    MSPhysics ice stage for AntonS
    25 Posts 13 Posters 9.0k Views 13 Watching
    • F Offline
      faust07
      This little simulation is made as a big thank you for Anton Synytsia for bringing physics for SketchUp back to life and to a high level. The ice stage with a lot of animated animals, collapsing icebergs, splashing and foaming demonstrates the performance of the plugin.
        Nice!
        How did you combine physics with animations for this video?
        • F Offline
          faust07
          Great that you like it!
          There are several animation exporters implemented in the MSPhysics plugin.
          If no rendering software is installed, you can export the images of the animation in a selected SketchUp style too.
          Twilight Renderer also allows to render MSPhysics animations (directly or saved Replay data).
          For rendered animations the requirement is that the render program (in my case IndigoRT) is installed for the certain SketchUp version.
          If the MSPhysics model is prepared and ready to run the steps are:
          • toggle the Record button, push the Play button and after the desired time the Reset button
          • answer the following questions with yes
          • in Extensions pull-down menu select "MSPhysics", "Export Replay to SkIndigo" (in my case), input the start and end frame numbers ...
          • after the following export to igq-files and rendering every frame with Indigo you can
          • combine the rendered images with a corresponding software (Windows Movie Maker, Virtual Dub, ...).
          • O Offline
            otb designworks
            Impressive!
            Can you give us some idea of how long and how complicated it is to achieve what we are watching? And how long that took to render at what resolution?
            Cheers, Chuck
            OTB Designworks is on Youtube
            • F Offline
              faust07
              With few previous knowledge in SketchyPhysics I started to learn MSPhysics at the beginning of this year.
              In June I started with the Orca experiments because I was excited by the possibilities of the "Buoyancy Plane" for water surface simulation.
              AntonS developed parallel MSPhysics further and built the grand Curvy Slider and Piston Joints.
              Then there were also minimal knowledge in scripting based on the assistance and the example models of AntonS and PituPhysics.
              See the especially the grand MSP concert piano with many self playing songs in 3D Warehouse.
              I recommend to install MSPhysics, read the instructions and get started.
              Rendering with IndigoRT:
              Render Settings: Path tracing, Halt SSP 30 samples per pixel
              CPU Rendering on Intel Core i7-4770 CPU 3.40GHz.
              resolution 1920 x 1080
              average rendering time: 1,5 min per frame.
              30 frames per sec.
              Here are some pictures, how the model is constructed:
              • cottyC Offline
                cotty
                Great MSPhysics example!
                my SketchUp gallery
                • pbacotP Offline
                  Wow.... wow!
                  • soloS Offline
                    Awesome, looking as the construction image, I'd go mad, too much happening for my little brain to keep up with.
                    • fredo6F Offline
                      @Faust07
                      I am really impressed, both by your artistic sense and your technical mastership...and indeed by MSPhysics, which look extremely powerful. You animation is a real movie that deserves a prize!
                      • ntxdaveN Offline
                        ntxdave
                        I pretty much agree with what Fredo said. ๐Ÿ‘ ๐Ÿ‘
                        I am particularly intrigued with the motion of the various pieces of water movement. The spray and waves are very nice.
                        Press F1...thank me later
                        • F Offline
                          faust07
                          Thanks guys for the kind words. But the praise goes with priority to you, because you are advancing SketchUp, either with helping comments in the posts or with fantastic plugins (Fredo6). My goal as a user is to support the combination of SketchUp and Physics, because there lies an incredible potential in it (apart from the game engines).
                          It seems that there still lack the necessary imagination to recognize the possibilities. Good examples are enough since SketchyPhysics but there is little feedback from users after SketchyPhysics received unjustly.
                          I wish I had more idea of Ruby programming to translate good examples of SketchyPhysics into the more advanced MSPhysics - but time will tell...
                            Anton_S
                            Hey Faust,
                            That's really amazing! Just astounding!
                            Thank you very much,
                            Anton
                            • F Offline
                              faust07
                              Nice that you like it, Anton.
                              That's largely your work and the preliminary work of the people who have developed the physics engine.
                              I scratch here, of course, only at the top of what is possible.
                              The simulation and animation of living things could be a little more sophisticated.
                              A good approach is the model "Real Springs" by PituPhysics (3D Warehouse) and what I hardly dare to dream, the first point on your TODO-list:
                              "โ€ขImplement cloth and soft bodies interface."
                              The others on the list, I can not wait ( ๐Ÿ˜Ž ) are:
                              "โ€ขImplement user mesh collision interface.
                              โ€ขAdd fracture/split interface.
                              โ€ขAdd your own convex decomposition algorithm."
                              ๐Ÿ˜‰ ๐Ÿ‘
                                Anton_S
                                Maybeh one day lol
                                • O Offline
                                  otb designworks
                                  Thanks for the details! That is one impressive animation.
                                  Cheers, Chuck
                                  • F Offline
                                    faust07
                                    Thanks again.
                                    The beauty is that you can achieve great effects with little effort with MSPhysics...
                                    • chriC Offline
                                      chri
                                      Faust , you are incredible
                                      A fool job for a magnificient poetic result, your are an artist !
                                      Chri
                                        Wonderful clip video! ๐Ÿ˜Ž
                                        Bravo! ๐Ÿ‘
                                        Ps Music by ?
                                        • F Offline
                                          faust07
                                          Thanks also to you, Chri and Pilou, for the kind words! And for the setting into the SketchUp "Hall of Fame" ...
                                          On the music I'm not particularly proud of. Here I strummed on the guitar a little and also improvised the text.
                                          I have the piece used because it accompanies the uniformity of simulation and extends over the full duration of the video.
                                          The content of the text does not match the content of the video... Sorry
                                            No problem ! It's perfect for me! I had believed that was Tom Waits! ๐Ÿ˜Ž
                                            and like this you will not have problem of copyright! ๐Ÿ‘
