    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 545.1k Views 172 Watching
    • majidM
      majid
      Strange.... also it is written that works with su version 8-2015....
      P.S.
      Yeah finally worked!
        It was rewritten to work with v2015.
        When the notes were written it was correct, the update meant it worked with PC & MAC v8 up to v2015 - as there was no v2016 at that time !
        Note that 99.9% of scripts that work with v2015 will also work with v2016.
        It is not signed, so the newfangled v2016 Extensions Loading Policy needs to be set at the lower level[s] to allow it to run, but otherwise it should work just as v2015 usage...
        • E
          esbensjensen
          Hi Kris,
          Could you re-upload the package? It would be very helpful.
          Thanks for sharing πŸ˜„
          @krisidious said:
          Ok, since we figured out who Gordon is and I saw his posts contributing to the community, I'm going to assume everything in my folder is up for grabs.
          Now don't go installing this unless you know what you're doing. Let Tig, Rich, Oxer and Myself sort them out, clean them up and see how they should fit in. We'll offer them up in a combined pack afterwards.
          Here it is.
          http://www.sketchup-house-plans.com/Ivy-Leaves-Kris.zip
          Here's what it contains.
          [attachment=4:f2flub88]<!-- ia4 -->Ivy-Screens-001.JPG<!-- ia4 -->[/attachment:f2flub88]
          [attachment=3:f2flub88]<!-- ia3 -->Ivy-Screens-002.JPG<!-- ia3 -->[/attachment:f2flub88]
          [attachment=2:f2flub88]<!-- ia2 -->Ivy-Screens-003.JPG<!-- ia2 -->[/attachment:f2flub88]
          [attachment=1:f2flub88]<!-- ia1 -->Ivy-Screens-004.JPG<!-- ia1 -->[/attachment:f2flub88]
          [attachment=0:f2flub88]<!-- ia0 -->Ivy-Screens-005.JPG<!-- ia0 -->[/attachment:f2flub88]
          • OxerO
            Oxer
            See my previous entry in this page.
            • E
              esbensjensen
              Unfortunately, the guide posted in your previous entry (http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=36882%26amp;start=540#p545506) seems to no longer work? I cant get access to it - can any of you in here? Maybe I'm mistaking?
              The package I was thinking of was based on a screenshot earlier in this thread. It seemed to have more than the 10 leaves in the zip package - is there no more than those 10 leaves? Not to sound ungrateful, I just want to make sure I'm understanding it right πŸ˜„
                I'll PM you a collection of extra leaves...
                • E
                  esbensjensen
                  Great, I'll try it out first thing tomorrow morning. Thanks! πŸ˜„
                  Anyone who also has the forementioned jpg image "guide"?
                  • B
                    BEAUTIFUL GARDEN
                    Hello,
                    I am using the plunging on sketch, and all is ok.
                    But when i export into Atlantis Render 6, the leafs moved over the branch.
                    Somebody can help me ?
                    http://i97.servimg.com/u/f97/19/53/99/03/th/captur10.png
                    http://i97.servimg.com/u/f97/19/53/99/03/captur10.png
                    http://i97.servimg.com/u/f97/19/53/99/03/th/captur11.png
                    http://i97.servimg.com/u/f97/19/53/99/03/captur11.png
                      There is a known issue with SketchUp Ivy and some file export to renderers where the image size is distorted by the receiving app...
                      Although your images are way too small to see the issue, I suspect that is what is wrong...
                        Solution is explode the 'tree' --> group (or components)
                        Then explode the 'leaves' --> group (or components)
                        Then export the geometry separately to any render app! πŸ€“
                        • C
                          cuervi
                          At first, thank you very much for the pluggin!!...
                          I am new user Sketshup. I downloaded the file but when I want to choose "Leaf Types" not appear nothing.
                          What should I do? thank you very much! and sorry my english....
                            For make your own πŸ˜„
                            Recto verso material can be different! πŸ€“
                            Have happy leaving! β˜€
                              If you have not something like this at this folder
                              for Windows System PC (can be another path following Windows'version)
                              C:\Users\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\LiveIvy\Textures...
                              you must have inside some skp of leaves or some png images!
                              If not load this file (3 leaves) or make your own
                                Jorgensen
                                just tried to grow an ivy and render with octane.
                                it seems that octane somehow moves or resets the leaves scale or something....
                                does anyone know what's going on and if it can be fixed?
                                thanks
                                jorgensen
                                • H
                                  hazzrael
                                  hi guys i have a problem with this awesome plugin ....
                                  Error: #<Math::DomainError: Numerical argument is out of domain - "acos">
                                  C:/Users/Raphael/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/LiveIvy/LiveIvy_branch.rb:35:in acos' C:/Users/Raphael/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/LiveIvy/LiveIvy_branch.rb:35:in grow_stem'
                                  C:/Users/Raphael/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:291:in `block (2 levels) in grow_stem'
                                  if anyone can help me i would be fantastic
                                    Do you get this error all of the time?
                                    Or is it related to particular settings ?
                                    • F
                                      faust07
                                      Have the same problem as jorgensen three posts before. I want to render ivy with indigo RT.
                                      It seems it depends where the ivy leave components are placed in relation to the world origin.
                                      Nothing works - only to explode the ivy leave components. But that can not be the goal. Never had such stubborn components in use ... here an example SKP2016 file, if someone has indigo and can help.
                                      IvyTest_01-Mat25P.skp
                                      SketchUp test scene
                                      result with indigo RT
                                        There have been some weird reports about some renderers and distorted results.
                                        The only fix I can see is to work on a copy model.
                                        Then use the Outliner to select all of the components involved and 'explode' them.
                                        It might take a while to process ?
                                        Then the renderer will probably cope OK ??
                                        • L
                                          LOPES
                                          I have the same problem; "When I use Vray to render geometry generated with Sketchup Ivy, the leaves don't render the same size as they appear in sketchup."
                                          Do you have a solution?
                                          Thank you for all.
                                          JosΓ© Manuel Lopes
                                          • L
                                            LOPES
                                            My name: JosΓ© Manuel Lopes
                                            My email address: lopesjosemanuel @ yahoo.fr
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 36 / 37
