Import 2 components with a single icon.
Starting from the base code, I changed the lines of code :
@@path_to_00 = File.join(path_to_components,'Componant1.skp','Componant2.skp')I get this message: File not found or invalid
def add_00 Sketchup.active_model.import(@@path_to_00) Sketchup.active_model.import(@@path_to_01) endOnly the model @@Path_to_01 is imported.
Unfortunately I do not find the solution.
If someone who masters the code goes through, I would be very grateful to have help.
Cordially
David
Unfortunately your code makes little sense.
Try using a p or puts in front of the reference setting line[s] so you can see what is going on in the Ruby Console...
` p path_to_components = File.join(File.dirname(FILE), 'Components')"The_user_path_to/Plugins/Your_Extension/Components"
p @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp')
"The_user_path_to/Plugins/Your_Extension/Components/00-Control-Panel-Trial-mm.skp"p @@path_to_00 = File.join(path_to_components,'Componant1.skp','Componant2.skp')
"The_user_path_to/Plugins/Your_Extension/Components/Componant1.skp/Componant2.skp"`
So obviously the file does NOT exist...
You need to sort out the paths so they are defined properly...This is quite basic stuff...
So I suspect that you are just too close to your code to be able to step back and see the wider picture...Using temporary p or puts as you define references to things help you see where your thinking has gone astray...
TIG thank you for your help.
So I changed my code like this:
module ClickWindow3D_Trial_mm class << self p path_to_components = File.join(File.dirname(__FILE__), 'Components') >>> "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components" p @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp') "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp" >>> p @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm') >>> "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp\02-Sliding-Window-Trial-mm" path_to_components = File.join(File.dirname(__FILE__), 'Components') @@path_to_00 = File.join(path_to_components, '00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm.skp') @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources') def add_00 Sketchup.active_model.import(@@path_to_00) end if !file_loaded?(__FILE__) tb = UI;;Toolbar.new(%Q(Click-Window3D-Trial-mm)) command1 = UI;;Command.new("add Resources"){ ClickWindow3D_Trial_mm.add_00 } command1.small_icon = File.join(@@path_to_resources,"add_00.png") command1.large_icon = File.join(@@path_to_resources,"add_00.png") command1.tooltip = %Q(add Resources) command1.status_bar_text = %Q(add Resources) tb.add_item(command1) tb.restore file_loaded(__FILE__) end end endUnfortunately I obtien this error message:
Error Loading File C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb
Error: #<SyntaxError: C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:7: syntax error, unexpected >>, expecting keyword_end
>>> "C:\Users\DAVID\AppData\Roa...
C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:7: Invalid escape character syntax
...ns\TNT_ClickWindow3D_Trial_mm\Components"... ^
C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:9: Invalid escape character syntax
...ns\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Tr...
C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:10: syntax error, unexpected >>, expecting keyword_end
>>>^C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:12: syntax error, unexpected >>, expecting keyword_end
>>>^C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm/logic.rb:13: Invalid escape character syntax
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:inrequire' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:inload'
C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:28:inregister_extension' C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:28:inmodule:ClickWindow3D_Trial_mm'
C:/Users/DAVID/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TNT_ClickWindow3D_Trial_mm.rb:18:in `<top (required)>'What was I doing wrong?
Thank you in advance for your help.
Cordially
David
It's all wrong !
Where I wrote>>> "....I was showing what the output of the set reference would be in the Ruby Console from the 'p ' command.Remove all of those early lines in the class's body
Also you should probably set up the menu code in the module not within the class itself ??Obviously the loose
>>>etc throws an error when it's read directly within the class's code !You have also not corrected the error in the path set up.
Will return:
C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp\02-Sliding-Window-Trial-mm.skp
which clearly will NOT exist !
Which concatenate TWO skp file names in this way ? -
Thank you for your prompt response.
@tig said:
It's all wrong !
Sorry, I discovered the ruby so I am very bad.
@tig said:
Where I wrote >>> ".... I was showing what the output of the set reference would be in the Ruby Console from the 'p ' command.
Like this ?
path_to_components = File.join(File.dirname(__FILE__), 'Components') "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components" @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp') "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\00-Control-Panel-Trial-mm.skp" @@path_to_00 = File.join(path_to_components,'02-Sliding-Window-Trial-mm.skp') "C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components\02-Sliding-Window-Trial-mm.skp" path_to_components = File.join(File.dirname(__FILE__), 'Components') @@path_to_00 = File.join(path_to_components, '00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm.skp') @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')@tig said:
Can you show an example?
@@path_to_00 = File.join(path_to_components, '00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm.skp')I have to write this?
@@path_to_00 = File.join(C;\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components,'00-Control-Panel-Trial-mm.skp','02-Sliding-Window-Trial-mm.skp')@tig said:
Will return:
Which concatenate TWO skp file names in this way ?Sorry, it also seemed impossible!
I wanted to follow this example:
@tig said:
" The_user_path_to / Plugins / Your_Extension / Composants /Componant1.skp/Componant2.skp "
Thank you for your help.
NO.
Do not add any raw text into the class's body.
So it'll becomepath_to_components = File.join(File.dirname(__FILE__), 'Components') @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp') @@path_to_02 = File.join(path_to_components,'02-Sliding-Window-Trial-mm.skp') @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources')Now you have a reference to '
path_to_components' and using that, then the paths for the TWO SKP files...
@@path_to_00
and
@@path_to_02Why do you think that [note how I added the
@@path_to_00 = File.join('C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components', '00-Control-Panel-Trial-mm.skp', '02-Sliding-Window-Trial-mm.skp')
would work ??
It'll give the file-path:
C:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/00-Control-Panel-Trial-mm.skp/02-Sliding-Window-Trial-mm.skp
which clearly doesn't exist !!!
Whereas the revised code [above] gives...
@@path_to_00
asC:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/00-Control-Panel-Trial-mm.skp
and
@@path_to_02
asC:\Users\DAVID\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\TNT_ClickWindow3D_Trial_mm\Components/02-Sliding-Window-Trial-mm.skp
which we might assume do exist ???PS: Note how the \ and / file-separators appear - best to fix on / ...
perhaps fix those withpath_string.tr!("\\","/")as you go... -
If I understand correctly, the code should look like this:
module ClickWindow3D_Trial_mm class << self path_to_components = File.join(File.dirname(__FILE__), 'Components') @@path_to_00 = File.join(path_to_components,'00-Control-Panel-Trial-mm.skp') @@path_to_02 = File.join(path_to_components,'02-Sliding-Window-Trial-mm.skp') @@path_to_resources = File.join(File.dirname(__FILE__), 'Resources') def add_00 Sketchup.active_model.import(@@path_to_00) Sketchup.active_model.import(@@path_to_02) end if !file_loaded?(__FILE__) tb = UI;;Toolbar.new(%Q(Click-Window3D-Trial-mm)) command1 = UI;;Command.new("add Resources"){ ClickWindow3D_Trial_mm.add_00 } command1.small_icon = File.join(@@path_to_resources,"add_00.png") command1.large_icon = File.join(@@path_to_resources,"add_00.png") command1.tooltip = %Q(add Resources) command1.status_bar_text = %Q(add Resources) tb.add_item(command1) tb.restore file_loaded(__FILE__) end endWith this code, the only component of "@@ path_to_02" is imported by the icon.
Yes, the existing models.
perhaps fix those with path_string.tr!("\","/") as you go...Thank you for this tip.
Instead of importing 2 components with a icon.
Can we automatically import a component on boot up SketchUp with a "rb"?
Is it possible to make invisible to the user, with no way to display the component from SketchUp?
If possible, how the code should he be writing?
Thank you
David
I'm sorry but your coding is bonkers to me.
What are you smoking ?
command1 = UI::Command.new("add Resources"){ ClickWindow3D_Trial_mm.add_00 }should import both SKP files, BUT only if they exist...So to test your code YOU need to add some simple steps within it...
For example some p or puts for the returned state as you set various paths,
also testing forFile.exist?(some_file_path)To be frank. for someone who is publishing extensions this is a surprisingly poor show...
I can't see what is so difficult in this process.
You seem to to be making things far more complicated than they need to be... -
Rest assured, this code is crazy for me too!
But as crazy as it is, it works :
Smoking is bad for health, so I like to drink.
also testing for File.exist?(some_file_path)Can you show an example, I can test?
I can't see what is so difficult in this process.I am sad to disappoint you, but I started in ruby.
My extensions work 99%, with "Dynamic Components", and 1% of ruby, to create a simple toolbar.
Thank you for your franchise.
You definitely right!
Can show me a simple example for the same result?
Cordially
David
I already showed how to set up distinct references etc and you replied.
http://sketchucation.com/forums/viewtopic.php?p=604766#p604766To check if the two paths are correct try:
puts "#{@@path_to_00} = #{File.exist?(@@path_to_00)}"
puts "#{@@path_to_02} = #{File.exist?(@@path_to_02)}"Perhaps this would also be better to definitely avoid the prompt..
Sketchup.active_model.import(@@path_to_00, false) Sketchup.active_model.import(@@path_to_02, false) -
Having thought this over...
Assuming both SKP files exist...
I think the issue is caused by your use of themodel.import(path_to_skp)method.
The first run of the import forks off to another process, where you insert/move the instance of the imported file - thus the second import never starts as it's effectively cancelled by the first one.There are other ways of doing this...
defn = model.definitions.load(path_to_skp)
adds the SKP to the model's definition,
then you can use other methods to insert it into the model.
entities.add_instance(defn, transformation)
Or use the alternative
model.place_component(defn)
You could also make your class a Tool and after adding the instance[s] use your tool to move the instance to a new location...
Another alternative might be to load the two and then make a group and add the two instances to its entities ?I am not entirely sure what it is you are trying to achieve ?
A simpler way might even be to combine the two components into one new SKP and import than ? -
Hello,
I am sorry for not being clear enough.
As it is possible to protect all a collection of "Dynamic Components", with a single "Parent Component," I want to import the "Component Parent" along with my dynamic models.
Import both components with a single icon sembait like a good idea, but I found much better now.
I allowed myself to open a new Topic with this new idea that is totally different.
If you still want to help me, I'd be delighted.
Sorry, for the time you have wasted on this topic.
Cordially
David
Create a template model that already has your set of component definitions loaded, and then the user can use that template when they start a new model.
I understand your reasoning.
But I wish maximum ease of use of my dynamic components, and simultaneously protect them.
If we take the example of "Click-Window 3D", the windows are useless without the "Control Panel", which is the perfect example of a component "Parent" protector.
If the "Control Panel" is not on the SketchUp scene, you'll have problems with my dynamic components.
Instead of importing the control panel manually, I want it to be imported automatically.
This will prevent user error, because 80% of the time the first reflex of a user is importing the "3D Window" before the "Control Panel".
This can lead to a crash of SketchUp.
It is therefore urgent for me to find a solution to import the "Control Panel" automatically on each new SketchUp scene.
Cordially
David
Now you have explained your reasoning perhaps we can come up with some ideas...
When a user clicks on a 3d Window DC to import I assume it's through your code - perhaps a toolbar ?
So instead of immediately importing that DC, you could first check if your special Control Panel component definition is loaded and if so if an instance of it is placed in the current view/scene...
If the answer id no to either of those tests, then additional code could be run to do that step [or those steps] before moving on to import the DC.
As explained before, rather than importing the Control Panel you can use
cp = model.definitions.load(path_to_CP)
Then say place an instance thus
model.active_entities.add_instance(cp, ORIGIN)Then import the Window DC ?
I am currently developing a version of Click-Window 3D without "Control Panel".
The 3D window will be changed manually with tools, "Scale", "Interact with Dynamic Components," and "Component Options".
A perfect example is my plugin, Click-Change.
However, i want to keep the protection of a "Parent" component, which will be a kind of invisible activation key of my "Dynamic Components".
The method used in the code is not important, only those conditions is important:
*** The "Parent" component, must be imported automatically.**
*** It must be on the SketchUp scene before the first dynamic component.**
*** It must be invisible or locked to prevent copy.**
By fulfilling these conditions, we will have a good chance of protecting our dynamic components.
Your proposal meets the three conditions?
Thank you
David
model.active_entities.add_instance(cp, ORIGIN)The code should look like this ?
module ClickWindow3D_Trial_mm module SomeSubModule def self.do_somethings() path=Sketchup.find_support_file "cube.skp","Components" model = Sketchup.active_model definitions = model.definitions componentdefinition = definitions.load path point = Geom;;Point3d.new 10,20,30 transform = Geom;;Transformation.new point definitions = model.definitions instance = entities.add_instance componentdefinition, transform end self.do_somethings() end endIf not, can you show me an example?
Without explanation with code examples, I do not understand you.
Thank you for your patience.
David
Please indent you code helpfully...
However, even as it is, your code should 'almost' work...
Below, I've made a few minor adjustments, like -
the()around methods' passed arguments, clearer naming etc...
I have also added###to the start of some unwanted code [that's like a 'rem' statement, as seen in some older coding conventions]module TNTDAVID module ClickWindow3D_Trial_mm def self.auto_run_code() path = Sketchup.find_support_file("cube.skp", "Components") ### let's assume that this SKP exists, ### but it does limit the search to that specific SketchUp folder - ### probably best to find it in your own subfolder of SKPs ### and have it shipped within your extension's subfolder ! model = Sketchup.active_model definitions = model.definitions component_definition = definitions.load(path) point = Geom;;Point3d.new(10, 20, 30) ### these offsets are in inches ! transformation = Geom;;Transformation.new(point) ### definitions = model.definitions instance = entities.add_instance(component_definition, transformation) end self.auto_run_code() ### runs the code, loads the skp and places at instance... end end -
Unfortunately even with your adjustment, the code does not work yet.
When I launch SketchUp, nothing happens.
And the "Ruby console" shipments this error message :
Error: # <TypeError: no implicit conversion of nil into String>
Or is the error?
See you soon.
David
