    Automatically load a component.
    70 Posts 5 Posters 12.2k Views 5 Watching
    • K
      kaas
      The error points you into the right direction: Error: #<NameError: undefined local variable or methodentities' for TNTDAVID::ClickWindow3D_Trial_mm:Module>`
      My guess is, the error refers to:
      instance = **entities**.add_instance(component_definition, transformation)
      If you change that line to:
      instance = model.entities.add_instance(component_definition, transformation)
      you might have more luck.
        @Kaas is correct.
        Try...
        entities = model.active_entities instance = entities.add_instance(component_definition, transformation)
        There have been so many iterations of your code fragments across two threads it becomes hard to keep track !
        • TNTDAVIDT
          TNTDAVID
          It works 😍 😍 😍
          Many Thanks, TIG, kaas and Dan Rathbun.
          Anyone can download HERE, the "RBZ".
          Here is the magic code:
          module TesteCube
            module CubeImport
              def self.auto_run_code()
                path = Sketchup.find_support_file("cube.skp",
                "Plugins/TesteCube/Components/")
                model = Sketchup.active_model
                definitions = model.definitions
                component_definition = definitions.load(path)
                point = Geom;;Point3d.new(10, 20, 30)
                transformation = Geom;;Transformation.new(point)
          We just reach the first goal!
          There remain two to accomplish:
            **1.How to run the code on each new scenes?**
          Currently only the launch SketchUp, triggers the code that import the "cube.skp".
            **2. How to lock or hide the cube, to avoid copying or unintended deletions?**
          More the cube is protected, more "Dynamic Components" related also. 😉
          Thank you for your Help.
          Cordially
          David
          [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
          • TNTDAVIDT
            TNTDAVID
            To lock my "[b]cube.stp", you just add this line:[/b]
            status = instance.locked = true #### Locks the cube.
            layers = model.layers
            new_layer = layers.add "cube" #### Create a new layer "cube".
            new_layer.visible = false #### Hides the "cube" layer.
            I can not find how to add the new layer on my cube!
            You have an idea ?
            Thank you
              That's the easy bit !
              instance.layer = new_layer
              You could also lock it, so that its harder to delete if someone activates that layer later
              You can also hide it for good measure, so it's harder to find if !
              instance.hidden = true
              However, nothing is foolproof...
              Layers > 'Cube' > ON shows it...
              View > Hidden Geometry > ON shows it...
              Select instance and right-click > Unlock > Unlocks it...
              Select instance and right-click > Unhide > Shows fully it...
              Hit delete > to remove it...
              or Open Component Browser find 'Cube' and use context-menu to delete its definition, when prompted accept...
              or Layers > Delete 'Cube' and accept to delete all entities using it...
              • TNTDAVIDT
                TNTDAVID
                Thank you TIG it works perfectly!
                The most important is to prevent the accidental suppresion.
                Same CleanUp does not remove my cube. 💚
                Protection against copying is not good.
                Is there a solution to make my cube inaccecible from SketchUp?
                For example, do not display the "cube" layer in the Layers window?
                %(#FF0000)[**
                It still remains a very important objective to accomplish:**]
                How do I load my "Plugin" has every opening a SketchUp file?
                I doubt that it will be harder to find!
                Thank you in advance for your help.
                David
                • TNTDAVIDT
                  TNTDAVID
                  Hello everyone. ☀
                  As my last objective seems difficult, I return to my first idea.
                  Instead of automatically import the "cube.skp" on each new SketchUp scene.
                  The "cube" will be imported along with the first "Dynamic Component".
                  Here is the modified code and that works:
                  module TesteCube
                    module CubeImport
                        path_to_components = File.join(File.dirname(__FILE__), 'Components')
                        @@path_to_00 = File.join(path_to_components, 'Dynamic Component.skp')
                        @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')
                      def self.methode1
                        point = Geom;;Point3d.new(0, 0, 0)
                        Sketchup.active_model.import(@@path_to_00)
                      if !file_loaded?(__FILE__)
                        su_menu = UI.menu("Plugins")
                        cc_menu = su_menu.add_submenu(%Q(Teste_Cube))
                        tb = UI;;Toolbar.new(%Q(Teste-Cube))
                        command1 = UI;;Command.new("add Dynamic Component"){ CubeImport.methode1 }
                        command1.small_icon = File.join(@@path_to_resources,"add_00.png")
                        command1.large_icon = File.join(@@path_to_resources,"add_00.png")
                        command1.tooltip = %Q(add Dynamic Component)
                        command1.status_bar_text = %Q(add Dynamic Component)
                        command1.menu_text = %Q(add Dynamic Component)
                        cc_menu.add_item(command1)
                        tb.add_item(command1)
                        tb.restore
                        file_loaded(__FILE__)
                  Notice that "method1" to one more line to import "Dynamique. Component.skp"
                  at the same time that the "cube.skp".
                  The line of code with the more interest to me is:
                  command1 = UI::Command.new("add cube") { CubeImport.methode1 }
                  She created a new icon { that triggers methode1 }.
                  If I click once on the icon:
                  methode1 will import "1 cube" + "1 component Dynamic".
                  If I click ten times on the icon:
                  method1 will import "10 cubes" + "10 Dynamic Components".
                  That's exactly my problem ❗
                  I do need a single "cube", with no restrictions on the number of "Dynamic Components".
                  How to limit the amount of cube imported at "1" ?
                  Through links provided by DanRathbun and especially "Ruby in twenty minutes",
                  I understand better now the ruby. 😍
                  But this is not sufficient to finalize my code as a great.
                  Cordially
                  David
                  • TNTDAVIDT
                    TNTDAVID
                    To limit the amount of cube to import, I found this method:
                    ComponentInstance.manifold?
                    This is the method that can meet my expectations?
                    I tried many things and it does not work:
                    instance.componentinstance.manifold instance = false
                    instance = componentinstance.manifold?
                    instance.componentinstance.manifold = false
                    status = istance.componentinstance.manifold?
                    status.componentinstance.manifold = false
                    componentinstance.manifold status = false
                    instance.componentinstance.manifold status = false
                    Nothing works !
                    And all methods that are following this method are not executed.
                    I need your help more than ever.
                    Thank you
                    David
                    • K
                      kaas
                      Manifold is used for testing if its a solid or not. Not the right tool for your problem.
                      So you just need 1 cube in the model: you have linked the 'cube' to 'path' and you refer to it as 'component_definition'. You insert the cube using:
                      Why not create a small test and see if an instance is already in the model and if so - don't load it again. Replace the above line with these lines:
                      in_scene=false
                      definitions.each{|d|
                      	if d.name == 'cube'
                      		c = d.count_used_instances
                      		in_scene = true if c > 0
                      if !in_scene
                        You seem to be misunderstanding how some things [many things!] work.
                        !!! .manifold? is NOT what you need it's for testing if a group or instance is a a 'solid' - e.g. for 3d printing.
                        When your extension starts to load the FIRST DC it initially adds 'definition'.
                        AND it then adds an 'instance' of that.
                        Subsequent DC loads should also check in case the definition or instance are not present...
                        if definition.valid?
                          if instance.valid? ###[or perhaps || definition.instances[0] ???]
                            ### You are already set to do the DC load...
                          else
                            ### You need to add an instance - perhaps it's been deleted by the user ???
                            ### NOW you are set to do the DC load...
                        else ### definition is NOT valid - it's been deleted - so the instance has too.
                          ### You load the definition AND add the instance again - seems like the user has deleted both !
                        A certain logic is needed in thinking through the coded steps...
                          Following @Kaas's useful input...
                          I am unclear as to whether you want one 'cube' instance in each model or in each scene or in each entities-context ???
                          If you only ever need one then it's easily done, otherwise it gets more convoluted [but still do-able]...
                          • TNTDAVIDT
                            TNTDAVID
                            @kaas said:
                            Pourquoi ne pas créer un petit test et voir si une instance est déjà dans le modÚle et si oui - ne pas le charger à nouveau. Remplacer la ligne ci - dessus avec ces lignes:
                            CODE PROMO: SÉLECTIONNER TOUT
                            in_scene=false
                               if d.name == 'cube'
                            if !in_scene
                            Like this?
                            module TesteCube
                              module CubeImport
                                def self.methode1
                                  in_scene=false
                                  if d.name == 'cube'
                                  if !in_scene
                                  command1.tooltip = %Q(add Sliding Window)
                                  command1.status_bar_text = %Q(add Sliding Window)
                                  command1.menu_text = %Q(add Sliding Window)
                                  tb.restore
                            When I click on my icon, nothing happens.
                            I made a mistake ?
                            I want one cube for each SketchUp scene!
                            Thank you for your help.
                              Maybe this concept will more clear ! 😄
                              The mysterious thing for me is how to avoid the list of components (even hidden)
                              on the Onliner ? 😉
                              Bon courage!
                              • Dan RathbunD
                                Dan Rathbun
                                My response is why use a hidden geometric construct to "protect" other components ?
                                I would instead use an AttributeDictionary.
                                I'm not here much anymore.
                                • K
                                  kaas
                                  @tntdavid said:
                                  ...When I click on my icon, nothing happens....
                                  Not sure. Maybe you already have an instance of the component present in your model? Its easy to find out by debugging. Add just one line in this loop:
                                      if d.name == 'cube'
                                  		puts %(there are #{c} instances in the model of cube)
                                  This code won't help you though if you want to have just 1 cube per scene. That would make the code more complex.
                                  Edit: Dan's suggestion might be just what you need. Its the only way to really hide data.
                                  • TNTDAVIDT
                                    TNTDAVID
                                    Pilou thank you for your clearer picture that my writings. 😛
                                    Because of my English very bad, I think I lacked clarity.
                                    I want a single cube by Sketchup file.
                                    In Sketchup file, you can have a complete project with many dynamic components, but you have a single cube!
                                    No instance is present in my file. 😕
                                    To test the code, you can download the extension HERE.
                                    It's complicated to automatically remove a "cube", when there are 2?
                                    Thank you for this information, I must annalyser this "class" with attention. 👍
                                    With the methods provided by this class, is it possible to make a dynamic component unusable without the presence of the extension?
                                    For example :
                                    If someone shares one of my dynamic components with a user without my extension, it must be impossible to use these dynamic features!
                                    I want to go at the end of my research, because my final interest is not only the security of my dynamic components.
                                    Thank you for your support
                                    David
                                      So to paraphrase...
                                      You want to have your cube component loaded into the model's definitions.
                                      You want to have ONE instance of it placed in the model.
                                      That instance should be 'masked' - e.g. assigned a special OFF layer, be hidden and be locked.
                                      [Aside: You could also make it so tiny that if was hard to find !]
                                      All this is readily done.
                                      My example test code, checks if the definition is loaded and if not it loads it.
                                      If it id loaded and there is an instance there is nothing more to do, otherwise it adds the instance...
                                      I agree with Dan...
                                      All of the messing on so far could be achieved by more subtle and less complex means.
                                      It probably needs a separate thread...
                                      However, here's my outline.
                                      Your plugin code loads DC components.
                                      It's possible to give a DC component a function which stops it working if the function fails.
                                      Your RB code could add a new function to the DC functions-code in the model, as it loads.
                                      Thereby your RB makes your special DCs usable.
                                      If a recipient of your DC does not have your licensed RB loading, then your DC does not work for them.
                                      The absence of your extra DC function to validate your DC could also be triggered when a users license expires.
                                      Here's an example of an extra DC function your RB could add...
                                      require('sketchup')
                                      if Sketchup.version.to_i <= 8
                                      	require('dynamiccomponents.rb')
                                      else
                                      	require('su_dynamiccomponents.rb')
                                      if defined?($dc_observers)
                                        ### Open SketchUp's Dynamic Component Functions (V1) class.
                                        ### BUT only if DC extension is active...
                                      	class DCFunctionsV1
                                      		protected
                                      		unless DCFunctionsV1.method_defined?(;tnt_checker)
                                      			def tnt_checker()
                                      				return true
                                      			protected;tnt_checker
                                      			### Usage; =tnt_checker()
                                      	end#class
                                      end#if
                                      Your main RB adds this extra function.
                                      Within each of your DCs you use the extra function to set up a reference etc.
                                      Usage: =tnt_checker()
                                      It returns true if the RB has added the function of false/or fails otherwise...
                                      Unfortunately even that could be circumvented by a Pro user editing the DCs attributes, BUT if your DC code is convoluted enough and it relies on the =tnt_checker() function's value being true to perform its later functions, then it at least makes the DC much more difficult to 'pirate'...
                                      They could also write their own code RB snippet to set up that function and always return true ?
                                      • Dan RathbunD
                                        Dan Rathbun
                                        There is no way to make it impossible.
                                        If you must use a DC function try to use a refinement for Ruby 2.0+.
                                        Code example withdrawn. A refinement will not work, because the DC code files would themselves need to use the refinement.
                                        • Modifying the DCFunctionsV1 class may not pass inspection by the Trimple Developer extension signing page.
                                        • TNTDAVIDT
                                          TNTDAVID
                                          Very good idea. 👍
                                          We can also hide the edges of a model?
                                          You talk about this example?
                                            else
                                          @tig said:
                                          I agree with Dan...
                                          I do not doubt for a moment of your words.
                                          As my specialty are dynamic components, create a protection directly into the models is much easier for me.
                                          Although my protection is not foolproof, it will be very difficult to circumvent.
                                          Thanks for these informations ❗
                                          • TNTDAVIDT
                                            TNTDAVID
                                            Hello,
                                            I still can not limit the number of cube to 1. 😕
                                            If someone can give me more information on writing code, I would be very recognize him.
                                            Thank you
                                            David
                                            • 2 / 4
