    Automatically load a component.
    70 Posts 5 Posters 12.2k Views 5 Watching
      path = Sketchup.find_support_file("cube.skp", "Components")
      either returns nil [no match]
      or if it matches, something like
      "C:\\Program Files\\SketchUp\\SketchUp 2015\\Components\\cube.skp"
      To check if it works use:
      puts "path = #{path}"
      and
      puts "path exist? #{File.exist?(path)}"
      as it runs, or in the code itself, to abort early...
      (UI.messagebox("Path does not exist\n#{File.exist?(path)}"); return nil) unless path && File.exist?(path)
      I expect in the 'real' code you are setting the path to a skp in a components-subfodler within the extension's own subfolder - found using __FILE__ to get the rb's folder path etc...
      • TNTDAVIDT
        TNTDAVID
        I added "cube.skp" in "Components Sampler" folder, there is always the same error message.
        http://zupimages.net/up/16/41/i14l.jpg
        module TNTDAVID
          module ClickWindow3D_Trial_mm
            def self.auto_run_code()
              path = Sketchup.find_support_file("cube.skp", "Components/Components Sampler")
              model = Sketchup.active_model
              definitions = model.definitions
              component_definition = definitions.load(path)
              point = Geom;;Point3d.new(10, 20, 30)
              transformation = Geom;;Transformation.new(point)
              instance = entities.add_instance(component_definition, transformation)
        Error Loading File C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb
        Error: #<NameError: undefined local variable or method entities' for TNTDAVID::ClickWindow3D_Trial_mm:Module> C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:10:in auto_run_code'
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:12:in <module:ClickWindow3D_Trial_mm>' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:2:in module:TNTDAVID'
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:1:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
        C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:28:in register_extension'
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:28:in <module:ClickWindow3D_Trial_mm>' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:18:in <top (required)>'
        Why, there's always this error message?
        @tig said:
        I expect in the 'real' code you are setting the path to a skp in a components-subfodler within the extension's own subfolder - found using FILE to get the rb's folder path etc...
        I can use the File method to import a component from an icon.
          class << self
            path_to_components = File.join(File.dirname(__FILE__), 'Components')
            @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp')
            def add_00
              Sketchup.active_model.import(@@path_to_00)
        if !file_loaded?(__FILE__)
                tb = UI;;Toolbar.new(%Q(Click-Window3D-Trial-mm))
                command1 = UI;;Command.new("add Resources"){ ClickWindow3D_Trial_mm.add_00 }
                command1.small_icon = File.join(@@path_to_resources,"add_00.png")
                command1.large_icon = File.join(@@path_to_resources,"add_00.png")
                tb.add_item(command1)
                tb.restore
                file_loaded(__FILE__)
        How to change the code so that "cube.skp" is automatically imported on each SketchUp scene?
        Thank you
        [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
        • Dan RathbunD
          Dan Rathbun
          @tntdavid said:
          The only thing I find about "String Object" is on this page:
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/string
          David, The SketchUp Ruby API is an extension to standard Core Ruby, and
          adds a few methods to the Ruby's core String class:
          http://ruby-doc.org/core-2.0.0/String.html
          You need to learn standard Ruby before you can really appreciate what SketchUp's API adds to Ruby.
          Here is a set of lists that will help (at the official SketchUp forum):
          [url=http://forums.sketchup.com/t/ruby-learning-resources-wikilists/22861:2epja1nk]Ruby Learning Resources [WikiLists][/url:2epja1nk]
          (There is similar, but perhaps older list, here ar SCF as well.)
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            David, code files need to be encoded as UTF-8 without BOM (BOM = Bit Order Mark.)
            The first line of all SketchUp code files should also always be the "magic comment":
            # encoding: UTF-8
            See: Ruby Core docs: Encoding - Script encoding
            • TNTDAVIDT
              TNTDAVID
              Hello, kaas 😄
              My "cube.skp" is in the "Components" folder in my plugin.
              It should be placed in another folder?
              You can download HERE the full fichier.rbz.
              Thank you for your help.
              cordially
              David
              Ps: Thank you for your links.
              Edit: Small error in "TesteCube.rb" corrected.
              • TNTDAVIDT
                TNTDAVID
                encoding: UTF-8
                Another thing I just learned. 😮
                Have you sample code # encoding: UTF-8?
                I supose that my error is because of that ?
                  It's a good idea to include that as the first line of all of your RB files.
                  But, it's not essential - if you use Notepad++ exe you can set up its preferences so that all new files you create are set to be properly encoded UTF-8 [without BOM] - which is required by the newer versions of Ruby.
                  Unfortunately the Windows bare-bones Notepad exe uses an inappropriate text encoding system - ANSI I think ?
                  And if you have an existing RB file that is encoded 'wrongly' [e.g. ANSI] you can use Notepad++ to change its encoding to UTF-8, then save it - and it should then be permanently set to that proper encoding...
                  Get Notepad++ exe v7 from here - it's free and has helpful Ruby syntax tools built in...
                  https://notepad-plus-plus.org/download/v7.html
                  There are 32 and 64 bit versions - I use the 64...
                  • TNTDAVIDT
                    TNTDAVID
                    Thank you for the download link TIG. 👍
                    I encoded my "rb" in "UTF-8", without BOM!
                    It is not the cause of the error message.
                    You can download HERE, the new "RBZ".
                    Thank you in advance for your help.
                    • K
                      kaas
                      The error points you into the right direction: Error: #<NameError: undefined local variable or methodentities' for TNTDAVID::ClickWindow3D_Trial_mm:Module>`
                      My guess is, the error refers to:
                      instance = **entities**.add_instance(component_definition, transformation)
                      If you change that line to:
                      instance = model.entities.add_instance(component_definition, transformation)
                      you might have more luck.
                        @Kaas is correct.
                        Try...
                        entities = model.active_entities instance = entities.add_instance(component_definition, transformation)
                        There have been so many iterations of your code fragments across two threads it becomes hard to keep track !
                        • TNTDAVIDT
                          TNTDAVID
                          It works 😍 😍 😍
                          Many Thanks, TIG, kaas and Dan Rathbun.
                          Anyone can download HERE, the "RBZ".
                          Here is the magic code:
                          module TesteCube
                            module CubeImport
                                "Plugins/TesteCube/Components/")
                          We just reach the first goal!
                          There remain two to accomplish:
                            **1.How to run the code on each new scenes?**
                          Currently only the launch SketchUp, triggers the code that import the "cube.skp".
                            **2. How to lock or hide the cube, to avoid copying or unintended deletions?**
                          More the cube is protected, more "Dynamic Components" related also. 😉
                          Thank you for your Help.
                          Cordially
                          David
                          • TNTDAVIDT
                            TNTDAVID
                            To lock my "[b]cube.stp", you just add this line:[/b]
                            status = instance.locked = true #### Locks the cube.
                            layers = model.layers
                            new_layer = layers.add "cube" #### Create a new layer "cube".
                            new_layer.visible = false #### Hides the "cube" layer.
                            I can not find how to add the new layer on my cube!
                            You have an idea ?
                            Thank you
                              That's the easy bit !
                              instance.layer = new_layer
                              You could also lock it, so that its harder to delete if someone activates that layer later
                              You can also hide it for good measure, so it's harder to find if !
                              instance.hidden = true
                              However, nothing is foolproof...
                              Layers > 'Cube' > ON shows it...
                              View > Hidden Geometry > ON shows it...
                              Select instance and right-click > Unlock > Unlocks it...
                              Select instance and right-click > Unhide > Shows fully it...
                              Hit delete > to remove it...
                              or Open Component Browser find 'Cube' and use context-menu to delete its definition, when prompted accept...
                              or Layers > Delete 'Cube' and accept to delete all entities using it...
                              • TNTDAVIDT
                                TNTDAVID
                                Thank you TIG it works perfectly!
                                The most important is to prevent the accidental suppresion.
                                Same CleanUp does not remove my cube. 💚
                                Protection against copying is not good.
                                Is there a solution to make my cube inaccecible from SketchUp?
                                For example, do not display the "cube" layer in the Layers window?
                                %(#FF0000)[**
                                It still remains a very important objective to accomplish:**]
                                How do I load my "Plugin" has every opening a SketchUp file?
                                I doubt that it will be harder to find!
                                David
                                • TNTDAVIDT
                                  TNTDAVID
                                  Hello everyone. ☀
                                  As my last objective seems difficult, I return to my first idea.
                                  Instead of automatically import the "cube.skp" on each new SketchUp scene.
                                  The "cube" will be imported along with the first "Dynamic Component".
                                  Here is the modified code and that works:
                                  module TesteCube
                                    module CubeImport
                                        @@path_to_00 = File.join(path_to_components, 'Dynamic Component.skp')
                                        @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')
                                      def self.methode1
                                        point = Geom;;Point3d.new(0, 0, 0)
                                        su_menu = UI.menu("Plugins")
                                        cc_menu = su_menu.add_submenu(%Q(Teste_Cube))
                                        tb = UI;;Toolbar.new(%Q(Teste-Cube))
                                        command1 = UI;;Command.new("add Dynamic Component"){ CubeImport.methode1 }
                                        command1.tooltip = %Q(add Dynamic Component)
                                        command1.status_bar_text = %Q(add Dynamic Component)
                                        command1.menu_text = %Q(add Dynamic Component)
                                        cc_menu.add_item(command1)
                                        tb.restore
                                  Notice that "method1" to one more line to import "Dynamique. Component.skp"
                                  at the same time that the "cube.skp".
                                  The line of code with the more interest to me is:
                                  command1 = UI::Command.new("add cube") { CubeImport.methode1 }
                                  She created a new icon { that triggers methode1 }.
                                  If I click once on the icon:
                                  methode1 will import "1 cube" + "1 component Dynamic".
                                  If I click ten times on the icon:
                                  method1 will import "10 cubes" + "10 Dynamic Components".
                                  That's exactly my problem ❗
                                  I do need a single "cube", with no restrictions on the number of "Dynamic Components".
                                  How to limit the amount of cube imported at "1" ?
                                  Through links provided by DanRathbun and especially "Ruby in twenty minutes",
                                  I understand better now the ruby. 😍
                                  But this is not sufficient to finalize my code as a great.
                                  Cordially
                                  David
                                  • TNTDAVIDT
                                    TNTDAVID
                                    To limit the amount of cube to import, I found this method:
                                    ComponentInstance.manifold?
                                    This is the method that can meet my expectations?
                                    I tried many things and it does not work:
                                    instance.componentinstance.manifold instance = false
                                    instance = componentinstance.manifold?
                                    instance.componentinstance.manifold = false
                                    status = istance.componentinstance.manifold?
                                    status.componentinstance.manifold = false
                                    componentinstance.manifold status = false
                                    instance.componentinstance.manifold status = false
                                    Nothing works !
                                    And all methods that are following this method are not executed.
                                    I need your help more than ever.
                                    Thank you
                                    David
                                    • K
                                      kaas
                                      Manifold is used for testing if its a solid or not. Not the right tool for your problem.
                                      So you just need 1 cube in the model: you have linked the 'cube' to 'path' and you refer to it as 'component_definition'. You insert the cube using:
                                      Why not create a small test and see if an instance is already in the model and if so - don't load it again. Replace the above line with these lines:
                                      in_scene=false
                                      definitions.each{|d|
                                      	if d.name == 'cube'
                                      		c = d.count_used_instances
                                      		in_scene = true if c > 0
                                      if !in_scene
                                        You seem to be misunderstanding how some things [many things!] work.
                                        !!! .manifold? is NOT what you need it's for testing if a group or instance is a a 'solid' - e.g. for 3d printing.
                                        When your extension starts to load the FIRST DC it initially adds 'definition'.
                                        AND it then adds an 'instance' of that.
                                        Subsequent DC loads should also check in case the definition or instance are not present...
                                        if definition.valid?
                                          if instance.valid? ###[or perhaps || definition.instances[0] ???]
                                            ### You are already set to do the DC load...
                                          else
                                            ### You need to add an instance - perhaps it's been deleted by the user ???
                                            ### NOW you are set to do the DC load...
                                        else ### definition is NOT valid - it's been deleted - so the instance has too.
                                          ### You load the definition AND add the instance again - seems like the user has deleted both !
                                        A certain logic is needed in thinking through the coded steps...
                                          Following @Kaas's useful input...
                                          I am unclear as to whether you want one 'cube' instance in each model or in each scene or in each entities-context ???
                                          If you only ever need one then it's easily done, otherwise it gets more convoluted [but still do-able]...
                                          • TNTDAVIDT
                                            TNTDAVID
                                            @kaas said:
                                            Pourquoi ne pas créer un petit test et voir si une instance est déjà dans le modèle et si oui - ne pas le charger à nouveau. Remplacer la ligne ci - dessus avec ces lignes:
                                            CODE PROMO: SÉLECTIONNER TOUT
                                            in_scene=false
                                               if d.name == 'cube'
                                            if !in_scene
                                            Like this?
                                            module TesteCube
                                              module CubeImport
                                                def self.methode1
                                                  in_scene=false
                                                  if d.name == 'cube'
                                                  if !in_scene
                                                  command1.tooltip = %Q(add Sliding Window)
                                                  command1.status_bar_text = %Q(add Sliding Window)
                                                  command1.menu_text = %Q(add Sliding Window)
                                                  tb.restore
                                            When I click on my icon, nothing happens.
                                            I made a mistake ?
                                            I want one cube for each SketchUp scene!
                                            • 1 / 4
