    Why does all material get displacement?
    renderpluginsextensions
    4 Posts 2 Posters 775 Views 2 Watching
    • V Offline
      vigge50
      HellO
      I wanted to test displacement to make the grass lock more real and I was glad with the result even if it's probably possible to make it much better but what bothers me is the other material.
      Here is my first image without displacement
      Here is my second image with displacement.
      The grass locks mush better but of some reason the driveway also got displacement and I can't find the settings to remove it. Any idea about what could have gone wrong? If i copy the driveway with the same material inside another model the displacement disappear so it most have something to do with the model but I can't find the settings.
        peerman
        Is the driveway in the same group as the grass? If so, you probably assigned the grass material to the group that includes the driveway. Cut the driveway out of the grass group and make it it's own. Make sure to assign the driveway material to this new group to make sure that the grass one is gone.
        Hope this helps.
        Peter
        iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
        • V Offline
          vigge50
          Hope this helps.
          Peter
          Not the same group but the same component, will test to explode the component and see if it solves the problem.
          • V Offline
            vigge50
            That Solveig the problem, thansk for the tip.
