    Automatically load a component.
    70 Posts 5 Posters 12.2k Views 5 Watching
      So to paraphrase...
      You want to have your cube component loaded into the model's definitions.
      You want to have ONE instance of it placed in the model.
      That instance should be 'masked' - e.g. assigned a special OFF layer, be hidden and be locked.
      [Aside: You could also make it so tiny that if was hard to find !]
      All this is readily done.
      My example test code, checks if the definition is loaded and if not it loads it.
      If it id loaded and there is an instance there is nothing more to do, otherwise it adds the instance...
      I agree with Dan...
      All of the messing on so far could be achieved by more subtle and less complex means.
      It probably needs a separate thread...
      However, here's my outline.
      Your plugin code loads DC components.
      It's possible to give a DC component a function which stops it working if the function fails.
      Your RB code could add a new function to the DC functions-code in the model, as it loads.
      Thereby your RB makes your special DCs usable.
      If a recipient of your DC does not have your licensed RB loading, then your DC does not work for them.
      The absence of your extra DC function to validate your DC could also be triggered when a users license expires.
      Here's an example of an extra DC function your RB could add...
      require('sketchup')
      if Sketchup.version.to_i <= 8
      	require('dynamiccomponents.rb')
      else
      	require('su_dynamiccomponents.rb')
      if defined?($dc_observers)
        ### Open SketchUp's Dynamic Component Functions (V1) class.
        ### BUT only if DC extension is active...
      	class DCFunctionsV1
      		protected
      		unless DCFunctionsV1.method_defined?(;tnt_checker)
      			def tnt_checker()
      				return true
      			protected;tnt_checker
      			### Usage; =tnt_checker()
      	end#class
      end#if
      Your main RB adds this extra function.
      Within each of your DCs you use the extra function to set up a reference etc.
      Usage: =tnt_checker()
      It returns true if the RB has added the function of false/or fails otherwise...
      Unfortunately even that could be circumvented by a Pro user editing the DCs attributes, BUT if your DC code is convoluted enough and it relies on the =tnt_checker() function's value being true to perform its later functions, then it at least makes the DC much more difficult to 'pirate'...
      They could also write their own code RB snippet to set up that function and always return true ?
      • Dan RathbunD
        Dan Rathbun
        @tntdavid said:
        If someone shares one of my dynamic components with a user without my extension, it must be impossible to use these dynamic features!
        There is no way to make it impossible.
        If you must use a DC function try to use a refinement for Ruby 2.0+.
        Code example withdrawn. A refinement will not work, because the DC code files would themselves need to use the refinement.
        • Modifying the DCFunctionsV1 class may not pass inspection by the Trimple Developer extension signing page.
        I'm not here much anymore.
        • TNTDAVIDT
          TNTDAVID
          Very good idea. 👍
          We can also hide the edges of a model?
          You talk about this example?
          @tig said:
          if definition.valid?
            if instance.valid? ###[or perhaps || definition.instances[0] ???]
              ### You are already set to do the DC load...
            else
              ### You need to add an instance - perhaps it's been deleted by the user ???
              ### NOW you are set to do the DC load...
          else ### definition is NOT valid - it's been deleted - so the instance has too.
            ### You load the definition AND add the instance again - seems like the user has deleted both !
          @tig said:
          I agree with Dan...
          I do not doubt for a moment of your words.
          As my specialty are dynamic components, create a protection directly into the models is much easier for me.
          Although my protection is not foolproof, it will be very difficult to circumvent.
          Thanks for these informations ❗
          [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
          • TNTDAVIDT
            TNTDAVID
            Hello,
            I still can not limit the number of cube to 1. 😕
            If someone can give me more information on writing code, I would be very recognize him.
            Thank you
            David
              Think through the logic...
              Here set out in words - not code...
              If there is no loaded definition, either it's a fresh start or the user has managed to delete it from the model: therefore you load it - otherwise you have got it already and you go to the next step.
              Next.
              If there is no instance of that definition, either because it's a fresh start or the user has managed to delete it from the model: therefore you need to add it - otherwise you already have it and do nothing.
              If there are multiple instances delete all but the first one.
              S'il n'y a pas de la definition chargée, soit il est un nouveau départ, ou l'utilisateur a réussi à le supprimer du modèle: donc vous le chargez [load] - sinon vous l'avez, déjà vous allez à l'étape suivante.
              Prochain.
              S'il n'y a pas d'instance de cette definition, soit parce qu'il est un nouveau départ, ou l'utilisateur a réussi à le supprimer du modèle: par conséquent, vous devez l'ajouter - sinon, vous l'avez déjà et ne rien faire ...
              S'il y a plusieurs instances supprimer tout sauf la première.
              model = Sketchup.active_model
              definitions = model.definitions
              if definition = definitions['cube'] ### or whatever it's named
                ### do nothing as we already have it
              else
                ### we load it because it's missing
                definition = definitions.load(path_to_cube.skp) ### you need to work that out
              end #if
              ### now check instance exists
              if definition.instances.length == 1
                ### we have it
                instance = definition.instances[0]
              elsif definition.instances.length > 1
                ### somehow we have duplicates, erase all but the first one [0]
                definition.instances[1..-1].each{|i| i.erase! }
              else
                ### there is NO instance so we add it
                instance = model.entities.add_instance(definition, ORIGIN)
              end #if
              ### Now change instance to have an OFF layer, hide it, lock it etc etc
              ### ALWAYS do this in case the user has messed with it...
              [mod=:1961t99s]Fixed my stupid typo ' definition.instances[1..-1]**.each**{|i| i.erase! }'[/mod:1961t99s]
              • TNTDAVIDT
                TNTDAVID
                Thanks TIG,
                I followed your method, which is very clear and detailed:
                def self.methode1
                      path = Sketchup.find_support_file("cube.skp",
                      "Plugins/TesteCube/Components/")
                      component_definition = definitions.load(path)
                      point = Geom;;Point3d.new(0, 0, 0)
                      transformation = Geom;;Transformation.new(point)
                      else
                      definition.instances[1..-1]{|i| i.erase! }
                      else
                      instance = model.entities.add_instance(component_definition, transformation)
                      status = instance.locked = true
                      layers = model.layers
                      new_layer = layers.add "cube"
                      new_layer.visible = false
                      instance.layer = new_layer
                      instance.hidden = true
                      Sketchup.active_model.import(@@path_to_00)
                I get this error message at the launch of SketchUp:
                Error Loading File C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube/logic.rb
                Error: #<SyntaxError: C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube/logic.rb:30: syntax error, unexpected { arg, expecting keyword_end
                C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube/logic.rb:30: syntax error, unexpected '}', expecting keyword_end
                C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube/logic.rb:102: syntax error, unexpected end-of-input, expecting keyword_end>
                C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load'
                C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube.rb:28:in register_extension' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube.rb:28:in module:TesteCube'
                C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube.rb:18:in `<top (required)>'
                I made a mistake somewhere?
                Thank you
                • TNTDAVIDT
                  TNTDAVID
                  Wonderful 😍 😍 😍
                  If I delete this line of code:
                  Your method works great TIG! 👍
                  Do you know why the line of code that is intended to deleted "cube", does not?
                  Many thanks for your help.
                  David
                  • Dan RathbunD
                    Dan Rathbun
                    Use:
                    definition.instances[1..-1].each {|i| i.erase! }
                    • K
                      kaas
                      Also have a look at this section in the picture.
                      My suggestion is: add more puts statements into your code to quickly find the problems (yourself).
                      Edit: where are you declaring definitionanyway??
                        Sorry about the typo - substitute Dan's .each{ correction.
                        I have edited the original post to suit !
                        Also I used the reference ' definition' BUT you then used ' component_definition'
                        Please try to match such references when you are given 'generic' code...
                        Why did you not follow my example more closely [except for the stupid typo!] ???
                        PS: @Kaas is actually wrong it IS = NOT == because
                        if definition = definitions[...
                        With the = test you are trying to set the reference ' definition' to be pointing to something 'by name' in definitions - if that fails then you get nil returned, so then the else part of the test runs...
                        A == test is for 'equality' of two items, and not for testing if setting a reference works...
                        • TNTDAVIDT
                          TNTDAVID
                          I took note of all your comments. 😉
                          This is not very important but the code, do not remove the "cube", if there is more than one.
                          elsif component_definition.instances.length> 1
                                   component_definition.instances [1 .. -1] .each {| i | i.erase! }
                                   component_definition.instances instance = [0]
                          You know why?
                          Thank you
                          David
                            It's wrongly formed, reread what you have typed it does not make sense.
                            Try this...
                            elsif component_definition.instances.length > 1
                              component_definition.instances[1..-1].each{|i| i.erase! }
                              instance = component_definition.instances[0]
                            I am assuming that all of your references to the cube's definition now use 'component_definition' rather than 'definition' ?
                            You cannot copy / paste snippets of code in a different sequence and hope that it will somehow work.
                            The first part of your code is also carried over from your earlier version and does NOT do what I asked you to do.
                            It always loads the path, but you ought to check if the definition exists and then load it if not.
                            Try following my code more closely, and remove your earlier steps which pre-load the cube before checking if it's loaded !
                            • K
                              kaas
                              @tig said:
                              ...PS: @Kaas is actually wrong it IS = NOT == because
                              Thanks TIG. Learned something here.
                              • TNTDAVIDT
                                TNTDAVID
                                I think yes :
                                def self.methode00
                                     if component_definition = definitions['cube']
                                     else
                                     component_definition = definitions.load(path_to_cube.skp)
                                     if component_definition.instances.length == 1
                                     component_definition.instances [1..-1] .each {| i | i.erase! }
                                     else
                                Sorry for silly mistakes, but i am just beginning to understand the logic of the ruby.
                                I'm a simple Carpenter by training, then learn the ruby is not easy for me.
                                I Thank You for your understanding and your indulgence.
                                David
                                  The initial
                                  is NOT needed.
                                  remove it, and retry.
                                  • TNTDAVIDT
                                    TNTDAVID
                                    @tig said:
                                    The initial
                                    is NOT needed.
                                    If I delete this line, the cube is no longer imported. 😲
                                    Another area of research:
                                    Is it possible to activate a tool SketchUp, with an icon from my toolbar?
                                    I would like to activate the tool, "Interact with Dynamic Components" and the window of "Components Options".
                                    How to change the value of an attribute of a dynamic component, by clicking on an icon?
                                    Thank you in advance for your lights.
                                    David
                                      The reason it's not loading is that the if...else...end test fails because you have not edited it properly:
                                      The line
                                      should actually be
                                      Of course you can do all of what you outline by setting up appropriate code.
                                      e.g. if you have a selected DC instance then a button click could change an attribute and then refresh the DC, but all of this is complex - we already have enough issues getting the cube.skp loaded !
                                      • TNTDAVIDT
                                        TNTDAVID
                                        Do not be so pessimistic TIG, because thanks to you I made very big progress in Ruby. 💚
                                        Here is an example of evolution, thanks to the ruby script:
                                        http://i.imgur.com/tgXhofT.gif
                                        Notice that the "Control Panel", is the "Click-Window 3D" layer are imported along with the "Hung Windows".
                                        Other advanced thanks to ruby, the "Control Panel" always positions façe the camera when you call.
                                        I want to believe you that my requests are complicated, but I will not give up before trying.
                                        You can at least guide me by giving me the methods to use?
                                        And if you are generous as usual, a small sample code?
                                        Thank you in advance.
                                        David
                                          Try this to open the Options dialog for the currently selected DC.
                                          $dc_observers.get_latest_class.show_configure_dialog
                                          Here are some other clues to update a DC after you change its attributes in Ruby...
                                          With dins set to an array of DC instances...
                                          dins.each{|di| $dc_observers.get_latest_class.redraw(din, false, false) if din && din.valid?}
                                          Alternatively
                                          dins.each{|sel| $dc_observers.get_latest_class.redraw_with_undo(din) if din && din.valid? }
                                          DC attributes are normally attached to the DC instance's definition,although some are on the instance itself.
                                          Assuming that din is the DC instance...
                                          dda = din.definition.attribute_dictionary("dynamic_attributes") ida = din.attribute_dictionary("dynamic_attributes")
                                          To see these, when testing etc, use
                                          dda.each_pair{|k, v| puts "#{k} = #{v}" }
                                          and so on...
                                          To get a particular 'key' value use this format.
                                          Note how 'built-in' attributes start with an _
                                          puts dda["_name"]
                                          To set a particular 'key' to a new value use this format.
                                          First see original name...
                                          puts dda["_name"] **dda["_name"]="Banane"** puts dda["_name"]
                                          which should show the new name...
                                          BUT remember that you need to do a ' redraw' - as explained above to see the changes and update the DC's Options etc.
                                          Also consider how attribute values are stored - as strings, with dimensions in inches etc...
                                          • TNTDAVIDT
                                            TNTDAVID
                                            TIG big thank you, this code works perfectly.
                                            I read on another forum, some character like "$" are refused by the bank of extensions and can lead to a rejection of the Plugin.
                                            Is it true?
                                            How close the window component options, with another icon?
                                            I'm sorry to ask twisted questions, but your experience is a great help to me. 👍
                                            I can not activate the icon "Interact with Dynamic Component".
                                            Yet I am the logical steps:
                                            1. I select the tool "Interact with Dynamic Components".
                                            2. I open the Ruby console and write this code:
                                             = tools Sketchup.active_model.tools
                                             if tools.active_tool_id.equal? 0
                                              puts "Tools collection is empty"
                                             else
                                             name = tools.active_tool_name
                                            The result is: "RubyTool" the name of the tool.
                                            As a result I write the following code:
                                            result = Sketchup.send_action "selectRubyTool:"
                                            The result is: False!
                                            If that means that "RubyTool" is not the right name.
                                            I so understand, that the solution is too hard to find for me!
                                            Do you have the solution?
                                            Thank you for explanations on changing the Dynamic Component with the ruby ​​script.
                                            I'll take my time to study in detail all the information you give me.
                                            Thank you for your patience.
                                            David
                                            • 3 / 4
