    [Beta Program] Animator
    18 Posts 7 Posters 2.0k Views 7 Watching
    • fredo6F Offline
      Welcome to the Animator Public Beta program
      Animator is a script dedicated to the animation of Sketchup models. It provides a parametric, interactive framework to control movements of objects and cameras along a timeline.
      The plugin now enters a public beta program, with a dedicated sub-forum of Sketchucation, where you will find most the release notes, some instructions and video tutorials. We invite users to post in this forum.
      Animator is now exclusively published on the PluginStore.
      IMPORTANTAnimator requires LibFredo6, with a version at the same level: for instance Animator v1.2a requires LibFredo6 v7.2a.
      Just to give an idea, below are a number of videos showing how Animator works. Some videos are now old, and there has been some evolution in the functionality and the user interface. But this gives you a first idea!
      First of all, a few animations generated by Animator and rendered with supported Rendering software.
      In Natural mode (No rendering)
      Rendered with AmbientOcclusionEx
      Rendered with Thea (no model preparation)
      Rendered with SketchFX (no model preparation)
      Rendered with Twilight Render Pro
      And some video tutorials
      Creating a First Animation
      The following tutorial shows how to create a basic animation.
      Finishing the Object Animation
      We can now finish the object animation. The tutorial shows how to re-use existing movements and modify / adjust the animation after it is built.
      Adding Cameras
      Installing FFmpeg (MS Windows)
      FFmpeg is an open source tool, free, which is used by Animator to generate video files. The tutorial shows how to do the installation once.
      Generating a video
      Launching / Stopping the Animation
      Tracking Cameras
      Layer Visibility
      • dereiD Offline
        derei
        Can't access the dedicated subforum: "You are not authorised to read this forum."
        Thank you.
        • jujuJ Offline
          juju
          +1
            I believe that is only for beta testers! πŸ˜‰
            • F Offline
              faust07
              Great! I hope there is a great response to this useful plugin. Animation, simulation in sketchy and render stiles is a dream that will finally come true ...
                Thank you.
                Working on it...my apologies
                  dtrarch
                  Hi Fredo
                  Just a super super plugin BUT ❓ ❓ ❓
                  How to contribute in US $$ ❓ ❓ Please
                  dtrarch
                    I am not awaken! 😳
                    Animation is played one time!
                      @pilou said:
                      I am not awaken! Animation is played one time!
                      Double click in the viewport to play. Double click in the viewport to play [Repeat]
                      • fredo6F Offline
                        Pilou,
                        Just use the Oscillation for the movement (one or several cycles).
                        Then do a Repeat for as long as you need.
                          @fredo
                          I think he wants the playback to loop back to frame 1 after hitting the final frame. For an infinite viewport playback.
                            Yes but this is "external" !
                            I want something "inside" the Time Line (if existing)
                            I don't want a "copy past" many time πŸ˜„
                            That is curious that this case was not predicted!
                            A sort of Ping Pong effect and Loop effect! πŸ˜„
                            There is this repeat but...& this infinite is not visible in the animation! 😳
                            • fredo6F Offline
                              There is no infinite playback within the model (but video viewers like MoviePlayer or QuickTime have the option),
                              I can indeed add the option, but what for exactly.
                                In Blender the timeline playback loops. Which is great to analyse for timing conflicts.
                                  yes πŸ˜„
                                    Sure imagine you have several objects with each differente infinite oscillations
                                    That will be fine to have the possibility to see what happen
                                    with different regulates in an infinite loop of a general closed movement! πŸ˜„
                                    (2 sorts : Ping Pong & Loop) without render a film!
                                    • fredo6F Offline
                                      [attachment=0:1bdyn990]<!-- ia0 -->ani7.jpg<!-- ia0 -->[/attachment:1bdyn990]
                                      Pilou,
                                      What you request is slightly different, as you wish the infinite loop is for individual clip elements (whereas Rich mentions a infinite loop for the whole Animation, in Blender).
                                      Let me think about it. Repeating the whole animation is easy. Individual elements may require some GUI and show some subtle side effects.
                                      Note also that Animator manages two modes: Repeat and Pursue, and I think a Pursue infinite may be useful too, as it provides continuity of movement, whereas Repeat will 'jump' back to the initial position.
                                        Repeat and Pursue
                                        Yes all yet existing is very useful! 😎
                                        Seems this is implicite if each clip has its own animation from start to end animation! πŸ˜„
                                        But will be terrific if you can make this automatically! πŸ‘
                                        So general Loop! Excellent! 😎
                                        Ping-pong will be paradisiacal! β˜€
                                        Not yet automatic animation element along a path ?
