    Automatically load a component.
    70 Posts 5 Posters 10.8k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      My response is why use a hidden geometric construct to "protect" other components ?
      I would instead use an AttributeDictionary.
      I'm not here much anymore.
        kaas
        @tntdavid said:
        ...When I click on my icon, nothing happens....
        Not sure. Maybe you already have an instance of the component present in your model? Its easy to find out by debugging. Add just one line in this loop:
        definitions.each{|d|
            if d.name == 'cube'
        		c = d.count_used_instances
        		puts %(there are #{c} instances in the model of cube)
        		in_scene = true if c > 0
        This code won't help you though if you want to have just 1 cube per scene. That would make the code more complex.
        Edit: Dan's suggestion might be just what you need. Its the only way to really hide data.
        • TNTDAVIDT Offline
          TNTDAVID
          Pilou thank you for your clearer picture that my writings. 😛
          Because of my English very bad, I think I lacked clarity.
          I want a single cube by Sketchup file.
          In Sketchup file, you can have a complete project with many dynamic components, but you have a single cube!
          No instance is present in my file. 😕
          To test the code, you can download the extension HERE.
          It's complicated to automatically remove a "cube", when there are 2?
          Thank you for this information, I must annalyser this "class" with attention. 👍
          With the methods provided by this class, is it possible to make a dynamic component unusable without the presence of the extension?
          For example :
          If someone shares one of my dynamic components with a user without my extension, it must be impossible to use these dynamic features!
          I want to go at the end of my research, because my final interest is not only the security of my dynamic components.
          Thank you for your support
          David
          [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
            So to paraphrase...
            You want to have your cube component loaded into the model's definitions.
            You want to have ONE instance of it placed in the model.
            That instance should be 'masked' - e.g. assigned a special OFF layer, be hidden and be locked.
            [Aside: You could also make it so tiny that if was hard to find !]
            All this is readily done.
            My example test code, checks if the definition is loaded and if not it loads it.
            If it id loaded and there is an instance there is nothing more to do, otherwise it adds the instance...
            I agree with Dan...
            All of the messing on so far could be achieved by more subtle and less complex means.
            It probably needs a separate thread...
            However, here's my outline.
            Your plugin code loads DC components.
            It's possible to give a DC component a function which stops it working if the function fails.
            Your RB code could add a new function to the DC functions-code in the model, as it loads.
            Thereby your RB makes your special DCs usable.
            If a recipient of your DC does not have your licensed RB loading, then your DC does not work for them.
            The absence of your extra DC function to validate your DC could also be triggered when a users license expires.
            Here's an example of an extra DC function your RB could add...
            require('sketchup')
            if Sketchup.version.to_i <= 8
            	require('dynamiccomponents.rb')
            else
            	require('su_dynamiccomponents.rb')
            if defined?($dc_observers)
              ### Open SketchUp's Dynamic Component Functions (V1) class.
              ### BUT only if DC extension is active...
            	class DCFunctionsV1
            		protected
            		unless DCFunctionsV1.method_defined?(;tnt_checker)
            			def tnt_checker()
            				return true
            			protected;tnt_checker
            			### Usage; =tnt_checker()
            	end#class
            end#if
            Your main RB adds this extra function.
            Within each of your DCs you use the extra function to set up a reference etc.
            Usage: =tnt_checker()
            It returns true if the RB has added the function of false/or fails otherwise...
            Unfortunately even that could be circumvented by a Pro user editing the DCs attributes, BUT if your DC code is convoluted enough and it relies on the =tnt_checker() function's value being true to perform its later functions, then it at least makes the DC much more difficult to 'pirate'...
            They could also write their own code RB snippet to set up that function and always return true ?
              Dan Rathbun
              There is no way to make it impossible.
              If you must use a DC function try to use a refinement for Ruby 2.0+.
              Code example withdrawn. A refinement will not work, because the DC code files would themselves need to use the refinement.
              • Modifying the DCFunctionsV1 class may not pass inspection by the Trimple Developer extension signing page.
              • TNTDAVIDT Offline
                TNTDAVID
                Very good idea. 👍
                We can also hide the edges of a model?
                You talk about this example?
                @tig said:
                if definition.valid?
                  if instance.valid? ###[or perhaps || definition.instances[0] ???]
                    ### You are already set to do the DC load...
                  else
                    ### You need to add an instance - perhaps it's been deleted by the user ???
                    ### NOW you are set to do the DC load...
                else ### definition is NOT valid - it's been deleted - so the instance has too.
                  ### You load the definition AND add the instance again - seems like the user has deleted both !
                @tig said:
                I agree with Dan...
                I do not doubt for a moment of your words.
                As my specialty are dynamic components, create a protection directly into the models is much easier for me.
                Although my protection is not foolproof, it will be very difficult to circumvent.
                Thanks for these informations ❗
                • TNTDAVIDT Offline
                  TNTDAVID
                  Hello,
                  I still can not limit the number of cube to 1. 😕
                  If someone can give me more information on writing code, I would be very recognize him.
                  Thank you
                  David
                    Think through the logic...
                    Here set out in words - not code...
                    If there is no loaded definition, either it's a fresh start or the user has managed to delete it from the model: therefore you load it - otherwise you have got it already and you go to the next step.
                    Next.
                    If there is no instance of that definition, either because it's a fresh start or the user has managed to delete it from the model: therefore you need to add it - otherwise you already have it and do nothing.
                    If there are multiple instances delete all but the first one.
                    S'il n'y a pas de la definition chargée, soit il est un nouveau départ, ou l'utilisateur a réussi à le supprimer du modÚle: donc vous le chargez [load] - sinon vous l'avez, déjà vous allez à l'étape suivante.
                    Prochain.
                    S'il n'y a pas d'instance de cette definition, soit parce qu'il est un nouveau départ, ou l'utilisateur a réussi à le supprimer du modÚle: par conséquent, vous devez l'ajouter - sinon, vous l'avez déjà et ne rien faire ...
                    S'il y a plusieurs instances supprimer tout sauf la premiĂšre.
                    model = Sketchup.active_model
                    definitions = model.definitions
                    if definition = definitions['cube'] ### or whatever it's named
                      ### do nothing as we already have it
                    else
                      ### we load it because it's missing
                      definition = definitions.load(path_to_cube.skp) ### you need to work that out
                    end #if
                    ### now check instance exists
                    if definition.instances.length == 1
                      ### we have it
                      instance = definition.instances[0]
                    elsif definition.instances.length > 1
                      ### somehow we have duplicates, erase all but the first one [0]
                      definition.instances[1..-1].each{|i| i.erase! }
                    else
                      ### there is NO instance so we add it
                      instance = model.entities.add_instance(definition, ORIGIN)
                    end #if
                    ### Now change instance to have an OFF layer, hide it, lock it etc etc
                    ### ALWAYS do this in case the user has messed with it...
                    [mod=:1961t99s]Fixed my stupid typo ' definition.instances[1..-1]**.each**{|i| i.erase! }'[/mod:1961t99s]
                    • TNTDAVIDT Offline
                      TNTDAVID
                      Thanks TIG,
                      I followed your method, which is very clear and detailed:
                      def self.methode1
                            path = Sketchup.find_support_file("cube.skp",
                            "Plugins/TesteCube/Components/")
                            component_definition = definitions.load(path)
                            point = Geom;;Point3d.new(0, 0, 0)
                            transformation = Geom;;Transformation.new(point)
                            else
                            definition.instances[1..-1]{|i| i.erase! }
                            else
                            instance = model.entities.add_instance(component_definition, transformation)
                            status = instance.locked = true
                            layers = model.layers
                            new_layer = layers.add "cube"
                            new_layer.visible = false
                            instance.layer = new_layer
                            instance.hidden = true
                            Sketchup.active_model.import(@@path_to_00)
                      I get this error message at the launch of SketchUp:
                      Error Loading File C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube/logic.rb
                      Error: #<SyntaxError: C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube/logic.rb:30: syntax error, unexpected { arg, expecting keyword_end
                      C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube/logic.rb:30: syntax error, unexpected '}', expecting keyword_end
                      C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube/logic.rb:102: syntax error, unexpected end-of-input, expecting keyword_end>
                      C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load'
                      C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube.rb:28:in register_extension' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube.rb:28:in module:TesteCube'
                      C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TesteCube.rb:18:in `<top (required)>'
                      I made a mistake somewhere?
                      Thank you
                      • TNTDAVIDT Offline
                        TNTDAVID
                        Wonderful 😍 😍 😍
                        If I delete this line of code:
                        Your method works great TIG! 👍
                        Do you know why the line of code that is intended to deleted "cube", does not?
                        Many thanks for your help.
                        David
                          Dan Rathbun
                          Use:
                          definition.instances[1..-1].each {|i| i.erase! }
                            kaas
                            Also have a look at this section in the picture.
                            My suggestion is: add more puts statements into your code to quickly find the problems (yourself).
                            Edit: where are you declaring definitionanyway??
                              Sorry about the typo - substitute Dan's .each{ correction.
                              I have edited the original post to suit !
                              Also I used the reference ' definition' BUT you then used ' component_definition'
                              Please try to match such references when you are given 'generic' code...
                              Why did you not follow my example more closely [except for the stupid typo!] ???
                              PS: @Kaas is actually wrong it IS = NOT == because
                              if definition = definitions[...
                              With the = test you are trying to set the reference ' definition' to be pointing to something 'by name' in definitions - if that fails then you get nil returned, so then the else part of the test runs...
                              A == test is for 'equality' of two items, and not for testing if setting a reference works...
                              • TNTDAVIDT Offline
                                TNTDAVID
                                I took note of all your comments. 😉
                                This is not very important but the code, do not remove the "cube", if there is more than one.
                                elsif component_definition.instances.length> 1
                                         component_definition.instances [1 .. -1] .each {| i | i.erase! }
                                         component_definition.instances instance = [0]
                                You know why?
                                Thank you
                                David
                                  It's wrongly formed, reread what you have typed it does not make sense.
                                  Try this...
                                  elsif component_definition.instances.length > 1
                                    component_definition.instances[1..-1].each{|i| i.erase! }
                                    instance = component_definition.instances[0]
                                  I am assuming that all of your references to the cube's definition now use 'component_definition' rather than 'definition' ?
                                  You cannot copy / paste snippets of code in a different sequence and hope that it will somehow work.
                                  The first part of your code is also carried over from your earlier version and does NOT do what I asked you to do.
                                  It always loads the path, but you ought to check if the definition exists and then load it if not.
                                  Try following my code more closely, and remove your earlier steps which pre-load the cube before checking if it's loaded !
                                    kaas
                                    @tig said:
                                    ...PS: @Kaas is actually wrong it IS = NOT == because
                                    Thanks TIG. Learned something here.
                                    • TNTDAVIDT Offline
                                      TNTDAVID
                                      I think yes :
                                      def self.methode00
                                           if component_definition = definitions['cube']
                                           else
                                           component_definition = definitions.load(path_to_cube.skp)
                                           if component_definition.instances.length == 1
                                           component_definition.instances [1..-1] .each {| i | i.erase! }
                                           else
                                      Sorry for silly mistakes, but i am just beginning to understand the logic of the ruby.
                                      I'm a simple Carpenter by training, then learn the ruby is not easy for me.
                                      I Thank You for your understanding and your indulgence.
                                      David
                                        The initial
                                        is NOT needed.
                                        remove it, and retry.
                                        • TNTDAVIDT Offline
                                          TNTDAVID
                                          @tig said:
                                          The initial
                                          is NOT needed.
                                          If I delete this line, the cube is no longer imported. đŸ˜Č
                                          Another area of research:
                                          Is it possible to activate a tool SketchUp, with an icon from my toolbar?
                                          I would like to activate the tool, "Interact with Dynamic Components" and the window of "Components Options".
                                          How to change the value of an attribute of a dynamic component, by clicking on an icon?
                                          Thank you in advance for your lights.
                                          David
                                            The reason it's not loading is that the if...else...end test fails because you have not edited it properly:
                                            The line
                                            should actually be
                                            Of course you can do all of what you outline by setting up appropriate code.
                                            e.g. if you have a selected DC instance then a button click could change an attribute and then refresh the DC, but all of this is complex - we already have enough issues getting the cube.skp loaded !
                                            • 3 / 4
