    How to build this model in SketchUp?
    26 Posts 6 Posters 10.6k Views 6 Watching
      Else for Cubify the D πŸ˜‰
      Voxelize by TheDro
      Draw a "D" in any font : Make a Group
      Voxelize by theDro
      Take the Top Line of cubes: Move it
      Explode
      Select Only Top Faces (not perimeters) (Selection Toy) by Thomthom
      Joint Push Pull "N" (random as you want) by Fredo
      et voilΓ  πŸ’š
      PS Ground will be of course trivial! πŸ˜‰
      The 3 letters D N S can be voxelizing in the same time but careful heavy calculation!
      Depending of the scale of voxelisation! πŸ€“
      Edit : in fact no: it's Speedy Light : see following posts! πŸ˜„
        If you take the 1/4 height with Voxelise
        that is speedy light for all letters in the same time! πŸ’š
        Take the Top cubes, Select the faces Joint Push Pull "N" (random) etc...as you want! β˜€
        (for your exact result asked at the first post)
        After moving the original group
        Color by Sdmitch Plugin
        • chippwaltersC Offline
          chippwalters
          Thanks everyone who contributed. Much appreciated.
          Frenchy, thanks for the Voxelize mention. I started using it, but then just couldn't figure out how to easily match the logo with the underlying grid while easily keeping things separate.
          Instead I used Cotty's advice and quickly created a grid comprised of single GROUPED sqares, then placed the logo beneath it and another plane beneath it as Cotty did and projected to Infinity using the Throw It plugin. Needed to keep the squares GROUPED or else they wouldn't 'throw' correctly.
          Once I had individual square poly groups in place, I then EXPLODED them and then creatde a single mesh Group-- one for the base and one for the logo.
          From there it was simple to apply Greeble to the group to get the effect I wanted. On the logo, I used the 'keep top faces grouped' Greeble option so that I could then AGAIN Greeble to get a slight bevel. I would've done the same for the base, but Greeble took so long to work through it, I decided to leave as is. (I don't even know how long as finally I just went to bed).
          Here's the final. Now off to create a KeyShot rendering of it.
          https://dl.dropboxusercontent.com/u/3788438/3D/GreeblesPILOUadj.jpg
          Currently working with Cross-Reality technologies
            @Chipp
            Why Not! πŸ˜„
            Just make 2 goups!
            Letters and a flat ground
            And play with the "N" random range of this flat one with the Joint Push Pull "N"! πŸ˜‰
            Of course fonts must have inbetween letter multiple of cube unity!
            As it's groups you can move them as you want for any positions x,y,z if adjusments are necessary!
            Here my plane is 1 m under the letters - so my range can be for example 0.8 m ---> 1 m
            Thanks to Fredo for this marvelous tools! 😎 Notice the range random! πŸ€“
            (in this video my cubes'ground are rectangles! πŸ’š It was just for the concept! β˜€
              chippwalters
              And the render...
              https://dl.dropboxusercontent.com/u/3788438/3D/PILOUgreeble177sm.jpg
                Space Odyssey! πŸ˜„
                  That's a great little plugin. You should stick it up on the PluginStore.
                  • sdmitchS Offline
                    sdmitch
                    Before I do that, what does it need to be more user friendly?
                    http://sdmitch.blogspot.com/
                      Simple is beautiful! β˜€
                      5 minutes (but many letters! πŸ˜‰
                      In Fact a cool plugin will be also this who draw only the cubics letters!
                      (without random : only the flat crossing plane with the grid )
                      Your parameters don't permit that for the moment! πŸ˜‰
                      Like this we can adapt by example some other plugins! JPP "N" by Fredo by example! πŸ˜‰
                      Or some deformations like TGI3D etc...
                      Here from the Voxelize by TheDro of the beginning posts!
                      (but some killing erase are necessary and size of cube don't adapt to the model - here i was lucky! )
                      • sdmitchS Offline
                        sdmitch
                        @chippwalters said:
                        Does anyone have an idea on how to automatically/algorithmically build this in SketchUp using a bitmap (or other way) to drive the distribution of randomimzed height boxes (or other shapes)?
                        Perhaps some sort of combination of Scatter and other plugins? Thanks for any cycles spent cogitating...
                        https://dl.dropboxusercontent.com/u/3788438/3D/howtodothis.jpg
                        Just the type of mindless exercises I live for. Over the weekend, I tried various scenarios and this was the best of them. Created in less than a minute under SU2016 64bit.
                        Usage:Extensions>SDM Tools>Misc Tool>Random Cubes
                        Random Cubes.skp
                        Random Cubes.rb
                          chippwalters
                          [attachment=1:1at0ardt]<!-- ia1 -->Random Cubes.jpg<!-- ia1 -->[/attachment:1at0ardt]
                          Wow! Amazing. Thanks so much for sharing!
                          • 2 / 2
