Vray proxy issue - Urgent help needed
Hi I have imported 3 x plant vrmesh objects from 3ds max, which I have then re applied the materials and saved as SKP. Rendered on their own, in different files they appear as they should. However as soon as I import all 3 models in to one file and render, the models adopt the shape of the first imported model. Though they keep their own texture files...... Does anyone have any idea what is going on?
On a tight deadline, any help would be appreciated.
Images and skp files attached
Are you naming your proxies correctly?
Edit:
Ok, sorry for that really fast and harsh reply.If you are sharing the sketchup files, you should also attach the vrmesh files associated to them. They are however too large to attach.
What is probably happening is that all the components are referencing the same vrmesh file, with different materials set on top. Try to export your plants again with a clear structure of your vrmesh files, and everything should work out fine.
Hi 3dita,
Thanks for your response, very much appreciated. I will give it a go.
Thank you
And share those proxies when you're done. wink wink
