    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
    • OxerO
      Oxer
      Rombout, see this reply http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=36882%26amp;start=540#p545506
      • romboutR
        rombout
        great thanks! i was searching for different name
        • L
          laudhi
          πŸ‘
          • majidM
            majid
            Thanks for the incredible plugin, but is there any update version working with latest Su?
              with latest Su?
              Seems it's works perfectly! πŸ˜‰ (2015-2016) PC for me 😎
              https://s6.postimg.org/mhbfu97gx/water4.jpg
              • majidM
                majid
                Strange.... also it is written that works with su version 8-2015....
                P.S.
                Yeah finally worked!
                  It was rewritten to work with v2015.
                  When the notes were written it was correct, the update meant it worked with PC & MAC v8 up to v2015 - as there was no v2016 at that time !
                  Note that 99.9% of scripts that work with v2015 will also work with v2016.
                  It is not signed, so the newfangled v2016 Extensions Loading Policy needs to be set at the lower level[s] to allow it to run, but otherwise it should work just as v2015 usage...
                  • E
                    esbensjensen
                    Hi Kris,
                    Could you re-upload the package? It would be very helpful.
                    Thanks for sharing πŸ˜„
                    @krisidious said:
                    Ok, since we figured out who Gordon is and I saw his posts contributing to the community, I'm going to assume everything in my folder is up for grabs.
                    Now don't go installing this unless you know what you're doing. Let Tig, Rich, Oxer and Myself sort them out, clean them up and see how they should fit in. We'll offer them up in a combined pack afterwards.
                    Here it is.
                    http://www.sketchup-house-plans.com/Ivy-Leaves-Kris.zip
                    Here's what it contains.
                    [attachment=4:f2flub88]<!-- ia4 -->Ivy-Screens-001.JPG<!-- ia4 -->[/attachment:f2flub88]
                    [attachment=3:f2flub88]<!-- ia3 -->Ivy-Screens-002.JPG<!-- ia3 -->[/attachment:f2flub88]
                    [attachment=2:f2flub88]<!-- ia2 -->Ivy-Screens-003.JPG<!-- ia2 -->[/attachment:f2flub88]
                    [attachment=1:f2flub88]<!-- ia1 -->Ivy-Screens-004.JPG<!-- ia1 -->[/attachment:f2flub88]
                    [attachment=0:f2flub88]<!-- ia0 -->Ivy-Screens-005.JPG<!-- ia0 -->[/attachment:f2flub88]
                    • OxerO
                      Oxer
                      See my previous entry in this page.
                      • E
                        esbensjensen
                        Unfortunately, the guide posted in your previous entry (http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=36882%26amp;start=540#p545506) seems to no longer work? I cant get access to it - can any of you in here? Maybe I'm mistaking?
                        The package I was thinking of was based on a screenshot earlier in this thread. It seemed to have more than the 10 leaves in the zip package - is there no more than those 10 leaves? Not to sound ungrateful, I just want to make sure I'm understanding it right πŸ˜„
                          I'll PM you a collection of extra leaves...
                          • E
                            esbensjensen
                            Great, I'll try it out first thing tomorrow morning. Thanks! πŸ˜„
                            Anyone who also has the forementioned jpg image "guide"?
                            • B
                              BEAUTIFUL GARDEN
                              Hello,
                              I am using the plunging on sketch, and all is ok.
                              But when i export into Atlantis Render 6, the leafs moved over the branch.
                              Somebody can help me ?
                              http://i97.servimg.com/u/f97/19/53/99/03/th/captur10.png
                              http://i97.servimg.com/u/f97/19/53/99/03/captur10.png
                              http://i97.servimg.com/u/f97/19/53/99/03/th/captur11.png
                              http://i97.servimg.com/u/f97/19/53/99/03/captur11.png
                                There is a known issue with SketchUp Ivy and some file export to renderers where the image size is distorted by the receiving app...
                                Although your images are way too small to see the issue, I suspect that is what is wrong...
                                  Solution is explode the 'tree' --> group (or components)
                                  Then explode the 'leaves' --> group (or components)
                                  Then export the geometry separately to any render app! πŸ€“
                                  • C
                                    cuervi
                                    At first, thank you very much for the pluggin!!...
                                    I am new user Sketshup. I downloaded the file but when I want to choose "Leaf Types" not appear nothing.
                                    What should I do? thank you very much! and sorry my english....
                                      For make your own πŸ˜„
                                      Recto verso material can be different! πŸ€“
                                      Have happy leaving! β˜€
                                        If you have not something like this at this folder
                                        for Windows System PC (can be another path following Windows'version)
                                        C:\Users\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\LiveIvy\Textures...
                                        you must have inside some skp of leaves or some png images!
                                        If not load this file (3 leaves) or make your own
                                          Jorgensen
                                          just tried to grow an ivy and render with octane.
                                          it seems that octane somehow moves or resets the leaves scale or something....
                                          does anyone know what's going on and if it can be fixed?
                                          thanks
                                          jorgensen
                                          • H
                                            hazzrael
                                            hi guys i have a problem with this awesome plugin ....
                                            Error: #<Math::DomainError: Numerical argument is out of domain - "acos">
                                            C:/Users/Raphael/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/LiveIvy/LiveIvy_branch.rb:35:in acos' C:/Users/Raphael/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/LiveIvy/LiveIvy_branch.rb:35:in grow_stem'
                                            C:/Users/Raphael/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:291:in `block (2 levels) in grow_stem'
                                            if anyone can help me i would be fantastic
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 36 / 37
