    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Explode and regroup script?
    extensions
    26 Posts 3 Posters 4.7k Views 3 Watching
      gregswk
      Hi guys!
      I have many groups (about 300) in my model and I'd like to explode and regroup each group, ONE BY ONE.
      Is there a script to do it automatically?
      *I'm attaching a .skp file with 2 of my groups.
      DROP TO TERRAIN_SKP6.skp
      • sdmitchS Offline
        sdmitch
        @gregswk said:
        Hi guys!
        Why? Is there a point to this exercise?
        http://sdmitch.blogspot.com/
          From your example you want explode these 2 groups above the terrain for make only one group ?
          (because they are pasted) ? For make a "unic solid" ? So for delete internal common faces?
          If yes or similar take a look at this post! ๐Ÿ˜‰
          More this one! (for coders)
            gregswk
            Hi! The reason is that I can't use "drop to terrain" plugins like DropGC and Raytracer. I select the groups and click the plugin but nothing happens.
            BUT if I explode and regroup them (one by one), everything works normally. I really dont know why...
              gregswk
              [attachment=0:1eoovfrz]<!-- ia0 -->unic_solid.jpg<!-- ia0 -->[/attachment:1eoovfrz]
              Hi! Actually I want to remain each group without mixing with others entities, because in my case they are all buildings (after ~exploding and regrouping each one of them~ I'll use the plugin DropGC).
              I dont know why: the way the groups are now dont let me use drop to terrain plugins. Do they have any definition or sth? If yes, is there a way to reset them?
                SmartDrop works for any terrain but maybe that is not that you want ? ๐Ÿค“ (Right Click on Selection)
                And sure that resovle not the little mystery! ๐Ÿ˜„
                  In this special case (flat terrain) ๐Ÿ˜„
                  If you Select All Groups / Right Click / Make Component : the Ray Tracer works!
                  Then just explode one time and you have your original groups on the terrain!
                  But sure your groups have a special state! ๐Ÿ˜ฒ
                  A little mystery! ๐Ÿ˜ฎ
                    gregswk
                    My terrain isnt flat ๐Ÿ˜ข
                    Yeah...Maybe a big mystery!
                    Pleasee find out for me! ๐Ÿ’š
                      gregswk
                      So, I've done the landscape above importing all those buildings solids and doing the following steps:
                      1. Transforming all groups as single components using "tt_groups2comps" plugin
                      2. Transforming all components as single groups using "Make_Components" plugin
                        *BUT THIS PLUGIN DOESNT MAKE ALL SELECTED COMPONENTS AS SINGLE GROUPS AT ONCE. THE "MAKE COMPONENTS TO SINGLE GROUPS" SCRIPT ONLY TRANSFORM 1 COMPONENT TO GROUP AT A TIME. SO I'VE MADE A SHORTCUT FOR THAT FUNCTION AND I KEPT REPEATING PRESSING THE SHORTCUT KEY AND THE ENTER KEY, WHICH TOOK ME A LOT OF TIME... ๐Ÿ˜
                      3. I used Raytracer to drop all groups to the terrain
                      I really would like to make this process as quickly as possible... For my future projects. Any idea? ๐Ÿ˜„
                      Thank you
                      • sdmitchS Offline
                        sdmitch
                        I'm with you, I can't figure out why this is so. But, since these are buildings, you wouldn't want them to conform to the surface like Pilou's SmartDrop demo. So something as simple as
                        mod = Sketchup.active_model
                        sel = mod.selection
                        sel.grep(Sketchup;;Group){|g|
                         t=mod.raytest([g.bounds.min,[0,0,-1]])[0]
                         g.transform!(Geom;;Transformation.new(t-g.bounds.min)) if t
                        This works on your groups whether they are exploded and regrouped or not.
                        Select group(s), paste code into Ruby Console, press Enter.
                          Sdmitch to the rescue! ๐Ÿ˜‰
                          But that resolve not the little mystery of the 2 groups states! ๐Ÿ˜„
                          What are special on them ?
                          How do you create that ?
                            gregswk
                            > sel = mod.selection
                            Hi, Sdmitch!
                            Thaaaank you so muchh!! That's all what I needed!!
                            ๐Ÿ˜„ ๐Ÿ‘ ๐Ÿ‘
                              gregswk
                              Hi, Pilou!
                              First of all, thank you so much for all support you are giving to me. ๐Ÿ˜„
                              Yes, the groups states remain. Mystery!
                              I've used Autocad Map 3d to generate those buildings with their proper heights attaching a shapefile. Before I export, I converted polygons to solids using -convtosolid command.
                              Then I saved as .dwg to export those buildings to Sketchup.
                                Even genious Sdmitch has find a solution for your problem ๐Ÿ‘
                                taka a look to these architect tools by Thomthom!
                                A suite of tools to help with imported DWG files aimed at Architecture
                                Maybe there there are some tricky things nside!
                                • sdmitchS Offline
                                  sdmitch
                                  My new project for the weekend!!!!!!!!
                                    I believe that the problem comes from the export DXF from external program! ๐Ÿ˜„
                                    (double vertices ?...)
                                    • sdmitchS Offline
                                      sdmitch
                                      No the problem is that the transformation.origin is not over the "surface"
                                      ` name = Group#445
                                      origin = (-420.075838m, -663.573913m, 8.06m)
                                      x axis = [1.0,0.0,0.0]
                                      y axis = [0.0,1.0,0.0]
                                      z axis = [0.0,0.0,1.0]
                                      x,y,z = [-16538.41882347539,-26124.9572089176,317.32283464566945]
                                      name = Group#468
                                      x,y,z = [-16538.41882347539,-26124.9572089176,317.32283464566945]` which is why the "Drop" fails. By exploding and regrouping the group, the transformation.orig is reset to bounds.min which is over the "surface".
                                        gregswk
                                        ` name = Group#445
                                        name = Group#468
                                        -So that means I need to explode and regroup to reset them? Or there is another way to change their transformation.orig to bounds? Sorry, I didnt understand very well..
                                        -I'm using your script to drop the groups down to terrain, but I'm having some problem... Many groups arent dropping well, they fly. ๐Ÿ˜•
                                        • sdmitchS Offline
                                          sdmitch
                                          [attachment=0:373faxky]<!-- ia0 -->flying.JPG<!-- ia0 -->[/attachment:373faxky]
                                          Could you post a sample of the one's that "fly".
                                            gregswk
                                            @sdmitch said:
                                            [attachment=1:2366zu5c]<!-- ia1 -->flying.JPG<!-- ia1 -->[/attachment:2366zu5c]
                                            badra 5 skp 8.skp
