    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    Splitting Groups of Walls in SU
    14 Posts 5 Posters 611 Views 5 Watching
    • N Offline
      nickallen
      Hi. Anyone know if there is a plugin / extension that splits a group of walls (the ground floor internal walls of a building for example) into individual walls (groups). Thanx
        Right Click / Explode one time?
        Without SKP's file or image Before / After...
        • sdmitchS Offline
          sdmitch
          I doubt that one exists but, if you would post a sample model with before and after examples, maybe one could be created.
          http://sdmitch.blogspot.com/
          • N Offline
            nickallen
            See attached pdf illustrating. Group of walls on right are 1 group. Walls on left split into individual groups. Model available if required.
            Cheers.
            Wall Groups.pdf
            • sdmitchS Offline
              sdmitch
              Cheers.
              Yes, please post the model. Make it version SU8 for max compatibility.
              • N Offline
                nickallen
                See attached. Tell me, why is V8 so good? That's more than once I have heard good things about V8.
                Q1 Wall Test_V8.skp
                  kaas
                  V8 is free for any use whatsoever - no commercial restrictions.
                    Save as V6 is even better! 💚
                    (can be reloaded by V7, V8,2013,2014, 2015, 2016)
                    • N Offline
                      nickallen
                      Thank you. Will give it a try.
                      • sdmitchS Offline
                        sdmitch
                        Doesn't exactly duplicate your "after" groups but maybe it is close enough.
                        Usage:
                        1. Select the group of walls1. Plugins>SDM Tools>CorG Tool>Wall Groups
                        • N Offline
                          nickallen
                          I think this works well. It seems to reverse some faces and there is a chamfered corner on one group as attached.
                          Can the same thing be done if the group is a component?, i.e. divides the major component into unique components?
                          • sdmitchS Offline
                            sdmitch
                            The reversed faces is probably an easy fix. The chamfered corner, is more problematic since it requires trying to decide which wall should be extended. Components instead of groups should be easy enough to implement.
                            • sdmitchS Offline
                              sdmitch
                              I have sent the latest version by PM.
                                Garry K
                                There is one definite advantage of having the corners mitered. It simplifies outside wall textures. A number of plugins do miter for this reason.
