    Import 2 components with a single icon.
    20 Posts 3 Posters 2.2k Views 3 Watching
    • TIGT Online
      Unfortunately your code makes little sense.
      Try using a p or puts in front of the reference setting line[s] so you can see what is going on in the Ruby Console...
      ` p path_to_components = File.join(File.dirname(FILE), 'Components')
      "The_user_path_to/Plugins/Your_Extension/Components"
      p @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp')
      "The_user_path_to/Plugins/Your_Extension/Components/00-Control-Panel-Trial-mm.skp"
      p @@path_to_00 = File.join(path_to_components,'Componant1.skp','Componant2.skp')
      "The_user_path_to/Plugins/Your_Extension/Components/Componant1.skp/Componant2.skp"`
      So obviously the file does NOT exist... 😮
      You need to sort out the paths so they are defined properly...
      This is quite basic stuff...
      So I suspect that you are just too close to your code to be able to step back and see the wider picture...
      Using temporary p or puts as you define references to things help you see where your thinking has gone astray...
      • TNTDAVIDT Offline
        TNTDAVID
        TIG thank you for your help. 😄
        So I changed my code like this:
        module ClickWindow3D_Trial_mm
          class << self
                p path_to_components = File.join(File.dirname(__FILE__), 'Components')
                >>> "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components"
                "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp"
                p @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm')
                "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp\02-Sliding-Window-Trial-mm"
                @@path_to_00 = File.join(path_to_components, '00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm.skp')
                @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')
            def add_00
              Sketchup.active_model.import(@@path_to_00)
        if !file_loaded?(__FILE__)
                tb = UI;;Toolbar.new(%Q(Click-Window3D-Trial-mm))
                command1 = UI;;Command.new("add Resources"){ ClickWindow3D_Trial_mm.add_00 }
                command1.small_icon = File.join(@@path_to_resources,"add_00.png")
                command1.large_icon = File.join(@@path_to_resources,"add_00.png")
                command1.tooltip = %Q(add Resources)
                command1.status_bar_text = %Q(add Resources)
                tb.add_item(command1)
                tb.restore
                file_loaded(__FILE__)
        Unfortunately I obtien this error message:
        Error Loading File C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb
        Error: #<SyntaxError: C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:7: syntax error, unexpected >>, expecting keyword_end
        >>> "C:\Users\DAVID\AppData\Roa...
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:7: Invalid escape character syntax
        ...ns\TNT_ClickWindow3D_Trial_mm\Components"
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:9: Invalid escape character syntax
        ...ns\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Tr...
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:10: syntax error, unexpected >>, expecting keyword_end
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:12: syntax error, unexpected >>, expecting keyword_end
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:13: Invalid escape character syntax
        C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load'
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:28:in register_extension' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:28:in module:ClickWindow3D_Trial_mm'
        C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:18:in `<top (required)>'
        What was I doing wrong? 😲
        Thank you in advance for your help.
        Cordially
        David
        [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
        • TIGT Online
          It's all wrong !
          Where I wrote >>> ".... I was showing what the output of the set reference would be in the Ruby Console from the 'p ' command.
          Remove all of those early lines in the class's body
          Also you should probably set up the menu code in the module not within the class itself ??
          Obviously the loose >>> etc throws an error when it's read directly within the class's code !
          You have also not corrected the error in the path set up.
          Will return:
          C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp\02-Sliding-Window-Trial-mm.skp
          which clearly will NOT exist !
          Which concatenate TWO skp file names in this way ?
          • TNTDAVIDT Offline
            TNTDAVID
            Thank you for your prompt response.
            @tig said:
            It's all wrong !
            Sorry, I discovered the ruby so I am very bad. 😳
            Like this ?
            @@path_to_00 = File.join(path_to_components,'02-Sliding-Window-Trial-mm.skp')
            "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\02-Sliding-Window-Trial-mm.skp"
            Can you show an example?
            I have to write this?
            @@path_to_00 = File.join(C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components,'00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm.skp')
            @tig said:
            Will return:
            Sorry, it also seemed impossible!
            I wanted to follow this example:
            @tig said:
            " The_user_path_to / Plugins / Your_Extension / Composants /Componant1.skp/Componant2.skp "
            Thank you for your help.
            • TIGT Online
              NO.
              Do not add any raw text into the class's body.
              So it'll become
              @@path_to_02 = File.join(path_to_components,'02-Sliding-Window-Trial-mm.skp')
              Now you have a reference to ' path_to_components' and using that, then the paths for the TWO SKP files...
              @@path_to_00
              and
              @@path_to_02
              Why do you think that [note how I added the '...']:
              @@path_to_00 = File.join('C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components', '00-Control-Panel-Trial-mm.skp', '02-Sliding-Window-Trial-mm.skp')
              would work ??
              It'll give the file-path:
              C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/00-Control-Panel-Trial-mm.skp/02-Sliding-Window-Trial-mm.skp
              which clearly doesn't exist !!!
              Whereas the revised code [above] gives...
              @@path_to_00
              as C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/00-Control-Panel-Trial-mm.skp
              and
              @@path_to_02
              as C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/02-Sliding-Window-Trial-mm.skp
              which we might assume do exist ???
              PS: Note how the \ and / file-separators appear - best to fix on / ...
              perhaps fix those with path_string.tr!("\\","/") as you go...
              • TNTDAVIDT Offline
                TNTDAVID
                If I understand correctly, the code should look like this:
                  class << self
                    def add_00
                      Sketchup.active_model.import(@@path_to_02)
                        tb.restore
                With this code, the only component of "@@ path_to_02" is imported by the icon. 😕
                Yes, the existing models.
                perhaps fix those with path_string.tr!("\","/") as you go...
                Thank you for this tip. 👍
                Instead of importing 2 components with a icon.
                Can we automatically import a component on boot up SketchUp with a "rb"?
                Is it possible to make invisible to the user, with no way to display the component from SketchUp?
                If possible, how the code should he be writing?
                Thank you
                David
                • TIGT Online
                  I'm sorry but your coding is bonkers to me.
                  What are you smoking ?
                  command1 = UI::Command.new("add Resources"){ ClickWindow3D_Trial_mm.add_00 }should import both SKP files, BUT only if they exist...
                  So to test your code YOU need to add some simple steps within it...
                  For example some p or puts for the returned state as you set various paths,
                  also testing for File.exist?(some_file_path)
                  To be frank. for someone who is publishing extensions this is a surprisingly poor show...
                  I can't see what is so difficult in this process.
                  You seem to to be making things far more complicated than they need to be...
                  • TNTDAVIDT Offline
                    TNTDAVID
                    Rest assured, this code is crazy for me too! 💚
                    But as crazy as it is, it works :
                    http://i.imgur.com/wc8ScTp.gif
                    Smoking is bad for health, so I like to drink. 😛
                    Can you show an example, I can test?
                    I am sad to disappoint you, but I started in ruby. 😞
                    My extensions work 99%, with "Dynamic Components", and 1% of ruby, to create a simple toolbar.
                    Thank you for your franchise.
                    You definitely right!
                    Can show me a simple example for the same result?
                    Cordially
                    David
                    • TIGT Online
                      I already showed how to set up distinct references etc and you replied.
                      http://sketchucation.com/forums/viewtopic.php?p=604766#p604766
                      To check if the two paths are correct try:
                      puts "#{@@path_to_00} = #{File.exist?(@@path_to_00)}"
                      puts "#{@@path_to_02} = #{File.exist?(@@path_to_02)}"
                      Perhaps this would also be better to definitely avoid the prompt..
                      Sketchup.active_model.import(@@path_to_00, false) Sketchup.active_model.import(@@path_to_02, false)
                      • TIGT Online
                        Having thought this over...
                        Assuming both SKP files exist...
                        I think the issue is caused by your use of the model.import(path_to_skp) method.
                        The first run of the import forks off to another process, where you insert/move the instance of the imported file - thus the second import never starts as it's effectively cancelled by the first one.
                        There are other ways of doing this...
                        defn = model.definitions.load(path_to_skp)
                        adds the SKP to the model's definition,
                        then you can use other methods to insert it into the model.
                        entities.add_instance(defn, transformation)
                        Or use the alternative
                        model.place_component(defn)
                        You could also make your class a Tool and after adding the instance[s] use your tool to move the instance to a new location...
                        Another alternative might be to load the two and then make a group and add the two instances to its entities ?
                        I am not entirely sure what it is you are trying to achieve ?
                        A simpler way might even be to combine the two components into one new SKP and import than ?
                        • TNTDAVIDT Offline
                          TNTDAVID
                          Hello,
                          I am sorry for not being clear enough.
                          As it is possible to protect all a collection of "Dynamic Components", with a single "Parent Component," I want to import the "Component Parent" along with my dynamic models.
                          Import both components with a single icon sembait like a good idea, but I found much better now.
                          I allowed myself to open a new Topic with this new idea that is totally different.
                          If you still want to help me, I'd be delighted.
                          Sorry, for the time you have wasted on this topic.
                          Cordially
                          David
                          • Dan RathbunD Offline
                            Dan Rathbun
                            Create a template model that already has your set of component definitions loaded, and then the user can use that template when they start a new model.
                            I'm not here much anymore.
                            • TNTDAVIDT Offline
                              TNTDAVID
                              I understand your reasoning.
                              But I wish maximum ease of use of my dynamic components, and simultaneously protect them.
                              If we take the example of "Click-Window 3D", the windows are useless without the "Control Panel", which is the perfect example of a component "Parent" protector.
                              If the "Control Panel" is not on the SketchUp scene, you'll have problems with my dynamic components.
                              Instead of importing the control panel manually, I want it to be imported automatically.
                              This will prevent user error, because 80% of the time the first reflex of a user is importing the "3D Window" before the "Control Panel".
                              This can lead to a crash of SketchUp. 😒
                              It is therefore urgent for me to find a solution to import the "Control Panel" automatically on each new SketchUp scene.
                              Cordially
                              David
                              • TIGT Online
                                Now you have explained your reasoning perhaps we can come up with some ideas...
                                When a user clicks on a 3d Window DC to import I assume it's through your code - perhaps a toolbar ?
                                So instead of immediately importing that DC, you could first check if your special Control Panel component definition is loaded and if so if an instance of it is placed in the current view/scene...
                                If the answer id no to either of those tests, then additional code could be run to do that step [or those steps] before moving on to import the DC.
                                As explained before, rather than importing the Control Panel you can use
                                cp = model.definitions.load(path_to_CP)
                                Then say place an instance thus
                                model.active_entities.add_instance(cp, ORIGIN)
                                Then import the Window DC ?
                                • TNTDAVIDT Offline
                                  TNTDAVID
                                  I am currently developing a version of Click-Window 3D without "Control Panel".
                                  The 3D window will be changed manually with tools, "Scale", "Interact with Dynamic Components," and "Component Options".
                                  A perfect example is my plugin, Click-Change.
                                  However, i want to keep the protection of a "Parent" component, which will be a kind of invisible activation key of my "Dynamic Components".
                                  The method used in the code is not important, only those conditions is important:
                                  *** The "Parent" component, must be imported automatically.**
                                  *** It must be on the SketchUp scene before the first dynamic component.**
                                  *** It must be invisible or locked to prevent copy.**
                                  By fulfilling these conditions, we will have a good chance of protecting our dynamic components.
                                  Your proposal meets the three conditions?
                                  Thank you
                                  David
                                  • TNTDAVIDT Offline
                                    TNTDAVID
                                    The code should look like this ?
                                        module SomeSubModule
                                            def self.do_somethings()
                                               path=Sketchup.find_support_file "cube.skp","Components"
                                               model = Sketchup.active_model
                                               definitions = model.definitions
                                               componentdefinition = definitions.load path
                                               point = Geom;;Point3d.new 10,20,30
                                               transform = Geom;;Transformation.new point
                                               instance = entities.add_instance componentdefinition, transform
                                    If not, can you show me an example?
                                    Without explanation with code examples, I do not understand you.
                                    Thank you for your patience.
                                    David
                                    • TIGT Online
                                      Please indent you code helpfully...
                                      However, even as it is, your code should 'almost' work... 😉
                                      Below, I've made a few minor adjustments, like -
                                      the () around methods' passed arguments, clearer naming etc...
                                      I have also added ### to the start of some unwanted code [that's like a ' rem' statement, as seen in some older coding conventions]
                                      module TNTDAVID
                                          def self.auto_run_code()
                                            path = Sketchup.find_support_file("cube.skp", "Components")
                                            ### let's assume that this SKP exists,
                                            ### but it does limit the search to that specific SketchUp folder -
                                            ### probably best to find it in your own subfolder of SKPs
                                            ### and have it shipped within your extension's subfolder !
                                            component_definition = definitions.load(path)
                                            point = Geom;;Point3d.new(10, 20, 30) ### these offsets are in inches !
                                            transformation = Geom;;Transformation.new(point)
                                            ### definitions = model.definitions
                                            instance = entities.add_instance(component_definition, transformation)
                                          self.auto_run_code() ### runs the code, loads the skp and places at instance...
                                      • TNTDAVIDT Offline
                                        TNTDAVID
                                        Unfortunately even with your adjustment, the code does not work yet. 😢
                                        When I launch SketchUp, nothing happens.
                                        And the "Ruby console" shipments this error message :
                                        Error: # <TypeError: no implicit conversion of nil into String>
                                        Or is the error?
                                        See you soon.
                                        David
