    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 432.4k Views 92 Watching
      Can you try downloading from Extension Warehouse? http://extensions.sketchup.com/en/content/vertex-tools
      I'm curious if Defender reacts differently depending on what site the file is downloaded from.
        alpro
        No issues downloading through the extension warehouse
          Interesting. I wonder if part of this might be trust based on download source. My website is a rather new one - so possibly that affects things... I dunno. I just hope they come back to me with some insight.
            thirdleft
            @thomthom said:
            @thirdleft said:
            hi all! just started using this tool and am LOVING it! one thing though. is there any way to enter a scale or distance factor when in gizmo mode? the advantage of this would be that i could scale by half in just one axis rather than all at once. thanks in advance for your tips and this excellent resource!
            hm... this should be working... but something seems to be broken.. ๐Ÿ˜ž I need to file this as a bug and investigate. Sorry. ๐Ÿ˜ž
            Thanks for such a prompt respons thomthom! look forward to the fix ๐Ÿ˜Ž
              labaruss
              I buy a license... but today the vertex tool doesn't work.
              I have a blank panel with the title "Vertex tool license"...
              How I can reactivate my license ?
                Hi. Sorry to hear that.
                I need some more information though.
                What SketchUp version?
                What version of Vertex Tools do you have installed?
                Also, you are on Windows, right? Windows 7?
                Any chance that you are using IE8? If so, then you need to update IE as minimum version for SketchUp and Vertex Tools is IE9.
                • N Offline
                  noldo
                  Hi Tomtom
                  I have purchased the plugin, but when i activating a gizmo the soft select radius in measurement dialog appear.
                  I try moving the vertex when a gizmo is active (using the arrow), and the measurement dialog show the distance, but when i release the gizmo (arrow), the dialog automatically change to soft select radius, and the distance disappear.
                  I can not move precisely vertex with numerical imput!
                  • BoxB Offline
                    Did you try hitting enter to finish.
                    • N Offline
                      noldo
                      Yes, nothing change!
                        That sounds similar to that another user reported: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=29636%26amp;p=604392#p603638
                        I've yet to figure out the cause of that is. It's high up on the list though.
                        • tuna1957T Offline
                          tuna1957
                          Downloaded latest version 1.2.7 from SketchUcation store on my desktop and laptop. License window shows blank now. Don't get a prompt to re-enter license key ? What did I do wrong ? Help.... SU 2015 pro , Mac 10.9 and Mac 10.10
                            Hm.. I had a couple of reports of this before, but always on Windows. It was either due to old IE version or Windows Defender. But since you have a Mac - this sounds like something new.
                            Can you open the Ruby Console and report back the results for: $LOADED_FEATURES
                            Also, can you check your Plugins folder; check if these two files exist:
                            • tt_vertex/ui/js/core.js
                            • tt_vertex/vendor/errorhandler/error_reporter.rbs
                            (Or, possibly zip up tt_vertex.rb and tt_vertex folder and send it back to me?)
                            • tuna1957T Offline
                              tuna1957
                              Thomas, here's the ruby console.......
                              $LOADED_FEATURES
                              "enumerator.so", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/encdb.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/trans/transdb.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/rbconfig.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/compatibility.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/defaults.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/deprecate.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/errors.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/version.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/requirement.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/platform.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/specification.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/exceptions.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_gem.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/langhandler.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/sketchup.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/sketchucation/!scfapitools.rbs", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/common.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/generic.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/ftp.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/http.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/https.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/ldap.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/ldaps.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri/mailto.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/uri.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/stringio.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/date_core.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/date/format.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/date.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/time.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/open-uri.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/socket.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/socket.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/timeout.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/protocol.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/zlib.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/exceptions.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/header.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/generic_request.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/request.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/requests.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/response.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/responses.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/proxy_delta.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http/backward.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/net/http.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/iso_8859_1.bundle", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF-myShortcuts.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF-openPluginsFolder.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/sketchucation/scf-rbztools.rbs", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/delegate.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/thread.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/singleton.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/etc.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/fileutils.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/tmpdir.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/tempfile.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/dos_time.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/ioextras/abstract_input_stream.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/ioextras/abstract_output_stream.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/ioextras.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/entry.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/generic.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/universal_time.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/old_unix.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/unix.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/zip64.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/zip64_placeholder.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/entry_set.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/central_directory.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/file.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/input_stream.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/output_stream.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/decompressor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/compressor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/null_decompressor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/null_compressor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/null_input_stream.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/pass_thru_compressor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/pass_thru_decompressor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/inflater.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/deflater.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/streamable_stream.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/streamable_directory.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/errors.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/sketchucation/scf_manager.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/sketchucation/scf_uninstaller.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/sketchUcloud.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF_loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/!SketchUcation_loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__Animation.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__Arc.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__BSplineU.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__Catmull.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__Chamfer.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__Courbette.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__CubicBezier.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__Divider.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__DogBone.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__FSpline.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/BZ__Segmentor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/BZ_Dir_17/bezierspline_main.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bezierspline.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/clf_shape_bender/clf_shape_bender_data.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/clf_shape_bender/clf_shape_bender_menus.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/clf_shape_bender.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/deBabelizer.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/langhandler.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/artisan.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/artisantools.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/extrude_tool.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/polyreduce.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/proxy_settings.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/dm_artisan/tool_observer.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/DM_artisan/artisan_load.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/DM_artisan.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/ExtrudeTools.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Follow Me Helix.rb", "LibTraductor.rb", "libtraductor.rb", "LibFredo6.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6__obsolete.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6_API.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6_txtmsg.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Algo.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6AllPlugins.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Config.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Contour.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6DirectionManager.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6EdgePicker.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Error.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6FacePicker.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6G6.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Input.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Magnifier.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Mark.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Material.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Offset3d.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Opengl.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Operation.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6OriginTargetPicker.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Palette.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6PaletteHelper.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6PluginDialogs.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Profile.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Protractor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Selmode.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Solid.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Spline.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Startup.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Stencil.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6StencilIntersector.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6StencilManager.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6System.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Tool.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Transform.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Translate.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Triangulation.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Upgrade.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6VCB.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6WebHtml.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6WebJS.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6WebWdlg.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6WebXTable.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/__loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_Curviloft/bootstrap_Curviloft.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_Curviloft/__loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoScale/bootstrap_FredoScale.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoScale/__loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__AngleInspector.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__AutoReverseFaces.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__ConstructFaceNormal.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__Convexify.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__CountFacesBySides.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__CurviShear.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__DrawAlong.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__EdgeInspector.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__ElementStats.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__MarkVertices.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__MoveAlong.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__RemoveLonelyVertices.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__ReportLabelArea.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__ReverseOrientFaces.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__RevertCurve.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/FredoTools__ThruPaint.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6Material.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools/__loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/__loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/bootstrap_RoundCorner.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner/__loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_ToolsOnSurface/bootstrap_OnSurface.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_ToolsOnSurface/__loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_Curviloft.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoScale.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_FredoTools.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_RoundCorner.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_advancedcameratools/advancedcameratools_main.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools/actloader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/geometryhelpers.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/fromcontours.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/triangulatorutility.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/meshhelpers.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/fromscratch.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/smoovetool.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/stamptool.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/drapetool2.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/detailtool.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/su_sandbox/flipedgetool.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_sandbox/sandboxmenus.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_sandbox.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_webtextures/webtextures_loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/su_webtextures.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TIG-splitdonut.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TIG-splitsausage.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TIG-splitTOOLS.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/system.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/arc.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/attributes.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/babelfish.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/libraries/2.10.6/2.0/osx64/tt_lib2.bundle", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bezier.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/binary.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/boolean_attributes.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/bounds.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/color.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/cursor.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/debug.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/deferred_event.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/definition.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/dimension.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/draw_cache.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d_ex.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/point3d.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/sketchup.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/progressbar.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/edges.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/instance.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/entities.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/geom3d.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uvq.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/faces.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/length.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/locale.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gizmo_manipulator.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gl_image.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/javascript.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/json.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/gui.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/image.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/modal_wrapper.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/webdialog_patch.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/window.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolwindow.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/settings.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/inputbox.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/materials.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/metaclass.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/model.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/profiler.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/ray.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/selection.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/simpletask.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/toolbarwindow.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/uv_plane.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/version.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/win32_shim.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/version.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/ostruct.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/generic_object.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/common.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_16be.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_16le.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_32be.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/enc/utf_32le.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/json/ext/parser.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/json/ext/generator.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json/ext.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/json.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/vendor/error-handler/error_reporter.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/analyze.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/entities.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/tools.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/uv_mapping.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/edge_connect.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/mesh_converter.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/gl.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/window.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/exporter_obj.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/command.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/importers/mtl.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/ui/obj_import_options.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/unit_helper.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/vertex_cache.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/importers/obj.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/settings.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/drawing_helper.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/geometry.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/face_splitter.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/loop_offset.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/controllers/loop_offset.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/tools/offset.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/core.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools/bootstrap.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_QuadFaceTools.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/settings.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_reporter/error_reporter.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/set.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl_helper.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/errors.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/shell.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_finder.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/instance.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/debug_tools.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/window.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/error_window.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/geometry.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_window.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/key_codes.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/drawing_helper.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/object_utils.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/label.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/cache.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/types.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/file.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/binary/struct.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/image_bmp.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/pixelcache.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/image.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/gl/text.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/legend.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/inspector_tool.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/core.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2/bootstrap.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_solid_inspector2.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/bootstrap.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/third-party/error-reporter/error_reporter.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/core.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/c_extension_manager.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_SUbD/libraries/1.0.5/2.0/osx64/SUbD.bundle", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/geometry.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/utilities.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/update.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/http/async_requests.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui/license_error_window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui/dialog_window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui/window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/object_utils.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui/license_window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/settings.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/crease.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/crease_finder.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/entities/edge.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/entities/drawingelement.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/entities/entity.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/cursor.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/entities/entities.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/entities/face.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/entities/vertex.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/gl/cache.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/gl/drawinghelper.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/gl/glyph.rbs", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/syntax_error.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/psych.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/nodes/node.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/nodes/stream.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/nodes/document.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/nodes/sequence.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/nodes/scalar.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/nodes/mapping.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/nodes/alias.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/nodes.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/streaming.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/visitors/visitor.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/x86_64-darwin12.5.0/strscan.bundle", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/scalar_scanner.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/visitors/to_ruby.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/visitors/emitter.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/visitors/yaml_tree.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/json/ruby_events.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/visitors/json_tree.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/visitors/depth_first.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/visitors.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/handler.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/tree_builder.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/parser.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/omap.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/set.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/coder.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/core_ext.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/deprecated.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/stream.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/json/yaml_events.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/json/tree_builder.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/json/stream.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych/handlers/document_stream.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/psych.rb", "/Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/yaml.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/gl/label.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/gl/label_group.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/gl/text.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers/app.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers/tools.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers/limit_mesh_selection.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers/base.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers/selection.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers/mesh.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/tools/base.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/tools/crease.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/tools/pushpull.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui/entity_info_window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers/entity_info_mesh.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/observers/entity_info_selection.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui/tool_window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui/subdivision_error_window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui/welcome.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/selection.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/shell.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_subd/ui.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_SUbD.rb", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/bootstrap.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/c_extension_manager.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/core.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/md5.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/point3d.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/geom3d.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/observable.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/l10n.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/settings.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/config.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/auto_smooth.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/selection.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Vertex/CExt/1.2.7/2.0/osx/VT_CEXT.bundle", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/cursor.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/gl_dib.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/gl_ui.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/gizmos.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/manipulator.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/tools.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/proxy_tools.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/functions.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/editor.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/ui/license_error_window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/ui/dialog_window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/ui/window.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/object_utils.rbs", "/users/charlestreon/library/application support/sketchup 2015/sketchup/plugins/tt_vertex/ui/license_window.rbs", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/TT_Vertex/loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/tt_vertex.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/twilight2/20/TwilightLibV2.bundle", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/twilight2/init_twilight.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/twilight2/twilight2_loader.rb", "/Users/charlestreon/Library/Application Support/SketchUp 2015/SketchUp/Plugins/twilight2.rb"
                                Some files are not loaded. Can you ZIP up the tt_vertex folder in your Plugins folder and send it to me please?
                                • tuna1957T Offline
                                  tuna1957
                                  Thomas, sent in a PM .
                                    For anyone else wondering, the issue seemed to be that installing a newer version on top of an older (a few versions back) leave an old file around that mess up the loading of the extension.
                                    The quick-fix is to completely remove Vertex Tools and install fresh. But I'll create a patch that will be able to clean this up automatically.
                                    • Bob JamesB Offline
                                      Bob James
                                      While you're at it, how about version 2 ๐Ÿ˜Ž
                                        bstng
                                        Hi !
                                        I have got a problem with vertex tool, when i use it my sketchup pro 2015 shut down. It's written : Sketchup had a bug splat.
                                        Does anyone know why ?
                                        Thanks for your help.
                                        Bastien
                                          Bob James
                                          @bstng said:
                                          Hi !
                                          Bastien
                                          Bastian, can you provide some more detail?
                                          Even though this is your first post, I notice that you've listed your skill level as "intermediate" so I assume youโ€™ve been using SU for some time. This leads me to ask some obvious questions to help us help you.
                                          1. Is this the first time you've used VT?
                                          2. If not, do you have any newly installed plugins/extensions that might be known candidates for incompatibility with VT?
                                          3. What were you doing specifically when the splat happened?
                                          4. How complex is the object youโ€™re trying to modify?
                                          5. Does it happen on other models?
                                          6. What version of VT are you using?
                                          7. What version of OS are you using?
                                          8. Does it happen on other models?
                                          9. Did you submit a โ€œBug Splatโ€?
                                          10. Can you include the .skp youโ€™re working on?
                                          Etc.
                                            What Bob just said. With an added question of; does the BugSplat happen when Vertex Tools is the only extension loaded?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 33
                                            • 34
                                            • 12 / 34
