    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 262.9k Views 123 Watching
      Even large objects can still contain some small triangulated facets.
      These can in turn 'intersect' during boolean operations to make potentially very very tiny facets.
      If these would have very short edges, then they'll still fail to form ad cause 'holes' etc, and non-solids result...
      • N Offline
        nongcc
          leo11
          Hi, can this plugin suit Sketchup 2015? I installed it, but it doesn't work ! 😲 I liked it so much when it used to work, back in SU 8... Can you do something ?
            acxone
            Is this plugin compatible with SU2015 now?
              @acxone said:
              No.
              It works with <= v2013 only...
              • N Offline
                NutsandBoltz
                This thread's probably dead, but in case it's not, I could really use a good boolean plugin right now, and OSCoolean still isn't compatible with the current version of Sketchup. Anyone have an idea of an alternative plugin?
                • gudio83G Offline
                  gudio83
                  Yes will be great if the author update the plugin to SU2016. I am looking for alternative in the same time, but no results. This plugin its a missing tool in Sketchup!
                    you have for moment the alternative to use the Viz Plugin trying period! 😉
                      tmt0009
                      Any update on this plugin? I'm using SketchUp Make because I can't justify getting a Pro license in my own mind yet. This would definitely help.
                      • F Offline
                        fluid
                        We just released Bool extension, featuring interactive boolean operations and hierarchical constructive solid geometry (CSG). You can try if here.
                        [flash:3mbvlufg]https://www.youtube.com/v/nU9s4WQKI90[/flash:3mbvlufg]
                        • PixeroP Offline
                          Pixero
                          Wow!
                            concord264
                            It does not work for me!! why?
                            I have make 2017!!
                              It's a very old script.
                              It's not supported by its author.
                              It's unlikely to work with newer SketchUp versions...
                              Search - there are several similar but newer tools now available.
                              • N Offline
                                Nearlyman
                                many thanks for this plugin. Regrettably, even though the install was “confirmed” according to the response I was unable to locate this extension even after restarting my win 10 PC. Importantly, I installed from download file: access to ‘extension warehouse’ failed due to a message statement “there is a script error on this page” with entries involving 1’s and 0’s among other meaningless dialogue. Where should this plug in appear? I am installing on the 2013 version of Sketchup Make.
                                reply if possible please to : bowderynman@gmail.com,
                                  @nearlyman said:
                                  I installed from download file: access to ‘extension warehouse’ failed due to a message statement “there is a script error on this page”...
                                  The Extension Warehouse hasn't supported SketchUp 2013 for a number of years.
                                  As TIG wrote in the post immediately before yours, this extension hasn't been supported. There are other options available, though.
                                  • 12
                                  • 13
                                  • 14
                                  • 15
                                  • 16
                                  • 15 / 16
