby Console and enter these lines, one by one and then post back the result?
                          filepath = File.join(TT;;Plugins;;SelectionToys;;PATH, 'webdialog/ui_manager.html')
                          p File.exist?(filepath)
                          p filepath
                          p filepath.bytes
                          • ludnidL
                            ludnid
                            > p filepath
                            > p filepath.bytes
                            -filepath = File.join(TT::Plugins::SelectionToys::PATH, 'webdialog/ui_manager.html')
                            C:/Users/Ludnid/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_selection_toys/webdialog/ui_manager.html
                            -p File.exist?(filepath)
                            true
                            true
                            -C:/Users/Ludnid/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_selection_toys/webdialog/ui_manager.html"
                            -[67, 58, 47, 85, 115, 101, 114, 115, 47, 74, 117, 100, 100, 32, 82, 97, 109, 101, 115, 101, 115, 47, 65, 112, 112, 68, 97, 116, 97, 47, 82, 111, 97, 109, 105, 110, 103, 47, 83, 107, 101, 116, 99, 104, 85, 112, 47, 83, 107, 101, 116, 99, 104, 85, 112, 32, 50, 48, 49, 53, 47, 83, 107, 101, 116, 99, 104, 85, 112, 47, 80, 108, 117, 103, 105, 110, 115, 47, 116, 116, 95, 115, 101, 108, 101, 99, 116, 105, 111, 110, 95, 116, 111, 121, 115, 47, 119, 101, 98, 100, 105, 97, 108, 111, 103, 47, 117, 105, 95, 109, 97, 110, 97, 103, 101, 114, 46, 104, 116, 109, 108]
                              I'm confused...
                              That path isn't what I get from the array of bytes...
                              bytes = [67, 58, 47, 85, 115, 101, 114, 115, 47, 74, 117, 100, 100, 32, 82, 97, 109, 101, 115, 101, 115, 47, 65, 112, 112, 68, 97, 116, 97, 47, 82, 111, 97, 109, 105, 110, 103, 47, 83, 107, 101, 116, 99, 104, 85, 112, 47, 83, 107, 101, 116, 99, 104, 85, 112, 32, 50, 48, 49, 53, 47, 83, 107, 101, 116, 99, 104, 85, 112, 47, 80, 108, 117, 103, 105, 110, 115, 47, 116, 116, 95, 115, 101, 108, 101, 99, 116, 105, 111, 110, 95, 116, 111, 121, 115, 47, 119, 101, 98, 100, 105, 97, 108, 111, 103, 47, 117, 105, 95, 109, 97, 110, 97, 103, 101, 114, 46, 104, 116, 109, 108]
                              bytes.pack('U*')
                              # > C;/Users/Judd Rameses/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_selection_toys/webdialog/ui_manager.html
                              And you have version 2.3.11?
                              Can you type in this into the console:
                              TT::Plugins::SelectionToys::PLUGIN_VERSION
                              • coulteriC
                                coulteri
                                I am back and have just tried newest version that works perfect and with no problems!
                                Thanks ThomThom!
                                πŸ˜„
                                • ludnidL
                                  ludnid
                                  @thomthom said:
                                  I'm confused...
                                  > bytes.pack('U*')
                                  2.3.11
                                    @ludnid: what is your user path? I'm still confused by the byte array shows a different path than the error message...
                                      If you right click on the blank window, do you get the option to View source?
                                      (and if you open Ruby Console before opening the window, any output there?)
                                      • ludnidL
                                        ludnid
                                        Sorry for the late response. I just figured I'll do the upgrade to 2017 seeing some of the new tweaks made to it. Selection Toys works like a charm now. Thanks Thom.
                                        • V
                                          vlau2
                                          Great tool! Is there a way to use the select faces by area for multiple selection of faces? So instead of individually selecting a face, I would like to select multiple faces and it would loop through each face and perform a selection of faces by area for each.
                                          What I'm trying to accomplish is selecting multiples of the same balcony on a building. Unfortunately, the building model was not built with components in mind and it is all in one layer. The idea is that I would select 1 balcony of the building (which is made out of several faces) and use the select faces by area to loop through each face and select the other balconies on the building.
                                          • P
                                            perishknight
                                            Can a selection be expanded by type?
                                            It's more intuitive to select 1 item type, for example text, images, dimensions, section planes, etc; and expand the selection.
                                            Instead of the reverse, where you select all items and then filter it out.
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
