    Import 2 components with a single icon.
    20 Posts 3 Posters 1.9k Views 3 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      Hello, ☀
      To import a component from a new icon, this code works fine:
      module ClickWindow3D_Trial_mm
        class << self
          path_to_components = File.join(File.dirname(__FILE__), 'Components')
          @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp')
          @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')
          def add_00
            Sketchup.active_model.import(@@path_to_00)
      if !file_loaded?(__FILE__)
              tb = UI;;Toolbar.new(%Q(Click-Window3D-Trial-mm))
              command1 = UI;;Command.new("add Resources"){ ClickWindow3D_Trial_mm.add_00 }
              command1.small_icon = File.join(@@path_to_resources,"add_00.png")
              command1.large_icon = File.join(@@path_to_resources,"add_00.png")
              command1.tooltip = %Q(add Resources)
              command1.status_bar_text = %Q(add Resources)
              tb.add_item(command1)
              tb.restore
              file_loaded(__FILE__)
      How to import two different components with the same icon?
      Thank you in advance for your help.
      David
      [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
      • TNTDAVIDT Offline
        TNTDAVID
        Starting from the base code, I changed the lines of code :
        @@path_to_00 = File.join(path_to_components,'Componant1.skp','Componant2.skp')
        I get this message: File not found or invalid
        def add_00
              Sketchup.active_model.import(@@path_to_01)
        Only the model @@Path_to_01 is imported.
        Unfortunately I do not find the solution. 😞
        If someone who masters the code goes through, I would be very grateful to have help.
        Cordially
        David
        • TIGT Online
          Unfortunately your code makes little sense.
          Try using a p or puts in front of the reference setting line[s] so you can see what is going on in the Ruby Console...
          ` p path_to_components = File.join(File.dirname(FILE), 'Components')
          "The_user_path_to/Plugins/Your_Extension/Components"
          p @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp')
          "The_user_path_to/Plugins/Your_Extension/Components/00-Control-Panel-Trial-mm.skp"
          p @@path_to_00 = File.join(path_to_components,'Componant1.skp','Componant2.skp')
          "The_user_path_to/Plugins/Your_Extension/Components/Componant1.skp/Componant2.skp"`
          So obviously the file does NOT exist... 😮
          You need to sort out the paths so they are defined properly...
          This is quite basic stuff...
          So I suspect that you are just too close to your code to be able to step back and see the wider picture...
          Using temporary p or puts as you define references to things help you see where your thinking has gone astray...
          • TNTDAVIDT Offline
            TNTDAVID
            TIG thank you for your help. 😄
            So I changed my code like this:
              class << self
                    p path_to_components = File.join(File.dirname(__FILE__), 'Components')
                    >>> "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components"
                    "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp"
                    p @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm')
                    "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp\02-Sliding-Window-Trial-mm"
                    @@path_to_00 = File.join(path_to_components, '00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm.skp')
                def add_00
                    tb.restore
            Unfortunately I obtien this error message:
            Error Loading File C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb
            Error: #<SyntaxError: C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:7: syntax error, unexpected >>, expecting keyword_end
            >>> "C:\Users\DAVID\AppData\Roa...
            C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:7: Invalid escape character syntax
            ...ns\TNT_ClickWindow3D_Trial_mm\Components"
            C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:9: Invalid escape character syntax
            ...ns\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Tr...
            C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:10: syntax error, unexpected >>, expecting keyword_end
            C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:12: syntax error, unexpected >>, expecting keyword_end
            C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:13: Invalid escape character syntax
            C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load'
            C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:28:in register_extension' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:28:in module:ClickWindow3D_Trial_mm'
            C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:18:in `<top (required)>'
            What was I doing wrong? 😲
            Cordially
            David
            • TIGT Online
              It's all wrong !
              Where I wrote >>> ".... I was showing what the output of the set reference would be in the Ruby Console from the 'p ' command.
              Remove all of those early lines in the class's body
              Also you should probably set up the menu code in the module not within the class itself ??
              Obviously the loose >>> etc throws an error when it's read directly within the class's code !
              You have also not corrected the error in the path set up.
              Will return:
              C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp\02-Sliding-Window-Trial-mm.skp
              which clearly will NOT exist !
              Which concatenate TWO skp file names in this way ?
              • TNTDAVIDT Offline
                TNTDAVID
                Thank you for your prompt response.
                @tig said:
                It's all wrong !
                Sorry, I discovered the ruby so I am very bad. 😳
                Like this ?
                @@path_to_00 = File.join(path_to_components,'02-Sliding-Window-Trial-mm.skp')
                "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\02-Sliding-Window-Trial-mm.skp"
                Can you show an example?
                I have to write this?
                @@path_to_00 = File.join(C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components,'00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm.skp')
                @tig said:
                Will return:
                Sorry, it also seemed impossible!
                I wanted to follow this example:
                @tig said:
                " The_user_path_to / Plugins / Your_Extension / Composants /Componant1.skp/Componant2.skp "
                Thank you for your help.
                • TIGT Online
                  NO.
                  Do not add any raw text into the class's body.
                  So it'll become
                  @@path_to_02 = File.join(path_to_components,'02-Sliding-Window-Trial-mm.skp')
                  Now you have a reference to ' path_to_components' and using that, then the paths for the TWO SKP files...
                  @@path_to_00
                  and
                  @@path_to_02
                  Why do you think that [note how I added the '...']:
                  @@path_to_00 = File.join('C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components', '00-Control-Panel-Trial-mm.skp', '02-Sliding-Window-Trial-mm.skp')
                  would work ??
                  It'll give the file-path:
                  C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/00-Control-Panel-Trial-mm.skp/02-Sliding-Window-Trial-mm.skp
                  which clearly doesn't exist !!!
                  Whereas the revised code [above] gives...
                  @@path_to_00
                  as C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/00-Control-Panel-Trial-mm.skp
                  and
                  @@path_to_02
                  as C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/02-Sliding-Window-Trial-mm.skp
                  which we might assume do exist ???
                  PS: Note how the \ and / file-separators appear - best to fix on / ...
                  perhaps fix those with path_string.tr!("\\","/") as you go...
                  • TNTDAVIDT Offline
                    TNTDAVID
                    If I understand correctly, the code should look like this:
                      class << self
                        def add_00
                          Sketchup.active_model.import(@@path_to_02)
                            tb.restore
                    With this code, the only component of "@@ path_to_02" is imported by the icon. 😕
                    Yes, the existing models.
                    perhaps fix those with path_string.tr!("\","/") as you go...
                    Thank you for this tip. 👍
                    Instead of importing 2 components with a icon.
                    Can we automatically import a component on boot up SketchUp with a "rb"?
                    Is it possible to make invisible to the user, with no way to display the component from SketchUp?
                    If possible, how the code should he be writing?
                    Thank you
                    David
                    • TIGT Online
                      I'm sorry but your coding is bonkers to me.
                      What are you smoking ?
                      command1 = UI::Command.new("add Resources"){ ClickWindow3D_Trial_mm.add_00 }should import both SKP files, BUT only if they exist...
                      So to test your code YOU need to add some simple steps within it...
                      For example some p or puts for the returned state as you set various paths,
                      also testing for File.exist?(some_file_path)
                      To be frank. for someone who is publishing extensions this is a surprisingly poor show...
                      I can't see what is so difficult in this process.
                      You seem to to be making things far more complicated than they need to be...
                      • TNTDAVIDT Offline
                        TNTDAVID
                        Rest assured, this code is crazy for me too! 💚
                        But as crazy as it is, it works :
                        http://i.imgur.com/wc8ScTp.gif
                        Smoking is bad for health, so I like to drink. 😛
                        Can you show an example, I can test?
                        I am sad to disappoint you, but I started in ruby. 😞
                        My extensions work 99%, with "Dynamic Components", and 1% of ruby, to create a simple toolbar.
                        Thank you for your franchise.
                        You definitely right!
                        Can show me a simple example for the same result?
                        Cordially
                        David
                        • TIGT Online
                          I already showed how to set up distinct references etc and you replied.
                          http://sketchucation.com/forums/viewtopic.php?p=604766#p604766
                          To check if the two paths are correct try:
                          puts "#{@@path_to_00} = #{File.exist?(@@path_to_00)}"
                          puts "#{@@path_to_02} = #{File.exist?(@@path_to_02)}"
                          Perhaps this would also be better to definitely avoid the prompt..
                          Sketchup.active_model.import(@@path_to_00, false) Sketchup.active_model.import(@@path_to_02, false)
                          • TIGT Online
                            Having thought this over...
                            Assuming both SKP files exist...
                            I think the issue is caused by your use of the model.import(path_to_skp) method.
                            The first run of the import forks off to another process, where you insert/move the instance of the imported file - thus the second import never starts as it's effectively cancelled by the first one.
                            There are other ways of doing this...
                            defn = model.definitions.load(path_to_skp)
                            adds the SKP to the model's definition,
                            then you can use other methods to insert it into the model.
                            entities.add_instance(defn, transformation)
                            Or use the alternative
                            model.place_component(defn)
                            You could also make your class a Tool and after adding the instance[s] use your tool to move the instance to a new location...
                            Another alternative might be to load the two and then make a group and add the two instances to its entities ?
                            I am not entirely sure what it is you are trying to achieve ?
                            A simpler way might even be to combine the two components into one new SKP and import than ?
                            • TNTDAVIDT Offline
                              TNTDAVID
                              Hello,
                              I am sorry for not being clear enough.
                              As it is possible to protect all a collection of "Dynamic Components", with a single "Parent Component," I want to import the "Component Parent" along with my dynamic models.
                              Import both components with a single icon sembait like a good idea, but I found much better now.
                              I allowed myself to open a new Topic with this new idea that is totally different.
                              If you still want to help me, I'd be delighted.
                              Sorry, for the time you have wasted on this topic.
                              Cordially
                              David
                              • Dan RathbunD Offline
                                Dan Rathbun
                                Create a template model that already has your set of component definitions loaded, and then the user can use that template when they start a new model.
                                I'm not here much anymore.
                                • TNTDAVIDT Offline
                                  TNTDAVID
                                  I understand your reasoning.
                                  But I wish maximum ease of use of my dynamic components, and simultaneously protect them.
                                  If we take the example of "Click-Window 3D", the windows are useless without the "Control Panel", which is the perfect example of a component "Parent" protector.
                                  If the "Control Panel" is not on the SketchUp scene, you'll have problems with my dynamic components.
                                  Instead of importing the control panel manually, I want it to be imported automatically.
                                  This will prevent user error, because 80% of the time the first reflex of a user is importing the "3D Window" before the "Control Panel".
                                  This can lead to a crash of SketchUp. 😒
                                  It is therefore urgent for me to find a solution to import the "Control Panel" automatically on each new SketchUp scene.
                                  Cordially
                                  David
                                  • TIGT Online
                                    Now you have explained your reasoning perhaps we can come up with some ideas...
                                    When a user clicks on a 3d Window DC to import I assume it's through your code - perhaps a toolbar ?
                                    So instead of immediately importing that DC, you could first check if your special Control Panel component definition is loaded and if so if an instance of it is placed in the current view/scene...
                                    If the answer id no to either of those tests, then additional code could be run to do that step [or those steps] before moving on to import the DC.
                                    As explained before, rather than importing the Control Panel you can use
                                    cp = model.definitions.load(path_to_CP)
                                    Then say place an instance thus
                                    model.active_entities.add_instance(cp, ORIGIN)
                                    Then import the Window DC ?
                                    • TNTDAVIDT Offline
                                      TNTDAVID
                                      I am currently developing a version of Click-Window 3D without "Control Panel".
                                      The 3D window will be changed manually with tools, "Scale", "Interact with Dynamic Components," and "Component Options".
                                      A perfect example is my plugin, Click-Change.
                                      However, i want to keep the protection of a "Parent" component, which will be a kind of invisible activation key of my "Dynamic Components".
                                      The method used in the code is not important, only those conditions is important:
                                      *** The "Parent" component, must be imported automatically.**
                                      *** It must be on the SketchUp scene before the first dynamic component.**
                                      *** It must be invisible or locked to prevent copy.**
                                      By fulfilling these conditions, we will have a good chance of protecting our dynamic components.
                                      Your proposal meets the three conditions?
                                      Thank you
                                      David
                                      • TNTDAVIDT Offline
                                        TNTDAVID
                                        The code should look like this ?
                                            module SomeSubModule
                                                def self.do_somethings()
                                                   path=Sketchup.find_support_file "cube.skp","Components"
                                                   model = Sketchup.active_model
                                                   definitions = model.definitions
                                                   componentdefinition = definitions.load path
                                                   point = Geom;;Point3d.new 10,20,30
                                                   transform = Geom;;Transformation.new point
                                                   instance = entities.add_instance componentdefinition, transform
                                        If not, can you show me an example?
                                        Without explanation with code examples, I do not understand you.
                                        Thank you for your patience.
                                        David
                                        • TIGT Online
                                          Please indent you code helpfully...
                                          However, even as it is, your code should 'almost' work... 😉
                                          Below, I've made a few minor adjustments, like -
                                          the () around methods' passed arguments, clearer naming etc...
                                          I have also added ### to the start of some unwanted code [that's like a ' rem' statement, as seen in some older coding conventions]
                                          module TNTDAVID
                                              def self.auto_run_code()
                                                path = Sketchup.find_support_file("cube.skp", "Components")
                                                ### let's assume that this SKP exists,
                                                ### but it does limit the search to that specific SketchUp folder -
                                                ### probably best to find it in your own subfolder of SKPs
                                                ### and have it shipped within your extension's subfolder !
                                                component_definition = definitions.load(path)
                                                point = Geom;;Point3d.new(10, 20, 30) ### these offsets are in inches !
                                                transformation = Geom;;Transformation.new(point)
                                                ### definitions = model.definitions
                                                instance = entities.add_instance(component_definition, transformation)
                                              self.auto_run_code() ### runs the code, loads the skp and places at instance...
                                          • TNTDAVIDT Offline
                                            TNTDAVID
                                            Unfortunately even with your adjustment, the code does not work yet. 😢
                                            When I launch SketchUp, nothing happens.
                                            And the "Ruby console" shipments this error message :
                                            Error: # <TypeError: no implicit conversion of nil into String>
                                            Or is the error?
                                            See you soon.
                                            David
